Read this: https://www.badcaps.net/forum/troubl...d-no-audio-fix
Original NES power issues
Yeah, but your second voltage wouldn’t be right. 9VAC x 1.414 = ~13VDC. If you put in 9VDC, then you have to subtract the bridge rectifier voltage drop and you get 8.3VDC. Look at the schematic, it needs 2 voltages, one 13VDC and a 5VDC from the 7805 regulator. That means you’d need a 14VDC PSU, not a 9VDC PSU. An AC voltage through a rectifier is always times 1.414 more on DC.Leave a comment:
Thanks for the response CapLeaker!
yeah there’s currently no cart in the machine so I’m not worrying about the 72pin (yet haha).
Up until now I’ve been using the original nes-002 AC power supply and a third party AC. Both rates at 9V 1.3a
The blinking light came on when I tried a 10V 700ma DC power supply (I would not use this long term as its lower a peerage and higher voltage than the NES spec.
on the 7805 I’m reading 8.3VDC on the in and 4.3VDC on the out when using the AC power supply.
using the DC power supply I get 9VDC in and 5VDC out.
No cassette = blinking red light
What PSU did you use now?Leave a comment:
Update: I tried a DC power supply and the red light started blinking (no game inserted) when powered on. Could this be a rectifier issue?
…this is beyond my knowledge and I’m learning of these components as I go, but I can probably handle the soldering if needed.Leave a comment:
Chit... wrong NES... hang on. You should have 2 voltages. 9VAC coming in, going through the bridge rectifier, then your get 13VDC and it goes to the 7805 regulator, 13VDC in and 5VDC out. Set your DMM to DC after the bridge rectifer!Last edited by CapLeaker; 11-28-2024, 02:26 PM.Leave a comment:
I recently turned on my old NES to find the red light won't go on at all. When powered on it shows black bars on the tv and a loud buzz through the tv speakers. Powering it off, the buzz goes away and tv goes back to normal (white snow).
I tested the power supply itself and it is outputting 9V as it should - first two solder joints on the board at the power port show the same.
Here's where it starts getting funky - When powered on, one side of the 7805 voltage regulator is showing 18V and the other is about 8.7V (center 0).
On the big blue connector I get 29V on the Brown (to power button) cable when it's off and 0V on the Red (power button return) cable. Pressing power on, the brown drops to 18V and the red goes up to 18v while the orange (voltage to reset button) goes from 0 to 8.7V, Yellow (power to LED) goes from 0 to 1.8V and the white (Reset button return) goes from 0 to 8.7V. If I hold down the reset button while it's powered on the Yellow (power to LED) goes up from 1.8V to 8.7V. I recall under normal operation the red led light goes off when you press the reset button which probably accounts for the increase in voltage from 1.8 to 8.7 there....
Both leads connected at the LED read 8.7V when powered on.
The 7805 should be dropping it down to 5V but I'm not seeing that anywhere. And I can't figure out where the 18V or 29V is coming from - so this doesn't seem right.
All of this was tested as AC on my multimeter as the power supply is a 9V AC power supply.
Any ideas?
One thing I can rule out is a dead LED as well. When I touch the two pins circled in yellow in the attached photo together the light goes on solid. The first circled pin is 8.7V second is 0vTags: None
by PantherDaveHi all!
https://www.badcaps.net/forum/troubl...-hardware-devi... -
by zlr8rhey guys, hoping for some pointers to repair an eBay bought "faulty" laptop.
Ill try and give as much info as I can.
Dell Inspiron 17 (7786) Laptop
Service Tag: 5J0NHT2
Bios: 1.9.0
When I received this , it would only flicker on the KB backlight for a second, then off and on.
Then it started getting weirder!
Sometimes when attaching the AC power supply, and pressing various pre-boot diagnostic keyboard keys... it did try to boot, in fact out of a hundred attempts, the laptop did actually boot into the Bios ! but never has... -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
by EazyBoneI got a qn65ls03ta from someone who stated shows no power at all. They said they bought a fully new tv (same one) and tested the one connect box from the old one onto the new one and said it worked.
I have no reason not to believe them, so I crack open the TV and test for voltages on the main board. There are none. I can't get any voltage at all. (Power comes from one connect to Main board then sends power to additional power board for backlights I believe)
While doing some digging I found the connection to the one connect cable ON the main board seems to be missing small... -
This specification for the HP Pavilion Power Pavilion Power 15-cb009nl Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 15-cb009nl boardview and Pavilion Power 15-cb009nl schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...09-06-2024, 05:59 AM
- Loading...
