SVOD4 - Winbond 25R256JVFN SOP-16 - Verify False After Read
  • BenzoCarpy
    • Mar 2026
    • 14
    Hi All,
    I am currently experiencing a bit of an issue with my SVOD4. I am trying to read a Winbond 25R256JVFN SOP-16 chip, however I keep getting "Verify false" after the read. I have tried the same chip with the same adapter in the RT809H and it reads the chip just fine. I manually verified the two reads from the RT809H and they are fine. I'm not too sure what's going on, so any help is appreciated. Here is the SVOD ver0.0.7.6 log:
    Software version 0.0.7.6 date 4.08.2026
    Running Microsoft Windows 11 Pro 64 bit
    Intel(R) Core(TM) i3-9100T CPU @ 3.10GHz
    .NET Framework Version: 4.8 or later
    Device connected in work mode
    Firmware version 0.0.5.4 date 4.8.2026
    SPI25 mode selected
    SPI speed set to 20 MHz
    SOP16 package selected
    Test pins..
    Test pins OK
    Read ID Flash..
    JEDEC ID: EF4019
    SFDP compatible
    Vcc Supply Maximum Voltage: FFFF mV
    Vcc Supply Minimum Voltage: FFFF mV
    Address size :4 byte
    Size: 0x02000000 (33554432) byte
    W25Q256 / W25Q256FV
    Status register 1 : 0x00
    Status register 2 : 0x02
    Start reading in: 17/08/2026 15:55:58
    End reading in: 17/08/2026 15:56:12
    Read OK
    Auto verify
    Start verify in: 17/08/2026 15:56:12
    error
    address: 0x125041F
    buffer: 0x6F device: 0x6E
    Verify false
    P.S I have tried changing the voltage and changing the SPI speed, but it either makes no difference or won't even read the ID of the chip. I have also been able to read and write to and IT8227 EC chip with the keyboard extender adapter, so I know the SVOD4 is able to read other types of chips. I have also been able to read and write to a Winbond WSON 6X8 BIOS chip from a dell absolutely fine.
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8800
    Chip on board or off the board?
    • BenzoCarpy
      BenzoCarpy commented
      Editing a comment
      The chip is off the board in an adapter
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8800
    Verify the false read against the read with the rt809h.
    • BenzoCarpy
      • Mar 2026
      • 14
      CapLeaker I have two reads from each programmer. The two reads from the RT809H are identical, but the two from the SVOD are different from each other and are both different to the RT809H reads. I have uploaded the reads, if you want to take a look. Oh and thank you for helping by the way
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8800
        For some reason I can't download your files. It initiate the download o.k. but nothing is being sent to finish the download.
          • 24922
          It downloads ok here , can you try again
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8800
            Change the status register #2 so it has the same status as #1. Probably that why it fails.
            • BenzoCarpy
              • Mar 2026
              • 14
              I assume this is to change the status register? Doesn't appear to be an option to set them to the same value. And now I have accidentally set Status Register 2 to BIT 5. If I untick BIT 5 and click Write config, it keeps re-ticking it. QE was already ticked, but does the same if I try to untick it and click Write config
Name:	Screenshot 2026-08-24 123756.png
ID:	3923902 Click image for larger version
Name:	Screenshot 2026-08-24 124635.png
                • 31927
                on a lot of flash the config is one-time.
                in other words - you cant erase set bits.
                • CapLeaker
                  Leaking Member
                  • Dec 2014
                  • 8800
                  Setting bit5 in status register #2 locks whatever is in status register 1 (at least that is what I thought). I think your programmer cannot handle QE (Quad Enable) and that is why you get garbage. You should be able to clear all that
                  SVOD4 often misreads SR2 when QE is set, causing “Verify False After Read"
                  • BenzoCarpy
                    • Mar 2026
                    • 14
                    CapLeaker Thanks for the info. I do find it weird that I have done these chips before on the SVOD with no problem. Seems odd that this one doesn't read correctly. Also, do you know if there is a way to untick QE? When I try to untick QE and set the config, it just re-ticks it straight away.
                    • CapLeaker
                      Leaking Member
                      • Dec 2014
                      • 8800
                      I don't have an SVOD programmer, so I can't test nothing. I do have an XGECU TL866II, a T76 and an RT809H. You do have a good copy with the read from the RT809H. Maybe try working with it?
                      • portal7
                        Dell Latitude 5440 - Help reading dual Winbond SPI flash in-circuit with CH341A on Linux
                        by portal7
                        I’m working on a relatively new Dell Latitude 5440, Intel i5 model, and I’m trying to make clean backups of the onboard SPI flash chips without desoldering, if possible.
                        The motherboard has two Winbond SPI flash ICs close to each other:
                        - UC2: Winbond 25Q256JVEN, likely 32 MB
                        - UC6: Winbond 25R128JVSN, appears to be 16 MB
                        I’m using a CH341A programmer with a SOIC8 clip on Linux.
                        Tools tested:
                        - flashrom on Linux
                        - IMSProg GUI on Linux
                        With flashrom, UC6 is sometimes detected...
                        05-14-2026, 12:26 PM
                      • 2elw
                        SVOD4 PCB pictures + parts
                        by 2elw
                        Hey, I find it very absurd that the SVOD4 costs so much and has zero documentation. I had no other choice than to buy it to unlock ECs, if there was any documentation or firmware avalible I could've made it or something simmilar. Anyways here are some of the most important parts:
                        STM32H723VGT6 MCU - It's a microcontroller by STMicroelectronics and its the whole brain of the SVOD4. It has flash memory for the firmware which can be updated by the SVOD4 program. Its also powered by the AMS117 which converts 5v into 3.3V. 7€ on AliExpress.
                        GW1N-UV9UG169C6/I5 FPGA - Its a...
                        07-04-2025, 12:23 PM
                      • in-sympathy
                        SVOD4 + Alexsof CYPD adapter
                        by in-sympathy
                        Hi guys.
                        I have a SVOD4 and got me a CYPD offline adapter from Alexsof.
                        No matter what I tried and what Alexsofsuggested - we can't get this adapter to work - in latest 0.0.6.6 version of SVOD app if I choose 1.8V in CYPD mode - I see ARM core detected messages, but CYPRESS is still not found.
                        Here is what the adapter looks like:
                        And it has placeholders for resistors and caps on the back:
                        Alexsof says that it's enough to add pull rst 1K resistor and it works with Cypress MiniProg4. I tried to add it - won't work with...
                        04-12-2026, 05:52 AM
                      • Trademark
                        Acer Predator Triton 16 PT16-51-99GL (DA0ZQDMB8AE Rev. E) - Looking for original 32MB BIOS dump (Winbond W25Q256JVEN)
                        by Trademark
                        I’m hoping someone can help me locate a verified original BIOS dump for my Acer laptop.
                        This is NOT a BIOS password removal request.
                        I’m looking for an original 32MB SPI BIOS dump to use as a reference in case my BIOS firmware is corrupted. My plan is to first dump and back up my own BIOS as soon as my programmer arrives. I am not planning to blindly flash someone else’s BIOS.
                        Laptop Information
                        • Model: Acer Predator Triton 16 PT16-51-99GL
                        • Motherboard: DA0ZQDMB8AE Rev. E
                        • Main SPI flash: Winbond W25Q256JVEN (32MB)
                        • Secondary
                        07-22-2026, 08:57 AM
                      • bharataus
                        Acer Nitro 5 N22C1 (AN515-58-93JE) – BIOS Fix Needed (Winbond 25Q256JVEQ 32MB)
                        by bharataus
                        I’m working on an Acer Nitro 5 and need assistance with a BIOS repair.
                        Device Details:
                        Model: Acer Nitro 5 N22C1
                        Variant: AN515-58-93JE
                        BIOS Chip: Winbond 25Q256JVEQ (32MB)
                        Serial Number: NHQHYSAA003245032C63400
                        SNID: 24501299834
                        MFG Date: 2022/11/12
                        Issue:
                        The laptop is not functioning properly, and I suspect a corrupted BIOS.
                        What I Have:
                        Original BIOS dump (attached)
                        Photos of the device...
                        04-22-2026, 12:23 AM
