Qubo Dash Cam Pro X Stuck During Boot: SigmaStar SSC335R + W25N512GV SPI NAND
  • Marcus3235
    • Jan 2024
    • 8
    • India
    Note: I am not a professional electronics/embedded engineer. Everything I've done so far has been learned through YouTube videos, datasheets/forums, and guidance from AI. I've been proceeding cautiously, measuring and documenting each step, and have deliberately avoided writing/erasing the NAND or making irreversible changes.
    Qubo Dash Cam - SigmaStar SSC335R stuck at "Load BL from SPINAND"
    I'm trying to recover a Qubo dash camera that stopped booting. Qubo support told me the unit has gone bad and recommended replacing it, so I'm investigating the board and would appreciate some help from anyone familiar with SigmaStar/SPI NAND recovery.
    Symptoms
    When powered from a USB charger, power bank, or car USB port:
    - Red LED flashes briefly.
    - It then becomes solid red.
    - Camera never boots.
    - Holding the power button makes the LED disappear, but releasing it makes the red LED return.
    Hardware identified
    Main SoC:
    Code:
    SigmaStar SSC335R
    STAR
    SSC-335R
    AM-315-298
    232-88
    ARM
    SPI NAND:
    Code:
    Winbond W25N512GVEIG
    WSON-8, approximately 8 x 6 mm
    Other chips:
    Code:
    Realtek RTL8188FTV
    IP6303 PMIC
    There is also a microSD slot used for recordings.
    UART
    I found four test pads labelled:
    Code:
    R  T  V  G
    Using a DT830D multimeter:
    Code:
    VBUS → GND = 5.02–5.03 V
    V → G     = 3.35–3.37 V
    R → G     = 3.25–3.26 V
    T → G     = 3.25–3.26 V
    I connected an FT232 USB-UART adapter at 3.3 V.
    The working connection is:
    Code:
    Qubo T → FT232 RX
    Qubo G → FT232 GND
    R → RX produces no output.
    UART settings:
    Code:
    115200 baud
    8-N-1
    No flow control
    Full clean Tera Term boot output
    This is the complete useful output I consistently get:
    Code:
    IPL g4b89453
    D-15
    SPI 54M
    64MB
    BIST0_0001-OK
    Find CIS in block00
    SPI 86M & SPI_CK driving
    Checksum OK
    IPL_CUST g4b89453
    Find CIS in block00
    Find CIS in block00
    It remains at:
    Code:
    indefinitely. I left it for approximately 7 minutes without any further useful output.
    I also tried 921600 baud, but that produced no useful output. 115200 gives the clean boot log above.
    What I have verified
    The SSC335R is clearly executing IPL.
    DDR appears to pass:
    Code:
    BIST0_0001-OK
    The NAND is detected and the bootloader finds its CIS:
    Code:
    Find CIS in block00
    The first loaded image reports:
    Code:
    Checksum OK
    The NAND remains powered while the system is stuck:
    Code:
    Pin 8 VCC ≈ 3.35–3.37 V
    Pin 3 /WP ≈ 3.36 V
    Pin 7 /HOLD ≈ 3.36 V
    I also checked the SPI pins against GND with the board unpowered. No obvious short was found on:
    Code:
    Pin 1 /CS
    Pin 2 DO
    Pin 5 DI
    Pin 6 CLK
    Programmer
    I have a CH341B programmer and NeoProgrammer.
    NeoProgrammer recognizes:
    Code:
    W25N512GV
    3.3 V
    512 Mbit
    SPI_NAND
    2048-byte page
    The CH341B's 3.3 V output measures 3.29–3.30 V.
    I have NOT connected the CH341B to the Qubo NAND yet, and I have NOT erased or written anything.
    I also have a generic SOIC-8 clip, but it is not suitable for this WSON-8 package. I'm considering getting a proper WSON-8 8 x 6 mm probe/clip.
    My current theory
    The board is not completely dead. It gets through:
    Code:
    IPL
    DDR BIST
    CIS detection
    Checksum OK
    IPL_CUST
    HANG
    I'm wondering whether the second-stage bootloader is corrupted or whether there is a NAND/ECC/bad-block/read issue.
    I'm particularly interested in understanding exactly what SigmaStar means by "Load BL from SPINAND" at the IPL_CUST stage.
    Questions
    1. Does this log indicate that IPL_CUST is hanging while reading/loading the next bootloader from SPI NAND?
    2. Could NAND ECC, bad blocks, or corrupted data cause this exact behavior?
    3. What does the earlier "Checksum OK" actually validate?
    4. Is there a known SigmaStar SSC335R bootloader/recovery process for this IPL/IPL_CUST format?
    5. Can the W25N512GVEIG be safely dumped in-circuit with a CH341B?
    6. Does the SSC335R need to be isolated from the NAND before connecting an external programmer?
    7. If dumping it, should I preserve the NAND spare/OOB area as well as the 2048-byte data pages?
    8. Are there SigmaStar tools or methods for inspecting/recovering the bootloader from this type of SPI NAND?
    My priority is to make a complete backup of the original NAND before attempting any repair or reflashing.
    Thanks in advance to anyone who can help interpret the boot log or suggest the safest next diagnostic step.
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8820
    Did it show some ailing signs or weird behaviour before this? There are many dash cams across different brands specially the past 5 or 6 years ago that do just that.
    in Order to test the NAND you have to take it out, copy its contents, then write it full and write it full again and check. Is the battery or super capacitor still working?
    • tranquility
      Onkyo TX-NR809 – no hdmi, DTS or NAND chip ? stuck at starting kernel
      by tranquility
      i want to repair an Onkyo TX-NR809 receiver.
      symptoms:
      on power on, display appears and i hear one click. enue functions is given.
      - no hdmi output
      - audio output not tested, but i think it is not there
      - usb sticks are not recognized
      if i read out the chips with display+standby button + tone+
      both dts show only ????
      chip is D830K013BZKB4
      things i have done:
      - reflow of the dts chip without taking off and reballing
      - changed the aluminium caps without the big one with 25v because i dont...
      08-25-2025, 01:04 AM
    • anik0101010
      [REQ] RCF M18 Digital Mixer - NAND Recovery files (uImage / ubi.img) or Dump
      by anik0101010
      I'm working on a bricked RCF M18 digital mixer. The unit was completely dead, but I managed to resurrect the hardware doing a low-level recovery via the internal UART header and the Debug Jumper method (as per RCF Service Note 1903B).
      I successfully booted from the SD card, wiped the NAND, and flashed U-Boot. The CPU is alive and I now have a working serial console at the RCF-M18# prompt.
      The Problem:
      The recovery script halted because the official firmware update provided by RCF on their website (.mpk format, ~1.5MB) is just an application...
      04-07-2026, 02:34 PM
    • janos6662000
      Samsung MX-T70 Sound Tower - Dead, stuck in early boot loop / bootloader console via UART (Need Dump)
      by janos6662000
      I'm working on a Samsung Sound Tower MX-T70 (1500W Party Audio) that came to me completely dead, showing no signs of life. Since I couldn't find any schematics or service manuals, I did some deep diagnostics and measurements.
      Here is a summary of what I have checked and done so far:
      • Power Supply: The standby voltage is present and stable at 12.3V–12.5V. The 3.3V rail is also active.
      • Power Button: The power key pin receives 3.3V and successfully drops to ~0.3V when pressed, so the signal reaches the board.
      • PSU Forced Start: I identified the Power-On
      07-17-2026, 03:31 PM
    • cheebster
      MacBook Pro 2019 A2141 820-01700 NAND Issue Stuck in DFU
      by cheebster
      Ok, here's an issue ive got on a A2141 820-01700 MBP 16' 2019. No signs of life, 5.06v 0.0a on usb-c meter, on each 4 usb-c ports.
      Nand voltages are missing.
      I've found no shorts at all so far, no signs of heat via thermal camera either.
      PPBUS_G3H 12.31
      PP3V3_G3H_RTC 3.387v
      PP3V3_G3H 12.31v
      PP2v5_NAND_SSD0 0v 58 ohms
      PP2v5_NAND_SSD1 0v 57.8 ohms
      PP1v8_SLPS2R 1.8v
      PP1v1_SLPS2R 1.1v
      P3V3_G3H_SOCPMU 3.37v
      PP0V9_SLPDDR 0.9v...
      10-11-2023, 11:31 AM
    • Stunt
      Hp Laptop Stuck on Hp protected by hp sure start screen
      by Stunt
      Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
      I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
      I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
      Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
      screen that's it and stuck there. I left it until the following day and i still...
      09-02-2025, 01:51 PM
