Nintendo switch 2 no wifi or bluetooth need cap value.
  • lilrepairshop
    • Dec 2023
    • usa
    I have a cracked cap on a nintendo switch 2 that i need the value of. it is C1 in the images attached,
  • Boardview and Schematic Bot
    Nintendo Switch Endurance HAD-CPU-10 HAD-CPU-01 Schematic & Boardview
    Nintendo Switch Endurance HAD-CPU-10 HAD-CPU-01 Schematic & Board view
    Switch Endurance HAD-CPU-10 image.pdf
    Switch Endurance HAD-CPU-10 PCB layer.pcb
    Switch Endurance HAD-CPU-01 image.pdf
    Switch Endurance HAD-CPU-10 USB-V2-Mariko-Pinout.pdf
    Switch Endurance HAD-CPU-10 PCB layer obdata.zip...
    09-30-2026, 03:30 AM
  • master_haze86
    macbook a1278 no wifi but bluetooth works
    by master_haze86
    Good day everyone,
    I got a macbook a1278 come in the other day with wifi issues. Owner says wifi just stopped working from one day to the next. As in, wifi was working previous evening, next day the laptop was turned on, wifi no longer worked.
    Just says "no hardware installed" under wifi while Bluetooth works without issues.
    First things first, I did the usual of removing certain settings files from the system configuration folder and let macOS rebuild them which did nothing to resolve the issue.
    Next I checked the motherboard's wifi connector...
    08-01-2026, 02:09 PM
  • ryogadan78
    Nintendo Switch OLED no Bluetooth, power button doesn’t work
    by ryogadan78
    Good morning everyone, I’ve got a problem with a Nintendo Switch console that was brought into my workshop. I should mention that another repair centre had installed a PicoFly using the ‘kamikaze’ method for the D0.
    The power button on the console isn’t working; I can switch it on by connecting the USB power supply (once it’s on, I can disconnect the power supply). I’ve obviously tried another flat cable that definitely works, but nothing has changed. I’ve inspected the console and found no signs of damage, but I did find a lot of copper dust scattered across the mainboard....
    05-28-2026, 02:24 PM
    Nintendo Switch OLED HEG-CPU-01 PCB Schematic & Boardview
    Nintendo Switch OLED HEG-CPU-01 PCB Schematic & Board view
    Switch OLED-HEG-CPU-01 PCB layer.pcb
    Switch OLED HEG-CPU-01 image.pdf
    Switch OLED-HEG-CPU-01 USB-OLED-PINOUT.pdf
    Switch OLED-HEG-CPU-01 PCB layer.zip...
    10-05-2026, 10:50 AM
    Nintendo Switch 2 BEE-01 BEE-CPU-01 Boardview and Schematic
    Nintendo Switch 2 BEE-01 BEE-CPU-01 Board view and Schematic
    List of Switch2 Chips:
    NVIDIA GMLX30-A1 applications processor w/ GPU
    Micron MT62F768M64D4EK-026 WT:B 6 GB LPDDR5 SDRAM memory
    Infineon CP10359AT USB type-C controller
    Nintendo B2423 Game Card reader controller
    Genesys Logic GL852G quad-port USB 2.0 hub
    Analog Devices MAX17050 battery fuel gauge
    Diodes Incorporated PI2SSD3212NCE 14-bit 2:1 SSD switch
    Texas Instruments TPS2121 dual-input, single-output power multiplexer
    Analog Devices MAX18000 boost converter...
    09-30-2026, 03:45 AM
