how to prevent a connected charger from draining battery when not charging?
  • flat-earther
    • Dec 2022
    • 119
    • palestine
    I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
    So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
    but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
    So the battery is backfeeding the charger and being drained.
    How can I prevent the battery from being drained?
    Maybe some kind of diode between the charger and PCB?
    If not then is it possible to add a mosfet between the charger and the PCB, and somehow make the mosfet turn on while charging but then turn off otherwise so no current can flow from the battery to charger?
    I don't know if those ideas are possible because I'm not knowledgeable enough about electronics, what do you guys suggest?
    • 31063
    the BMS 3wire bit means a diode or fet wont work.
    maybe a tiny 2pole relay to only connect the board to the cells when it has 5v going in will be a good method.
    • flat-earther
      • Dec 2022
      • 119
      • palestine
      thanks stj,
      so two of these 5V relays would work? SRD-05VDC-SL-C https://www.aliexpress.com/item/1005007905038217.html
      is that the type of relay you mean?
      I'd have to see if there's room to fit those.
      I just wonder how other radios which have built in internal charging deal with not draining the battery? they don't have mechanical relays.
      • Unspun01
        • Jun 2011
        • 349
        The 3-wire battery management system uses B+ and B- with a common wire. Perhaps you only need to disconnect the common wire. If you mean to accomplish this with a relay, I think disconnecting the common wire when 5V not applied is simple to try.
          • 31063
          maybe the bms can be disabled,
          can you get a datasheet for the chip?
          • flat-earther
            • Dec 2022
            • 119
            • palestine
            Thanks, so I may try disconnecting the common wire and letting it sit and see if the battery still gets drained.
            • flat-earther
              • Dec 2022
              • 119
              • palestine
              What do you mean by disabling the BMS?
              The charging chip is marked IP2326 and I found a datasheet for it. https://www.chipsourcetek.com/DataSheet/IP2326_V1.2.pdf
              • lotas
                • Jan 2016
                • 4621
                • Russia
                BMS - Battery Management System.
                  • 31063
                  if the module lets you disconnect pins23 & 24 it will disable 3wire mode and not try to balance the cells
                  • flat-earther
                    • Dec 2022
                    • 119
                    • palestine
                    But I'm using a 2 cell battery, obviously I need to keep the balancing feature enabled.
                    Anyway I have removed the BM middle wire and left the battery connected to the radio for 23hours, at the start of the test the battery was at 7.27V, after 23h it's at 7.16V.
                    So the battery is still being drained even with the balancing wire disconnected.
                    So the only option is to install two of those relays right? one on B+ and one on B-
                      • 31063
                      you can get a relay with 2 sets of contacts in it.
                      • flat-earther
                        • Dec 2022
                        • 119
                        • palestine
                        can you share link of such 2 pole relay and I'll see if I can get any, otherwise I'll get those that I found, I think there's enough space to make two fit.
                        the relay I linked above was like the only 5V one I found and it's electromechanical which is what I should get right?
                        Since electromechanical physically disconnects the contacts, I can be sure the battery won't be drained.
                        There are also solid state relays, but I worry maybe they have some resistance even when off and can still drain battery?
                          • 31063
                          https://www.aliexpress.com/w/wholesa...pdt-relay.html
                          • flat-earther
                            • Dec 2022
                            • 119
                            • palestine
                            Thanks, that looks good HK19F-DC5V-SHG https://www.aliexpress.com/item/33007295607.html
                            I read somewhere about needing to add a diode on a relay coil.
                            is that so? do I also need to buy some diode?
                              • 31063
                              a 1N4148 diode will do it - they are used on just about everything so you can probably recover one from some junk.
                              they are only worth a couple of pennies btw.
                              • Bowline
                                by Bowline
                                06-11-2025, 10:13 AM
                                Bauer tool battery pack charging with a HERCULES charger modification
                                by sam_sam_sam
                                The Bauer power tool battery charger just has to many issues with the charger over heating because I several HERCULES Hercules battery chargers that are 3 amp charge and because they have gone on quite a few times over the years before they came out with the fan cooling battery charger I going to modify one so I can charge Bauer battery packs faster than the crape battery charger that they have
                                Here is how this modification is going to be done I taking a 1.5 amp hour battery enclosure and gutting it removing the battery cells and replacing some Ryobi 1.5 amp hour battery pack that...
                                05-06-2023, 12:17 PM
                                Milwaukee M18 HD12.0 (12 amp hour battery pack) unbalanced failure charger refusing
                                by sam_sam_sam
                                I have two Milwaukee 12 amp hours battery packs that have an issue with battery cells very unbalanced these are probably over 4 years old and been heavily used in the past but now get occasionally used heavily and when I went to use the grinder tool the battery lost battery battery power very quickly so I decided to open it up and found some battery cells voltage from 3.6 to 4.1 no wonder the battery charger was not fully charging them 3 out of 4 LEDs were on meaning that it was only 75% charged
                                So I have put them on the battery testing machine to drain each battery cell down to...
                                09-04-2022, 04:45 PM
                              • code share
                                Lenovo P43s won't boot with internal battery connected – looking for help diagnosing battery issue
                                by code share
                                I'm having an issue with my Lenovo ThinkPad P43s. The laptop does not power on when the internal battery is connected, but it works fine on AC power alone (battery disconnected). Once the battery is reconnected, the system becomes completely unresponsive — no lights, no fan spin, nothing.
                                Here's what I've tried so far:
                                • Power/EC reset (held power button for 60 seconds with battery and AC disconnected)
                                • Booted successfully on AC power only with the battery disconnected
                                • Visual inspection of the battery — no swelling, burn marks, or connector damage
                                • Battery
                                04-21-2025, 12:50 PM
                              • Thomasraud
                                Dell Vostro 3550 (v A01 with BQ24707) Plugged in, Not Charging
                                by Thomasraud
                                i have similar problem as https://www.badcaps.net/forum/showthread.php?t=37828
                                QUOTED
                                -It works on charger (without battery connected-only charger)
                                -It works on battery (without charger connected-only battery)
                                -& it also works when plugged in battery & charger, but it's not charging the battery
                                //Confirming, i have same issue, but problem started from charger, centre PIN is outputing 10V+ and jumping randomly 19V
                                and..
                                QUOTE
                                The IC cannot maintain the input current level
                                06-28-2022, 06:47 PM
