Hi I'm a newbie when it comes to electronics. Does TSD127-B 20201226 have schematics?
TSD127-B 20201226 cable tracker schematics
by Patch2I have a broken connector (believe it's a 6 pin mini-DIN) on a cable. The metal shroud and all but one of the pins are separated from the cable, and just stuck together for the photo. The other end is an unknown rectangular connector. The cable is for the foot pedals on an Italian made electronic piano, and the company is out of business. Looking for ideas on how to fix it. I have a soldering iron, but I'm not very skilled at soldering, so getting a retrofit for the broken end may be beyond my ability. The other end would be easier to replace, if I could get a mini-DIN cable with the same number...8 Photos
by Lisa_kHi There
I am new to learning how to read schematics and have seen a few videos on the subject where people have spoken about how manuals have given reference resistance values but never really elaborated on how to check them.
I'm sorry if this has been asked before, I've made a search, perhaps I am using incorrect terms
I have a sony service manual with reference measurements, would I be right in thinking a measurement from pin 14 and pin 25 would get 1.4k?
by Tr0llHi guys! I realized you have a lot of knowledge here so i am hoping you could point me in right direction with my odd issue.
Original T-con:
First replacement T-con:
I thought it might be t-con and ordered new t-con from china(supposedly tested)... -
by fweoneaWhile at university, I connected my HP-Pavilion x360 14-dw0156ng laptop, running Windows 10, to a monitor using a provided USB-C cable. Immediately after this, my laptop's screen turned black and the device stopped working entirely. There are no signs of life such as fan noise or LED indicators, holding the power button does nothing. I've previously used this same monitor model and cable without issues, the cable typically charges the laptop as well.
I've attempted holding the power button for over 30 seconds, removing and reinserting the battery, and trying to power it on with only the...01-16-2024, 11:35 AM -
by marce002Hi all, please
I just want to make a "usb c" charging cable from 5V power supply (have cut cable w/ red black green and white pins connected from factory.... i just want to use 500mah max !
How do I connect this ? if I do not have CC1 /2 physically wired, how to proceed?
NOTE: an identical new (not cut) USB A to USB C cable charges my phone but not the remote control!
here is a picture of the remote, the cable to be used and a picture of what are the factory connected pins
thanks in advance!!
... - Loading...
