I am having trouble figuring out what is wrong with my elite series 2 (1797 model) power board MCU. I was replacing the thumbsticks, which i have replaced many on different kinds of controllers with success. However, when i went to test it and put it back together, the controller no longer turns on. Ive looked at all sorts of capacitors and resister and havent found any shorts. I have a donor board that i tested to make sure it turned on first. I took the power management BQ chip off that board and successfully transferred it but still nothing. I then took the BQ chip from the original one and placed it on my donor and that board still turned on. Is there another chip that handles some of the power delivery or should i continue probing for any shorts or reflow any other chips? I do have a bench power supply that i was thinking of hooking up to inject and see if any component gets hot but i would have to use the alcohol method as i dont have a thermal cam. I also am not sure how much voltage/amps i should inject on the main positive and negative on the board. Its possible that some flux got underneath the bigger BGA chip on the flipside (bottom aide of thumbsticks) when i was changing out the joysticks. A boardview of this might be helpful as well
