Re: PS3 Fat RLOD reflow and now overheating message
Glad to help, dont forget to put the ac socket first before assembling.
Good job, I learned some things tooLeave a comment:
Well, applied new Thermal Paste, assembled it just for testing, and
it turned without problems for about half an hour!
Now I see the way to close this console!
Gonna assemble it completly tomorrow and fire it up for a couple of hours and confirm that the repair is good.
Thanks to all who gave the precious inputs!Leave a comment:
cool! i will adopt your method for my next ones. the chip looks really intact, with a modified blade there always were scuffs and cuts.Leave a comment:
I'm back!
Well, started to figure how to get that CPU IHS out of there without damaging anything...
And after searching what I had at home, decided to go with ... a fishing line !
A good quality one, and ... it worked !
Just placed it on the corners and started working it arround like a chainsaw.
It starts slowly cutting the edges ... and even slower on the middle ...but it's safe and some minutes will do it!
Some pics are attached ... on the first one, we cant see it well, but its just two tools with the fishing line attached to permit to work it arround the IHS without hurting our hands
Now some cleaning, some good paste ... and ready to test!
I'll post back results!
Hope these results can help anyone with this problem!
CheersLast edited by magneh; 10-05-2014, 06:18 PM.Leave a comment:
Looks like Phenom II CPUs are soldered as well (http://forums.guru3d.com/showthread.php?t=294013)
That makes me happy, since that's what I run. So there should be no TIM to degrade\dry out.Leave a comment:
I've not dabbled in desktops for a good few years, but IME, most of the high-end C2D chips had the die soldered to the IHS. On the smaller, lower-performing ones however (particularly E2xxx series), there was thermal paste between IHS and die, and the IHS could be removed by using a sharp blade. I removed the IHS from an E2180 back in the day. Rumor has it it's the same with Ivy Bridge and Haswell too.Leave a comment:
Possibly the same with Haswell.Last edited by RJARRRPCGP; 10-04-2014, 04:16 PM.Leave a comment:
A bit OT, but you know, I've never even thought about there being TIM between IHS and the die... is that true on all CPUs? I guess it must be... and how long before it degrades and needs replacing?Leave a comment:
the cell be ihs is glued with soft silicon, you need to cut it in less than 1mm space without touching the chip, crazy thing. whatever you do, dont rush, even you havent cut 10% in 30minutes.
than apply quality thermal paste to the sole chip and try to fix it just for a try. dont worry, the 2 big screws will tight that securely.Leave a comment:
Its never too late The unique, I think you have all capabilities to do the nand/nor downgrade service. Start with the Teensy++ 2.0, which is a superb piece of hardware, costs just 24$ (half as a downgrade service) and if you are good enough with arduino programming you can make a decent programmer out of it.Leave a comment:
No offense taken senndogg, i don't do consoles and your theory makes sense. I'll let you handle this one.Leave a comment:
Nope, no heat for the cell be. just follow the tutorial like the one at bgamods, the one i linked you. NEVER use a razor or edge like knife. In contrary to the rsx, the cell be ihs is glued with soft silicon, you need to cut it in less than 1mm space without touching the chip, crazy thing. whatever you do, dont rush, even you havent cut 10% in 30minutes.
It doesnt start at full load.
So you recommend removing the other IHS and apply new paste right?
Gonna see that post and try to do it ... do you recommend applying heat during process?
CheersLeave a comment:
If you applied thermal paste enough and the fan is still kicking in loud then the issue is probably the thermal paste under processor CELL BE IHS.
Dont get me wrong The unique but this is typical if Fat Nand consoles. (In this case CECHC 4 usb and mem cards)Leave a comment:
Please dont touch components after trying this!
the PS3 rsx (gpu) and cell be (processor) uses these ugly ihs to dissepate. the problem of overheating lays under the ihs which is a pita to remove. i see you have managed somehow removing the gpu ihs. now, you need thermal paste, preferably as5 for the gpu chip and THERMAL GLUE for the ram chips.
If you jailbreaked your ps3, thats another story, you can show the temperatures using multiman and several othe homebrew softwares. In most cases you will notice that in fact its the CELL BE which overheats. removing the cell ihs requires maximum efforts http://bgamods.com/forum/viewtopic.p...it=ihs+removal
But now I'm in a dilemma.
First of all, the gpu ihs came allready like this when it came to me.
The PS didnt turn on, just blinked the red light.
I've reflowed GPU and now it turns on, but when on main screen to choose HDMI and video source, if I let it 2 mins without pressing any button, the fan starts to increase speed step by step, until overheating message.
Now that I've recieved some opinions regarding changing the NecTokin caps, I was going to do so.
Now that I've read your post, I'm kinda lost.
The PS isnt jailbreaked so I cant see which chip is getting overheating problems!
How can I proceed correctly from this point on?
Thanks for all your help!Leave a comment:
If you jailbreaked your ps3, thats another story, you can show the temperatures using multiman and several othe homebrew softwares. In most cases you will notice that in fact its the CELL BE which overheats. removing the cell ihs requires maximum efforts http://bgamods.com/forum/viewtopic.p...it=ihs+removalLeave a comment:
Or should I change 4 of them, 2 on top and 2 on bottom?
And then test it?
Gonna spend all tantalum caps in tha house!
Start at the GPU and then CPU with the NEC/TOKIN caps. I kinda doubt it is a bad thermal probe - otherwise it would display the overheating message from the start.Leave a comment:
It may be a shorted thermal probe, if it's the same type that many thermometers use. (open would cause a false 0 C reading)Leave a comment:
by rumpumpel1I have a T490 that displays the error message “2203: System configuration is invalid” immediately after the Lenovo logo every time it boots up.
This message must be acknowledged with 'Esc'. On the one hand, I cannot eliminate the problem, on the other hand, I have not observed any other restrictions.
Is it possible to change the BIOS so that this message no longer has to be acknowledged?
MTM 20N3S19L00
system SN PF1X4JP8
board SN L1HF171000X...-
Channel: BIOS Requests ONLY!
by Olvin1Hello everyone,
I’m kindly asking for help and advice regarding a reflow procedure for my laptop — Acer Nitro 5 AN517-52, which is equipped with an Intel Core i7-10750H processor.
I own an ACHI IR 6500 infrared rework station and would greatly appreciate:
• A detailed temperature profile for reflowing this specific CPU
• Step-by-step guidance for a safe and effective reflow process
• Tips on what to watch out for during the procedure
If the reflow doesn’t resolve the issue, I’m also considering BGA reballing of...08-01-2025, 01:59 PM -
by tony359Hello all,
I am experimenting a bit with reflowing larger components - ideally I'd like to reflow a PS4 APU or a GPU for example.
I know it's impossible to reflow such large components with just hot air so I bought a pre-heating plate, T-8280 classic Chinese machine, which seems to be working fine besides it's a little slow, which shouldn't be a big deal.
Now, my hot air station is a Aoyue 852A++ and I feel it's a bit weak when used with larger nozzle. I tried reflowing a laptop chipset using one of those large, rectangular, nozzles and I failed miserably,... -
by VenDell Latitude 3510 (Intel Core i7-10510U) CPU Overheating
Issue Description:- CPU Overheating to 100°C
- When I start the laptop from a cold state, it takes about a minute to reach temps around 80-90-100°C, and CPU thermal throttling triggers.
- When the CPU fan is running at full speed (by disconnecting PWM and TACH cables), CPU temperature stays around 50-60°C.
- However, when the fan is connected normally to the motherboard, it does not kick in at high temperatures.
- I also noticed a few times that the fan kicked in for a very short time, but it does not stay on consistently.
- Thermal
2 Photos - CPU Overheating to 100°C
by PrabuthThe customer gave me this for changing the old battery, and then I replaced the new battery. always showing this message. I changed many chargers and programmed the new BIOS as well. Does someone have any idea for this message?
... - Loading...
