I’m looking for advice on a PlayStation 5 Slim, model CFI-2016, motherboard revision EDM-041.
Symptoms
At this stage I’m intentionally not assuming:
Before moving into deeper electrical diagnosis or invasive steps, I’d like to:
I will attach high-resolution photos of both sides of the motherboard for reference. Any insight, documentation, or shared experience would be greatly appreciated.
Thanks in advance.
Symptoms
- Console beeps once when pressing power
- Blue LED turns on for about 1 second
- Fan spins very briefly
- Console shuts down immediately
- No second beep, no error message
- TV briefly detects an HDMI signal, then nothing . This behavior is 100% consistent on every power attempt.
- The console is PS5 Slim, digital model
- Motherboard has been removed from the chassis for inspection
- No visible catastrophic damage (no burned components, no cracked silicon)
- There are signs of residue / oxidation around the APU area, possibly related to liquid metal migration or long-term exposure (photos attached)
- Power supply appears to deliver standby and main power normally (at least at a basic level – no obvious collapse or instability observed during power-on)
- VRM area around the APU looks intact
- No visibly blown MOSFETs
- No obviously shorted or missing components
- Some discoloration/residue around the APU frame and nearby copper areas (again, visible in photos)
- a shorted APU
- a bad VRM
- a firmware / Syscon issue
- liquid metal damage being the root cause
- experience with EDM-040 / EDM-041 PS5 Slim boards
- knowledge of common failure modes on PS5 Slim
- access to boardviews, schematics, or known-good reference points
- seen similar “blue light for 1 second then off” cases on Slim revisions
- confirm whether this symptom pattern is commonly associated with a known failure on EDM-041
- understand if there are known always-on rails or enable sequences that are typical failure points on Slim boards
- rule out (or confirm) liquid metal migration as a realistic primary cause on this revision
Thanks in advance.
