Hi, I am trying to fix an xbox one s. The issue is a mosfet (Q9F1) keeps shorting through. I'm thinking the issue may be with U9F1. I had to do some trace repair on one of the pads (pin 12) and still had the sam3 issue. I have removed the chip (51916) and checked for shorts on every pin. The only thing I can find is around 9 ohms between pins 18 and 19. Looking at the pin out and block diagram it seems these should not be connected. Please correct me if i am wrong. Will buy some anyway as im all out. Any help would be appreciated.
Xbox one s no power issue.
Tags: None
Thanks for the response. Yes there is a pair of mosfets Q9F1 and Q9F2. The other mosfet seems to read ok in circuit. It's always the 1 that shorts thru. Replaced a couple of times and voltage does hold for a very short time then it goes. I was thinking if pins 18 and 19 are not supposed to be connected then that is definitely an issue. I will take a look at U9F2. ThanksComment
All I can tell you at the moment is that it's an xbox one s. 2016 I think. I will check and get board ID when I get home from work. Sorry I didn't realise there were different one s boards. Every one I've worked on has been the same.Comment
page 50
Attached FilesPremium supporters get full download access and other benefits.
Hi I have removed TPS51916 and found i have a short between pad 1 (VTTSNS)and pad 3 (VTT). I don't think it is supposed to be there but failing to find where it could be. Thinking maybe ram but would be a guess. Both pad 1 and pad 3 go to V_VTTB. I have scrolled through the pages a bit and have no idea where to find this. Could you please point be in the right direction. Thanks again.Comment
I just found VTT and VTTSNS on U1P1 (TPS51206) and it seems they are connected. Nice having the schematics but frustrating. Like looking for a needle in a haystack.Comment
Xbox 360 All Models x815842-002 X862605-002 584711 Schematic & Board view
Xbox 360 Jasper V1 x815842-002 osp.pcb
SCHEMATIC 584711 Wireless Control.pdf
Xbox 360 Corona V5 V6 sterling osp.pcb
Xbox 360 Corona V1 V2.brd.pcb
Xbox 360 Corona V3 V4 X862605-002 waitsburg.pcb
Xbox 360 Trinity FabF ver2.pcb
Xbox 360 Zephyr_B.pcb
Xbox 360 Zephyr A.pcb
Xbox 360 Jasper Kronos.pcb
Xbox 360 Falcon.pcb
Xbox 360 Xenon.pcb
Xbox 360 Xenon 008.pcb
Xbox 360 Corona Translation Schematic.pdf
Xbox 360 Zephyr A Schematic.pdf...-
Channel: Schematics and Boardviews
10-01-2026, 03:26 AM -
by GLISITHi all,
A few weeks ago I was using the laptop (on battery power) for a Zoom meeting. The battery was running very low (long meeting) but I wasn't worried about... -
Lenovo ThinkPad E480 - power LED only, no fan, no USB 5V, CPU cold (suspected power rail/fuse issue)by tux.ktLenovo ThinkPad E480 - power LED only, no fan, no USB 5V, CPU cold (suspected power rail/fuse issue)
Post:
I have a Lenovo ThinkPad E480 motherboard with the following issue.
The laptop shows only a power LED when connected to charger, but it does not boot at all.
Symptoms:- Power LED turns on
- No fan spin
- No display (internal or HDMI)
- No Caps Lock response
- CPU stays completely cold
- USB ports do not provide 5V power
Board condition:
I found corrosion around the power/PM area. I cleaned the motherboard carefully,...7 Photos -
by AndreasbestHello.
Received a LA-H32AP motherboard with AMD cpu, only reaction is the power led (LED1) that lights up for 5 secs, nothing else.
Summary↓
The laptop was working normally the previous day.
When pressing the power button, LED1 (Power LED) turns on for a few seconds and then turns off. The motherboard does not boot.
Some power rails remain active for several seconds after LED1 turns off.
Troubleshooting already performed:- Tested different RAM modules.
- Tested without RAM.
- Tested again with RAM installed — exactly the same behavior.
- Removed
by 9xnokiax9Repair Tip: Power-off or No Power Issue Caused by MPS CPU Power IC (MP2960)
After lurking and learning a lot from experienced technicians in the community for a long time, I would like to share a common hardware fault based on my practical experience. This issue frequently occurs on laptops utilizing MPS CPU power ICs, such as HP Zbook, Lenovo Legion, Thinkpad, LOQ, GALLERIA, Dell XPS, etc.
1. Symptoms- Plugged in the charger, cannot power on, only the keyboard backlight turns on.
- The laptop shuts down suddenly when plugged into the charger
10-03-2026, 02:26 AM - Loading...
