PS5 CFI-1216B EDM-030 - no power
  • Clarify4082
    • Oct 2022
    • 118
    I`m working an a Playstation 5 which is not turning on. No lights, no beep, nothing. When I got the console there was metal liquid spilled over the board.
    I´ve checked all fuses and voltages and can´t find anything wrong. Also I can´t find any shorts.
    When connected to the power supply it takes 3mA and the southbridge is getting warm. I´ve replaced the southbridge already twice but nothing changed.
    I also tried to flash a new bios but this also didn´t change anything.
    Here are some voltage readings around the southbridge:
    Click image for larger version  Name:	image.png Views:	0 Size:	2.62 MB ID:	3935098
    I´m not sure if there is some voltage missing, or what else the problem could be.
    Any help appreciated
  • Clarify4082
    • Oct 2022
    • 118
    There is a resistor which is also getting warm, near the F7002 fuse. I´ve measured 1.8V:
    Which value should this be? I measure .197kOhm
    If I inject 1.8V the board is taking 6ma...
    • Clarify4082
      • Oct 2022
      • 118
      Update: Replaced it with a 200kOhm resistor. Now the resistor doesn´t get warm and it seems fine when injecting voltage.
      Beforehand I also reballed the wifi-ic because I thougt this may be a issue.
      Now I get this diode-readings on the wifi-ic and I´am not sure if this is healthy (377 on the 1.8V rail):
      Click image for larger version  Name:	image.png Views:	0 Size:	2.21 MB ID:	3936133
      I also get 3.3V and 1.8V on theses capacitors, so I believe the wifi is fine?
      Still board takes 3ma when connected to the power supply
      • LaPCon_IT
        • Sep 2022
        • 98
        • Malta
        If the liquid metal was spilled on the board, it could be anywhere - under the APU, RAM, SSD controller...
        • Clarify4082
          • Oct 2022
          • 118
          Yes, you´re right, I thougt it could be a bad wifi-chip, but also after replacing the chip nothing changed .
          I´ll use it as a donor...
          • Andreasbest
            HP LA-H32AP motherboard power on for 5 secs
            by Andreasbest
            Hello.
            Received a LA-H32AP motherboard with AMD cpu, only reaction is the power led (LED1) that lights up for 5 secs, nothing else.
            Summary↓
            The laptop was working normally the previous day.
            When pressing the power button, LED1 (Power LED) turns on for a few seconds and then turns off. The motherboard does not boot.
            Some power rails remain active for several seconds after LED1 turns off.
            Troubleshooting already performed:
            • Tested different RAM modules.
            • Tested without RAM.
            • Tested again with RAM installed — exactly the same behavior.
            • Removed
            10-19-2026, 03:11 PM
          • calebtree33
            Nitro 5 AN515-58 Power Up Sequence Failure
            by calebtree33
            Device: Acer Nitro 5 AN515-58-5046
            Board: LA-L973P HH514
            Context: I bought this from a guy hoping to fix it and resell it as I am learning motherboard repair. He said that the laptop would start powering up, fans would spin, and keyboard backlight would turn on. When the screen turned on, the time was wrong. Eventually it stopped turning on altogether. I am confused as to how this could be a gradual failure.
            Problem: When pressing the power button the LED showed for about 5 seconds before shutting off. The laptop would charge with the charging light. I cannot find...
            09-24-2026, 08:18 PM
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • PantherDave
            by PantherDave
            Hi all!
            05-29-2024, 02:01 PM
          • GLISIT
            by GLISIT
            01-16-2025, 02:29 PM
