Try our *UPDATED* boardview, bios, & schematic search. Over 2.3 million files for download!
Xbox one S - Dead or No Power
    No photos found.
  • User 4574
    Asus , board 532lws R1..3 Power rail 5v , 3v dsw
    by User 4574
    Hi everyone .
    I have model g712l And In stuck.
    Originally this laptop has a short on main Power rail . Thé main short is gone, i have found 2 pea16b mosfets Next to the SN51285ARUKR shorted , and the Chip Intself was Also shorted , i have removed them and main Power rail IS not shorted anymore , but right Now im still eating for this parts And in checking rest of the board . But pin 14 od the SN51285ARUKR when this chip od removed is shorted to ground Its +5VSUS has 6ohms , And that can not be , i have check mosfets All over the board And i have found ONLY one tahat ís shorted its...
    Bad cap
    0%
    0
    Shorted internal layer in thé motherboard
    0%
    0
    06-21-2026, 07:50 AM
  • k370
    Yoga3 Pro-1370 Board NM-A321 DEAD no power at all
    by k370
    I have a NM-A321 board that is dead, with no power at all.
    When I received the laptop, the +5VPMIC line was shorted. Removing the PU3 (ISL95905) solved the short, so I ordered and replaced the ISL.
    With the new ISL, the short is gone, but still no voltages at all. I measured the following rails:
    • +3VALW
    • +5VAUX
    • 1.2VSUS_PWRGD
    • 3VALW_PGD
    • 1.05VAUX_PWRGD
    Additionally, the ISL95906 (PU3) is not getting any voltage on the VIN rail.
    The only place on the board where I find any voltage is on the first MOSFETs, specifically:...
    09-23-2024, 11:57 AM
  • Destroyer-Br
    [HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
    by Destroyer-Br
    I'm working on an Acer Nitro 5 unit with the following specs:
    • Motherboard: LA-J871P Rev: 1B
    • Model: Acer AN515-55-59MT
    • S/N: NHQ7JAL00403906A973400
    • SNID: 03902728734
    Initial Issue
    The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
    After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled...
    04-17-2025, 08:18 PM
  • DavidChunco
    Lenovo NM-D031 board, no video, shuts down after 25s despite stable power rails, need bios rebuild
    by DavidChunco
    Hi, I have this machine on the work bench (Lenovo IdeaPad/NM-D031/GS454/GS554/GV450/GV550 board, no DGPU).
    I’m trying to diagnose a power-on issue and I would appreciate some guidance or a clean BIOS rebuild.
    • Board powers on correctly
    • All power rails remain stable
    • No video is ever produced
    • System always shuts down after ~20-25 seconds (very consistent timing) and requires full power cycle to restart.
    • BIOS was previously reflashed with a known-good image and cleaned ME region (when reflashing with clean ME region it power cycles several times but then shuts down and returns
    06-20-2026, 03:50 PM
