well PS3 problem , shutdown after around 40 min
  • highpulse
    i hate HP
    • May 2013
    • 1488
    • portugal
    didnt find any part relevant to consoles on the forum so i will post here .
    Got a ps3 that was reballed (first model with card reader and 4 usb's )after been reballed , i can play very well GTA5 for ex , with no problem i barelly hear the console passing level 3 of the fans , after around 40 min it simply shut down and red led stay flashing . if it would be warming issue shouldn't the fan been more radical to get it coller (for ex LEVEL 7 of fan speed)? well its anoying since i feel some hot air coming frmo inside but fan not passing or speeding up .
    any ideas guys ?
    thk in advance
  • xboxhaxorz
    • Jan 2011
    • 196
    Re: well PS3 problem , shutdown after around 40 min
    the cpu heat sink needs to be removed, the compound underneath is old
    • highpulse
      i hate HP
      • May 2013
      • 1488
      • portugal
      ok will do this to that one , also i think will do the same to my PS3 since mine was getting max level of fan when playing COD , and gpu was lifted the IHS and thermal past was applyed but still the same , so guess cpu is with same stress ,
      will remove it with the cut wire and will apllpy new termal.
      thk
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        So you reballed it but kept the old thermal paste, if it was overheating the fan would ramp sounds like somthing els !
        • Beowulf
          • Dec 2012
          • 175
          Try with a different power supply or open it and see if you have bulged caps.
          I found this thread here that has a similar problem and it was due to bulging caps on the power supply.
          http://advancedreworks.com/forum/sho...nutes-200.html
          • dj_ricoh
            • 2073
            • uk
            and lets not forget tokin capacitors.
            pff and how many are they in a ps3 and xbox
            • highpulse
              i hate HP
              • May 2013
              • 1488
              • portugal
              well , nop . like xbox mentioned , it was the thermal udner the cpu IHS that needed to be replaced , it was dry like a stone . after replacing it , i play for hours no problem .
              Indeed i made the same to mine , now i can play COD at total silent
              but now i got another issue ,
              GOT a ps3 i received few days ago , that client complain some time was not getting into the system . we cheked also that it was loosing hdmi signal and goes to AV without requestion , we have tryed the rebuild database , nothing sort it out , so we reinstalled the firmware , and all was good , we 'played the entire campaign of COD ghost , and always on hdmi and no problem , client took the console back to home saturday , and this morning he called me saying it it happening again (now he can access to the system , but it loose hdmi and goes to AV) this console never had any kid of internal repair , no reball or reflow , nothing , unless it was on another store and someone added the void stick again.
              opinions !?
