Pls any idea for this problem
Ps4 blod with this uart code
That's not a hardware fault, the board boots fine. The panic is on the encryption layer:
panic: eap key not available means the PS4 can't access the EAP (Encrypted APU) key used to decrypt the system partition. This happens when:- HDD was swapped without going through recovery mode first. The replacement drive doesn't have the console-specific encrypted partition. Fix: boot into recovery (hold power ~7s until 2nd beep), choose option 7 "Reinstall System Software" with a USB containing the full PS4UPDATE.PUP.
- Corrupted system partition - same fix, option 7 from recovery.
- If recovery mode itself panics with the same error, the key storage in the APU's secure enclave is gone. That's board-level and typically means APU replacement.
The [REGMGR] 000006 / 010007 / 000108 codes are just the crash register dump, nothing diagnostic there.
The Belize SATA PHY cycling (ahci1 init repeating 3x) is normal on CUH-1200, just the PHY training loop.
Try recovery option 7 first, 90% of these are HDD swap without proper init.
boardrepair.me/guides/ps4.html has the full UART stage map if you need to cross-reference further boot stages.
by gobkillerHello,
i am working on a ps5 edm-010 board with a blown fuse and UART code of 80810001. I cleared the code and power cycled the ps5 and same error code.
i have checked a lot of the capacitors on the board and i haven’t found one that is short to ground. The power supply also outputs 12V. The PS5 has a beep on beep off fault. Blue light for about 2 seconds. The person i got it from said that it was overheating a lot and then just randomly started shutting off with the beep on beep off. When i opened it, it has a horrible dry spot on the apu and heat sink.
...10-15-2026, 12:01 AM -
by 1centchipsGoes to recovery when plugged in with another Mac, shows in finder with a question mark and serial number. When revived fails at error 9 (the laptop turns off and on?) In the Apple Configurator when in dfu, gives error restores device removed before restore completed 0xFAA (4010). Tried in intel and m1 based Macs.
History, came in with severe liquid damage and bubbly motherboard
Transplanted t2/ recalled ram, u4730, all 4 nands and u4770.
Below is the log from console, the usb meter negotiates at 19v and goes as high as 2.4A
Apr 1 08:36:25 macs-MBP UARPUpdaterServiceDisplay[1440]:...04-01-2026, 11:38 AM -
by kurtspiritHello,
I have a PS5 exhibiting the classic symptoms: it beeps, the LED lights up for a second, and then it shuts down.
I ran a UART log and cleaned it up to be sure, and the resulting codes are:
80060080 and 80000009.
Naturally, the first code is unknown… so I’m not sure where to look.
I swapped the power supply to test it, but that didn’t solve the problem.
Does anyone have any ideas, please? I’ve checked the fuses and the usual capacitors, but I can’t find any short circuits.
Thanks. -
by orion78frHi everyone !
So a friend gave me a ps4 to rescue but it just pulses blue and never boots. I can't get it to safe mode either (maintaining the power button never gives a second beep, except after like 15 seconds to force turn off). Nothing visible on the board and removing the hard drive doesn't change anything (SMART data are OK on PC).
I'm trying to enable UART on the PS4 to get info on what it stops on, if a memory is bad, something is corrupted... as explained here : https://repair.wiki/w/PS4_UART_Guide
However, the software that everyone used,... -
TCL LED TV Service Menu Code
LG LED TV Service Menu Code
Veste/ LED TV Service Menu Code...-
Channel: Schematics and Boardviews
10-31-2024, 03:58 AM -
- Loading...
