PS3 Fat RLOD reflow and now overheating message
  • magneh
    • Apr 2014
    • 591
    • Portugal
    Hello!
    Got a PS3 with RLOD.
    Reflowed the gpu on my hot air station, and when I tested it it turned on.
    Conected it to my LCD and left it here for maybe ten minutes.
    As I dont have the controller, it sat there on the start screen.
    I noticed that the fan started jumping from different stages to full load, and then I got a overheating message and asking to turn off the PS.
    Whats the right approach here? Reballing the GPU?
    Or buying a new BGA ?
    Thanks for your thoughts!
    Re: PS3 Fat RLOD reflow and now overheating message
    Did you replace the thermal paste?
    • magneh
      • Apr 2014
      • 591
      • Portugal
      Hello!
      Thanks for the reply!
      Sure, cleaned all perfectly and replaced by new one.
      • magneh
        • Apr 2014
        • 591
        • Portugal
        No one with this issue on PS3 repair?
        Thanks in advance
        • mockingbird
          • Dec 2008
          • 5484
          Do you have Nec/Tokin Proadlizer capacitors on your PS3 motherboard? These need to be replaced with surface mount tantalum capacitors.
          • magneh
            • Apr 2014
            • 591
            • Portugal
            Hello!
            Gonna check that when I'm at the office.
            Could those capacitors be the responsible for the overheating message?
            Thanks in advance!
            • mockingbird
              • Dec 2008
              • 5484
              Yes.
              Please see this thread:
              https://www.badcaps.net/forum/showthread.php?t=8991
              • magneh
                • Apr 2014
                • 591
                • Portugal
                Hello!
                Just opened back the PS3 and looked for the "badcaps" NecTokin
                Found 8 of them (!) , 4 on each side of the board.
                Some pics are following.
                Should I change'm all?
                If I must do so , I need 32 (!) 330 uF 2.5V ??
                Or should I start by the 4 that feed the GPU and test?
                Thanks for any inputs to know the best approach to this issue!
                • RJARRRPCGP
                  • Jul 2004
                  • 6304
                  It may be a shorted thermal probe, if it's the same type that many thermometers use. (open would cause a false 0 C reading)
                  ASRock B550 PG Velocita
                  Ryzen 9 "Vermeer" 5900X
                  Arc A770 16 GB
                  eVGA Supernova G3 750W
                  Alienware AW3423DWF OLED
                  • Th3_uN1Qu3
                    Believe in
                    • Jul 2010
                    • 6031
                    • Romania
                    Start at the GPU and then CPU with the NEC/TOKIN caps. I kinda doubt it is a bad thermal probe - otherwise it would display the overheating message from the start.
                    A working TV? How boring!
                    • magneh
                      • Apr 2014
                      • 591
                      • Portugal
                      So I should change the 2 of the top of the board near the GPU?
                      Or should I change 4 of them, 2 on top and 2 on bottom?
                      And then test it?
                      Gonna spend all tantalum caps in tha house !
                      • senndogg
                        • Dec 2011
                        • 383
                        • Albania
                        Please dont touch components after trying this!
                        the PS3 rsx (gpu) and cell be (processor) uses these ugly ihs to dissepate. the problem of overheating lays under the ihs which is a pita to remove. i see you have managed somehow removing the gpu ihs. now, you need thermal paste, preferably as5 for the gpu chip and THERMAL GLUE for the ram chips.
                        If you jailbreaked your ps3, thats another story, you can show the temperatures using multiman and several othe homebrew softwares. In most cases you will notice that in fact its the CELL BE which overheats. removing the cell ihs requires maximum efforts http://bgamods.com/forum/viewtopic.p...it=ihs+removal
                        • magneh
                          • Apr 2014
                          • 591
                          • Portugal
                          Thanks for yur inputs Senndogg!
                          But now I'm in a dilemma.
                          First of all, the gpu ihs came allready like this when it came to me.
                          The PS didnt turn on, just blinked the red light.
                          I've reflowed GPU and now it turns on, but when on main screen to choose HDMI and video source, if I let it 2 mins without pressing any button, the fan starts to increase speed step by step, until overheating message.
                          Now that I've recieved some opinions regarding changing the NecTokin caps, I was going to do so.
                          Now that I've read your post, I'm kinda lost.
                          The PS isnt jailbreaked so I cant see which chip is getting overheating problems!
                          How can I proceed correctly from this point on?
                          Thanks for all your help!
                          • senndogg
                            • Dec 2011
                            • 383
                            • Albania
                            If you applied thermal paste enough and the fan is still kicking in loud then the issue is probably the thermal paste under processor CELL BE IHS.
                            Dont get me wrong The unique but this is typical if Fat Nand consoles. (In this case CECHC 4 usb and mem cards)
                            • magneh
                              • Apr 2014
                              • 591
                              • Portugal
                              The fan starts normally...and about 1 min after turning it on I can hear it going to stage 2-3 and finally maximum fan speed in about 2-3 minutes.
                              It doesnt start at full load.
                              So you recommend removing the other IHS and apply new paste right?
                              Gonna see that post and try to do it ... do you recommend applying heat during process?
                              Cheers
                              • senndogg
                                • Dec 2011
                                • 383
                                • Albania
                                Nope, no heat for the cell be. just follow the tutorial like the one at bgamods, the one i linked you. NEVER use a razor or edge like knife. In contrary to the rsx, the cell be ihs is glued with soft silicon, you need to cut it in less than 1mm space without touching the chip, crazy thing. whatever you do, dont rush, even you havent cut 10% in 30minutes.
                                than apply quality thermal paste to the sole chip and try to fix it just for a try. dont worry, the 2 big screws will tight that securely.
                                • Th3_uN1Qu3
                                  Believe in
                                  • Jul 2010
                                  • 6031
                                  • Romania
                                  No offense taken senndogg, i don't do consoles and your theory makes sense. I'll let you handle this one.
                                  • senndogg
                                    • Dec 2011
                                    • 383
                                    • Albania
                                    Its never too late The unique, I think you have all capabilities to do the nand/nor downgrade service. Start with the Teensy++ 2.0, which is a superb piece of hardware, costs just 24$ (half as a downgrade service) and if you are good enough with arduino programming you can make a decent programmer out of it.
                                    • RJARRRPCGP
                                      • Jul 2004
                                      • 6304
                                      Sounds like the issue Intel's Ivy Bridge processors have. If hot at stock or a little OC, then take the IHS off and replace the TIM under the IHS.
                                      Arc A770 16 GB
                                      • Agent24
                                        I see dead caps
                                        • Oct 2007
                                        • 4978
                                        • New Zealand
                                        A bit OT, but you know, I've never even thought about there being TIM between IHS and the die... is that true on all CPUs? I guess it must be... and how long before it degrades and needs replacing?
                                        -David VanHorn
                                        • rumpumpel1
                                          T490 error message 2203 Skip acknowledgement of an error message
                                          by rumpumpel1
                                          I have a T490 that displays the error message “2203: System configuration is invalid” immediately after the Lenovo logo every time it boots up.
                                          This message must be acknowledged with 'Esc'. On the one hand, I cannot eliminate the problem, on the other hand, I have not observed any other restrictions.
                                          Is it possible to change the BIOS so that this message no longer has to be acknowledged?
                                          MTM 20N3S19L00
                                          system SN PF1X4JP8
                                          board SN L1HF171000X...
                                          01-19-2025, 03:32 PM
                                        • Olvin1
                                          Acer nitro 5 an517-52 reflow/rebal CPU
                                          by Olvin1
                                          I’m kindly asking for help and advice regarding a reflow procedure for my laptop — Acer Nitro 5 AN517-52, which is equipped with an Intel Core i7-10750H processor.
                                          I own an ACHI IR 6500 infrared rework station and would greatly appreciate:
                                          • A detailed temperature profile for reflowing this specific CPU
                                          • Step-by-step guidance for a safe and effective reflow process
                                          • Tips on what to watch out for during the procedure
                                          If the reflow doesn’t resolve the issue, I’m also considering BGA reballing of...
                                          08-01-2025, 01:59 PM
                                        • tony359
                                          Reflow equipment
                                          by tony359
                                          Hello all,
                                          I am experimenting a bit with reflowing larger components - ideally I'd like to reflow a PS4 APU or a GPU for example.
                                          I know it's impossible to reflow such large components with just hot air so I bought a pre-heating plate, T-8280 classic Chinese machine, which seems to be working fine besides it's a little slow, which shouldn't be a big deal.
                                          Now, my hot air station is a Aoyue 852A++ and I feel it's a bit weak when used with larger nozzle. I tried reflowing a laptop chipset using one of those large, rectangular, nozzles and I failed miserably,...
                                          12-25-2021, 01:29 PM
                                        • Ven
                                          Dell Latitude 3510 Overheating & Fan Control Issue – Need Help
                                          by Ven
                                          Dell Latitude 3510 (Intel Core i7-10510U) CPU Overheating
                                          Issue Description:
                                          1. CPU Overheating to 100°C
                                            • When I start the laptop from a cold state, it takes about a minute to reach temps around 80-90-100°C, and CPU thermal throttling triggers.​
                                            • When the CPU fan is running at full speed (by disconnecting PWM and TACH cables), CPU temperature stays around 50-60°C.
                                            • However, when the fan is connected normally to the motherboard, it does not kick in at high temperatures.
                                            • I also noticed a few times that the fan kicked in for a very short time, but it does not stay on consistently.
                                            • Thermal
                                          02-12-2025, 03:57 PM
                                        • Mr_Nada
                                          Concerns before attempting a Reflow of Laptop's GPU
                                          by Mr_Nada
                                          I saw some posts at one point talking about doing a reflow but I couldn't find them again so I thought that I would post this here.
                                          I plan on reflowing the GPU of this old HP DV2500 laptop but I want to go over what I have and the steps I have to take to guarantee it will come out fine.
                                          I have a Yihua 8786D 2in1 Rework station, flux (just some paste that I got from an old Radioshack kit), a couple rolls of Kapton tape and a $15 Thermometer +probe (a TM902C from EMR shielding Solutions if its important).
                                          • The paper that came with the thermometer states that the probe
                                          10-10-2024, 02:53 AM
