Canon VIXIA HF S10 A read data from inernal flash memory.
  • abajor
    • 175
    Hello I've had somebody bring in one of these charming little cameras to attempt retrieving data from the internal 32GB flash.
    Something is damaged inside the cameras lens assembly I can hear it clunking around and it has probably dislodged the sensor, powering up the camera gives a blank screen and the focus motor sounds like it's having a fit.
    The camera will not connect to a computer via USB in this state, I have no options no navigation, just power up and focus/zoom motor noises.
    I think my best shot is to figure out a way to read the internal flash memory outside of the camera.
    It has two flash modules on a small board with a Phison PS8005-A controller similar to many SD cards, and it interfaces with the main camera body via a flexi cable.
    I'm thinking best case is hacking into an SD card reader maybe a micro SD to full size SD adapter?
    Worst case would be solder the chips onto something else since there appears to be some epoxy like under fill like substance around the FLASH modules.
    Anybody here have any experience with such an operation?
    Attached are pictures of the Flash module.
  • mon2
    • Dec 2019
    • 13935
    you can review the assorted probing kits for sd cards on AliExpress :
    Just found this amazing item on AliExpress. Check it out! US $43.15 | Probe Data Recovery SD Memory Card Flyline PC3000FE Chip SSD Electronic Test Tool
    https://a.aliexpress.com/_mOPcQpq​
    • abajor
      • 175
      That's a pretty wild looking piece of kit, looks like you need to create your own interface for it at the through holes?
      I'll need to research those more, I was hoping I could just bodge into the pads, but it is pretty tight working space.
      • abajor
        • 175
        Some more info about the FLASH module I found on this pdf.
        • abajor
          • 175
          These guys have a site that appears to be dedicated to the topic of recovering data from flash drives.
          http://www.flash-extractor.com/
          • rogfanther
            • Jul 2006
            • 458
            • Brazil
            Have you searched for the datasheet of that Phison ontroller ? Maybe your module interfaces with the camera in a "common" way, and then you could, with luck, bodge something to connect it to a sdcard adapter.
            • abajor
              • 175
              Yes
              This is the only thing I've found. I have no idea why Phison doesn't make their device spec sheets available publicly.
              https://blog.stuffedcow.net/wp-conte...47.58_6635.pdf
              It may be the proper pin arrangement. I can't really verify whether or not the pin layout in the diagram is for a totally different package or someone taking artistic liberties. I suppose I can give this pin layout a shot and see if the Ribbon interface has continuity where expected.
              • abajor
                • 175
                I've traced out most of the pins based on what I believe is the proper layout of the Phison PS8005. Some of the pins are not visible as their VIA's are under the chip.
                Currently I need to Determine which is the CLK and CMD line. I'm going to make a guess that the CLK is the line the runs between the two ground wires, and Clock is the line next to data here is my pin layout based on the standard SD card layouts and the Phison Chip.
                • abajor
                  • 175
                  This looks pretty Nasty but it was a complete success!!!!
                  • rogfanther
                    • Jul 2006
                    • 458
                    • Brazil
                    Yahoo! congratulations !
                    • bamdad61
                      Canon DR-1210C flash dump request
                      by bamdad61
                      Dear folks, recently got a canon dr-1210c and it worked perfectly just for one day. Right now it shows all possible errors on the screen and do nothing. I tear down the device and found a 32 pin plcc flash chip. I thought reprogramming firmware might be helpful. The firmware update file from canon support include a dll file which doesn't help. So if anyone has the dump it would such a great favor to share.
                      04-15-2025, 02:43 PM
                    • ekozeko333
                      [Help] Lenovo Yoga Slim 7-14ARE05 (DA0LS3MBAF0) – 25Q80DVN1G Flash Is All FF, USB-C PD Stuck at 5V
                      by ekozeko333
                      I’m trying to recover a Lenovo Yoga Slim 7-14ARE05 with board DA0LS3MBAF0 Rev:F. I’ve run into an unusual issue where USB-C PD is stuck at 4.7–5V and the system won’t boot (keyboard lights flash briefly, then nothing).
                      🔥 The Problem Started After Suspected ESD/PD Fault
                      I experienced a power issue or ESD event through a USB-C charger
                      After that, the NX20P5090 power switch was visibly burned and was replaced
                      Now the PD controller always negotiates 5V @ 2A, even with known-good chargers
                      🧠 What I’ve Done So Far
                      Flashed...
                      06-21-2025, 02:48 AM
                    • corrize
                      Nikon D800 camera - flash don’t work and capacitor don’t charge
                      by corrize
                      Hello, I'm stuck in troubleshooting…
                      The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
                      In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
                      When I press the flash button, it's detected by the system, flash icon appear on LDC display....
                      10-01-2022, 10:02 AM
                    • liquidzorch
                      DSLR canon sl2 flash error 50
                      by liquidzorch
                      Hello. I repaired a canon sl2 for personal use, it had a bad sd card slot, bad battery connector, plus a little bit of water residue on the motherboard. The water damage seems to not have caused any damage, just salt deposits that have been cleaned. After repairing everything works except for the flash.
                      When shooting with the flash turned on, i get a "wait" message once, then on the second try I get an error: e50. I have disassembled the front to get a look at the flash board, and everything seems good, the flash board also controls the shutter, which works, so it does...
                      02-17-2021, 05:24 PM
                    • juergenb
                      Nescafe Aeroccino, still fails with new Motor (red flashes only once)
                      by juergenb
                      i am asking for some Help.
                      I have one of these Nescafe Aeroccino (Milk Frother) things with a bad motor.
                      The Motor didn´t start anymore and internet is full of users just swapping the motor for a Mabuchi RF-500TB-12560.
                      So i got a few of these from Banggood.
                      I swapped the motor and now i have a new fault condition.
                      In a working Frother you would press the start button, it will light red and work for a few minutes.
                      If you press longer it will light blue and just mixup the milk.
                      With the new Motor it just starts...
                      03-23-2021, 11:24 AM
