HELP!!!PS4 Component identification
  • ui5usnm
    • Apr 2025
    • Japan
    Hello, I need help with a ps4 SAB-001 board. I tried to look for schematic but I had no luck. Does anyone know what value they are around the syscon chip? It is something urgent.THANK YOU SO MUCH.
    Click image for larger version  Name:	无标题.png Views:	0 Size:	561.5 KB ID:	3620391
  • klynstronic
    • Jun 2022
    • 44
    • españa
    Hi, I hope this helps. Best regards
    • klynstronic
      • Jun 2022
      • 44
      • españa
      Regards.
      • ui5usnm
        • Apr 2025
        • Japan
        Still have no clue. But anyway thanks. If anyone know the exact value of these components please let me know. Thank you.
        • Shulgin
          Acer predator XB241YU Component identification
          by Shulgin
          I have a problem with my Acer predator XB241YU screen. When I plug it in, the startup LED turns on instantly, and I can't turn off the screen without unplugging it.
          After disassembly and inspection of the electronic cards I found what looks like a broken inductor, it is marked with the letter A and is at location L58.
          In the first photo you can see the broken component, in the second photo you can see where it is on the board, in the third photo you can see the silkscreen and in the fourth photo you can see the identification sticker of the main board
          I...
          05-11-2024, 11:06 AM
        • thebomb602
          ASUS GA402R IC identification
          by thebomb602
          Hey guys! my name is kyle, new to motherboard troubleshooting and a little confused still on chip identification if yall could help identify this chip..
          also if you could teach me how to fish on this particular topic... i did read through the ic identification sticky, and couldnt identify this with that info... thanks!
          EDIT, just realized thats a 5 and not an S in the first line... finding results for it now. cant figure out how to take down thread so im not embarrassed...
          11-21-2023, 02:30 PM
        • Tend0
          hp elitebook 840 G4 no 5v IC identification
          by Tend0
          Hello everythone
          i have on the bank hp elitebook 840 G4 6050a2854301 mb a01 missing 5V cause IC is damage on this board 5V and 3V IC is separatly
          i have 3V but no 5V i found 5V IC damage . i need our help to find IC identification, the 3v ic has mentionned ALVH 572 i found reference but no see something like IC . I poste the 3V here if someone have is reference. i don't found motherboard schematique or boardview...
          05-31-2025, 09:13 PM
        • Tomylee
          Identification of Component T5 on NEXIQ USB-Link 2 (damaged due to crushing)
          by Tomylee
          I'm currently repairing a NEXIQ USB-Link 2 that was physically damaged due to crushing. After a thorough inspection, it appears that only one component is visibly damaged: the T5 component, located right next to the Mini-USB port.
          It's a 4-pin SMD component, with one pin at each corner, aligned front-to-back along the USB port axis. Unfortunately, it is broken, and there are no visible markings left on the part to identify it.
          I'm looking for help with the following:
          The exact identification or part number of the T5 component
          05-28-2025, 12:42 PM
        • FrozenHaxor
          SOT23 component identification
          by FrozenHaxor
          Hello, I have two identical circuits and one has a component with a hole in it, it is some sort of MOSFET driver, as two gates of large MOSFETs are connected to the lower right pin of it, I'd rather avoid guesswork if positive identification is possible.
          04-09-2025, 03:17 AM
