Baykunl DRO Digital Readout D80M-3V - TFT LCD no image, backlight works
  • arkkkk
    • Dec 2025
    • 11
    • Venezuela
    • Soldering, Electronics, Gaming
    Hello everyone
    A friend gave me this Baykunl D80 DRO (Digital Readout) he uses for a lathe/milling machine. The LCD stopped working, shows no image or color whatsoever, but the backlight works.
    When you power up, sometimes you can see a brief image but for like 1ms then it goes black. That kinda tells me the LCD is actually good and the issue lies elsewhere.
    The board has:
    • 1x ST STM32F103VET6 Micro-controller
    • 1x RAIO RA8876LN4 LCD controller
    • 1x Winbond W9864G6KH-6 SDRAM
    • 1x Winbond W25Q128JV Serial Flash Memory
    • 1x ATMEL ATMLH834 EEPROM
    • 3x Texas Instruments HC14 Hex Inverters
    • 1x AMS1117 3.3 Voltage Regulator
    • 1x PHOI 5 pin SMD, which is apparently a Texas Instruments TPS61040 boost converter for LCD and white led applications.
    • 1x IN6RL 5 pin SMD, marking unknown, can't find anything about this. It is related someway or another to the LCD flex connector connector.
    After visual inspection, nothing looks blown up, nothing burned, no discoloration, all traces look fine. Checked caps and diodes and transistors, no evident shorts. It uses a 104-240VAC to 5VDC 3A SMPS, which is working. The voltage regulator is outputting 3.3VDC, at lower side of the PCB near the LCD flex connector there are 3 test points for -7VDC, 10VDC and 16VDC, which i assume come from the LCD boost converter, and they are present, so the power supplies aren't the problem. For the time being i'm powering the device directly with my lab bench supply instead of the device's SMPS.
    I checked the board with a thermal camera while it was powered and nothing looks to be overheating. I checked the LCD controller, pins 93 to 96 which are clocks for LCD scan and V-sync/H-sync, and they are present so i guess it is working. Both micro-controller and LCD controller are oscillating at the correct frequency (8MHz and 10MHz) respectively. I checked all pins from the micro-controller and i read high and lows, but no clock or pulse waveform besides the XTAL waveform.
    It has a 5V buzzer that beeps as soon as it is powered up. Not exactly sure what it implies as i can't find the exact manual for this device, i'm assuming it beeps because i don't have the connections for the XYZ axis rulers. I de soldered it because the beeping was driving me crazy.
    The IN6RL SMD IC seems to be related to the LCD connector, de soldered it to check for shorts and it doesn't seem to be bad. Can't find any info about it online.
    At this point i'm not sure what else to check, any chance the micro-controller is bad? What else can i check to make sure that's the problem? Any help would be appreciated.
    Thanks in advance!
  • R_J
    • Jun 2012
    • 9672
    • Making Money
    The |N6RL is a MP3302DJ-LF-Z not sure what else to check as it could be anything, lost or corrupt program, check the reset circuit if it has one to make sure the micro is being reset properly
    • arkkkk
      • Dec 2025
      • 11
      • Venezuela
      Oh, it's a | not an I, thanks for that! Looks like this is the backlight driver... makes sense.
      I'll try checking again on monday, i left it at the shop and moved into something else for the time being.
      • huzo
        Dell 5590 no image on LCD,HDMI works ,the board works...
        by huzo
        The board is LA-F411P ,DELL 5590 ...
        The screen polarises,no backlight,no image,only black screen,tried another screen,the same,so there is no backlight,but there should be an image when i shine a lamp behind the screen,but there is none...only dark screen...when screen is connected and i press F8 to turn the image over to the external monitor, the external monitor gets coloured bars ,but when i disconnect the cable from the EDP ,the HDMI picture is good...What could be the problem? I don't have another edp cable, but i measured it with meter and it comes out good...i am baffled......
        02-16-2025, 03:08 PM
      • nicoar10
        HP DAG7HAMB8F0 rev F NO IMAGE/NO BACKLIGHT internal display but works HDMI
        by nicoar10
        Hello! In this case I have an HP with motherboard DAG7HAMB8F0 rev F. The laptop powers on and shows video on an external display, but not on the internal screen. There is no image / no backlight.
        I have checked and I do have 3.3 V at the display connector. There is also no short circuit at the display connector. I have checked the 3 V and backlight fuses and they are OK.
        What I can’t understand from this schematic is that I cannot find the backlight boost circuit. According to the schematic, this display works with the same VIN supply, which passes through a fuse and...
        12-18-2025, 10:22 AM
      • zaurus81
        Yashi All in one model AY62409 (Quantum S 24'') no image (backlight works)
        by zaurus81
        This chinese all in one computer gives an image when connected to an external vga monitor but only the backlight with integrated monitor (no image). Initially I thought it was an edid problem on the eeprom of the screen but then I saw that the monitor works correctly with another identical motherboard (model th410-d4, read by bios). Unfortunately the motherboard is chinese and has no brand or codes on the pcb. The format seems ITX. Nothing can be found online. The official yashi site provides drivers but not the bios. The electrical diagram is obviously unobtainable
        The board is equipped...
        01-16-2025, 03:54 AM
      • orgamisho
        Capture digital data between microcontroller and led driver
        by orgamisho
        Hello, I have a device which uses 3 7segment displays (4 digits each) controlled by a single led driver (TM1629A) which is controller by a microcontroller (MS51FB9AE).
        I want to capture the communication between the 2 ICs, so I can decode it and read it from PC with USB cable.
        The problem is that this task is slightly over my skills and I have no experience is such tasks.
        I would be grateful if somebody give a hint how can I read and decode the digital signals or share a source where I can educate myself on this matter.
        I have no idea what protocol is...
        11-10-2024, 02:42 AM
      • Boardview and Schematic Bot
        HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
        This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
        09-12-2024, 02:20 PM
