PS5 BLOD Long blu LED blinking
  • ryogadan78
    • Nov 2021
    • 66
    • Italia
    Hi guys,
    I have a PS5 with BLOD issue.
    I have checked some rail and found a lot of short circuit (see the image, red circle are short cricuit, others in the back side).
    There is something that I can check? It's definetely an APU problem?
    Thanks, Daniele
  • ryogadan78
    • Nov 2021
    • 66
    • Italia
    Sorry, measuring better I have these values that may not correspond to a short circuit. On the right rail I have 1.2 ohms , on the left rail I have 3.2 ohms
    • ryogadan78
      • Nov 2021
      • 66
      • Italia
      Hi guys. I put this Playstation 5 back on the workbench. I checked all the major voltages following the directions in TheCode3r video (https://www.youtube.com/watch?v=HXa2L8QxrQg&t=2072s), and they all seem to be correct (at least as far as TheCode3r says). I then took some thermal pictures of the mainboard, finding after a few minutes some hot spots, but perhaps not so abnormally, considering that the fan was not installed. I attach the images.
      Do you have any suggestions, any control procedures? I remember that PS5 remains constantly with the blue led flashing.
      I also attach the error logs taken with UART
ID:	3247744Click image for larger version
      • ryogadan78
        • Nov 2021
        • 66
        • Italia
        No help? I can try to reballing or change RAM, I would like to know whether you think this is the right way
        • 08caine15
          HP 14s-cf0057TU caps lock blinking 3 long and 2 short
          by 08caine15
          Hi everyone , I need your help with this board and it's giving me a hard time . 3 long and 2 shorts base on HP site it's a MEMORY ERROR , tried replacing RAM it's still the same. RAM VOLTAGE has 1.2V i think it has a complete voltage a 3.3v and there's also ah 2v , tried checking pins if there any damage or unsoldered and everythings good , now I don't what should I do next. Also tried reflashing and programming the bios and still the same, hopefully there's someone who can help me with this since im having like 4 laptop with the same error.
          10-03-2024, 02:23 AM
        • Charrlie
          Sharp Lc-70le734u blinking 2 long 5 short
          by Charrlie
          Just picked up this sharp tv not too long ago and it started not wanting to start the other day, giving me the notorious 2 long-5 short blink pattern indicating a power issue. I was able to force start it a handful of times (once the tv has fired up it has no issue running for 5+ hours). But now as of yesterday, no matter what I try to do button combination wise, I just receive the same blinking code.
          So I busted into it and have done the following:
          -Removed the power board and inspected for any bad caps, burn spots etc. Do not see any instances of such ...
          07-07-2022, 02:02 PM
        • seifaldenn
          LA-G07EP rev 2.0 i3 7th gen. light blinking 5 long 3 short
          by seifaldenn
          11-09-2022, 01:06 PM
        • cm0002
          Sharp LC-55N7000U 1 long 5 short blinking, no display
          by cm0002
          I've got a Sharp LC-55N7000U. It has a standbuy LED when plugged in, but powering it on causes it to blink 1 LONG and 5 FAST. Theres no display and no backlight.
          Nothing I checked has that blink pattern for Sharp TVs and there's only one multi-button on the TV itself so that service menu trick involving the input button doesn't work either. Its a post-Hisense buyout TV so that probably makes sense lol
          I've tried disconnecting the panel sides from the TCON alternating sides, but no change in behaviour even when the whole TCON is disconnected,...
          06-19-2023, 06:21 PM
        • rabsonnjala
          HP 250 G7 4 long 2 short blinking error
          by rabsonnjala
          Hallo,
          I have hp 250 g7 motherboard no: EPK LA-G07DP Rev 1.0. It powers on perfectly but when it tries to load the windows logo while booting, the keyboard starts blinking 4 long and 2 short error codes. i tried to reflash the bios with another file problem continues. Please help
          03-10-2022, 12:47 PM
