PS3 PSU (APS-231) Voltage mod
  • m111920
    • Nov 2013
    • 49
    • Croatia
    I have this PSU from old broken PS3, it's 23.5A +12V PSU, using it 3 months from now to run a car amp and it works perfectly, but it needs little more boost.
    I need help about mod, don't know where to start, which chip..which resistor??
    Any help will be appreciated
  • domas
    News Hater
    • May 2013
    • 323
    • Denmark
    Re: PS3 PSU (APS-231) Voltage mod
    there are 3 chips as i can see
    uc3854, LM339, cxa8038a
    not sure about last one but the controlling chip is uc3854. check it's datasheet. It is different from tl434, so you have to work on in yourself.
    • domas
      News Hater
      • May 2013
      • 323
      • Denmark
      https://cdn.badcaps-static.com/pdfs/...f943b9589e.pdf
      maybe pin 11(Vsense) but check what voltage do you have there when p/s is operating normally.
      And do this at your own risk as i am no expert.
      By the way by more boost you mean more voltage??
      • Behemot
        • 4845
        • CZ
        There is a couple of potentiometers, there is high probability one of them is for voltage tuning.
        • m111920
          • Nov 2013
          • 49
          • Croatia
          I think that too
          from datasheet: "VSENSE (Pin 11) (voltage amplifier inverting input): This is
          normally connected to a feedback network and to the
          boost converter output through a divider network"
          Cloud be it?
          Tried all of them, no-no
          • domas
            News Hater
            • May 2013
            • 323
            • Denmark
            well, as i mentioned i am no expert here. but try adding a trimpot there in series between pin11 and its circuitry on pcb, and set it to 0ohms when you power it up, and then carefully try to adjust the voltage - see if it increases. Remember, if you manage to break the feedback circuit somehow, the voltages will skyrocket unless there is an additional protection and blow some electrolytic caps on the output side ;-)
            • Khron
              • Sep 2006
              • 1350
              • Finland
              I would seriously recommend AGAINST messing around on the primary side of the circuit...
              A far better choice would be finding the TL431 that's hooked up to one of the optocouplers (which is responsible for the voltage regulation feedback) - i think i might've found it, but you'll have to confirm the markings. It might be one of the two small SOT23 3-pin IC401(?) or IC201, near the top left corner of the board, right on the left edge, "above" that 6.3mm or 8mm ChemiCon cap, and "facing" the bottom-most two of those four optocouplers.
              Just keep in mind, one of them may well be for the 5Vsb, and the other one for the 12v rail. If you can read the values of the 2-3 resistors connected to each of those 3-pin chips, that can easily be determined
              Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
              • domas
                News Hater
                • May 2013
                • 323
                • Denmark
                what? since when hacking feedback circuit is working on hot side??
                I just do not understand why playing with optocouplers is better idea than playing with the control chip itself.
                I am sure you have seen some examples of doing the same to TL494, where you add a trim pot on the first pin. I am trying to apply same practice to uc3854 which is similar chip to tl494, but not pin-to-pin compatible.
                The idea i am offering for him is reducing the Vsense input to the chip itself, thus UC chip will try to compensate for faked "missing" voltage, therefore increasing the voltage.
                • m111920
                  • Nov 2013
                  • 49
                  • Croatia
                  I've measured resistance between Vsense (11) pin and ground, it was 6.41k. then i added 100K pot in parallel, at the end, resistance was 6.30K and power supply didn't turn on.
                  • domas
                    News Hater
                    • May 2013
                    • 323
                    • Denmark
                    any damage to p/s?
                    what is the voltage on pin 11 when p/s is operating normally? To increase the voltage you probably should increase the resistance, therefore to connect something in series
                    • domas
                      News Hater
                      • May 2013
                      • 323
                      • Denmark
                      ok, now i just thought about what Khron666 had in mind...
                      As i looked to datasheet of UC chip again, it is a preregulator (APFC in atx terms i guess?), as in typical application note. The functionality is similar to pwm driver but it is not the same..
                      I guess there is another chip controlling the output. I doubt that only UC chip is responsible for both preregulation and output voltage. As i check the nets, it most likely is cxa8038a, but there is no datasheet for it.
                      • Khron
                        • Sep 2006
                        • 1350
                        • Finland
                        I believe the method i recommended was the safest, and the one with the greatest chances of success. Adding to that the lack of a datasheet for that CXA8038A, it's starting to seem like the only way
                        Then again, i've found 2 pages (with not much on them) for a CXA8038P:
                        And yes, it seems that UC3854 is "just" the APFC controller (not "just" in ATX terms ).
                        In the first picture from the first post, i can read "12V REG" right next to optocoupler PH301 - see if any of its two leads from the secondary side go to IC401(?) or IC201, then see what resistors are connected to that one - one will have one end going to the +12v rail, and the other one will have one end going to ground; the two remaining resistor ends should be joined together, and going to one of the pins on IC401 or IC201, whichever's responsible for regulating the 12v rail.
                        • domas
                          News Hater
                          • May 2013
                          • 323
                          • Denmark
                          nice job with finding the datasheet, it seems that pinout is what we need.
                          according to datasheet it looks like it should be pin 4, but i am not too sure about it.
                          m111 please check how much voltage in relation to GND and pin 16 do you have on that pin 4 when p/s is operating normally.
                          I am just unsure why do we have an octocoupler on 12v reg., from my experience feedback circuit is just a resistor going from 12v line
                          • m111920
                            • Nov 2013
                            • 49
                            • Croatia
                            i will check today,im busy right now,sent this from cellphone
                            • Khron
                              • Sep 2006
                              • 1350
                              • Finland
                              Well, don't take this the wrong way, but that means your experience is a bit "insufficient". I'd say 9 times out of 10, in an off-line (ie. line-powered, isolated) REGULATED switching power supply, the feedback to the PWM controller (especially when it's on the primary side) is done with the help of a TL431 (or similar) chip.
                              True, there's a resistor coming from the regulated rail in series with the diode in the optocoupler, but between the diode and ground, there's a TL431
                              • domas
                                News Hater
                                • May 2013
                                • 323
                                • Denmark
                                I don't, no worries here, the knowledge definately is insufficient. Well thats getting offtopic, but by saying line regulated/off-line do you mean that the P/S does not have a standby transformer? Or i still misunderstand the conception? Because the particular p/s has 5Vsb.
                                I will have to do some reading later tonight anyway, i have some documents about topologies, i can maybe go through those. Well thats not what this thread is about
                                • Khron
                                  • Sep 2006
                                  • 1350
                                  • Finland
                                  "Off-line" = line-powered, from 110/120/220/230V AC, as in 'NOT a DC-input SMPS'
                                  Regulated = has feedback from the output (if the controller is on the primary side, it's gonna have at least ONE optocoupler)
                                  Non-regulated = i know my definition's not entirely accurate, but that's what i call the ones that only have feedback from the auxiliary winding on the primary (that's also supplying the PWM chip)
                                  Either way, especially since there's something that may well be a TL431-type part near that group of optocouplers, plus the lack of information about the PWM chip, i still maintain that the safest, most "certain" and most likely to work method of modifying the output voltage of this particular PSU is to alter the feedback. And to that, i can add my reservations about poking around the primary side of an SMPS
                                  Call me weird, but isn't it easier (not to mention safer - 230VAC and/or 320-385VDC isn't fun to mess around with) to try something that's safer and more likely to work, than to just try semi-random stuff, "in the dark"?
                                  • m111920
                                    • Nov 2013
                                    • 49
                                    • Croatia
                                    there is 0 ohm resistance between optocoupler's second pin and ic401 first pin
                                    • Khron
                                      • Sep 2006
                                      • 1350
                                      • Finland
                                      IC401 - marking L287 = TS2431
                                      https://cdn.badcaps-static.com/pdfs/...72f58e3dcc.pdf
                                      See what resistance value you can measure between pins 1 and 2, and then 3 and 2 (see datasheet in the link for pin numbering).
                                      To increase the output voltage, you'll need to decrease the resistance between pins 2 and 3 (formula in Figure 11 in datasheet).
                                      • m111920
                                        • Nov 2013
                                        • 49
                                        • Croatia
                                        there is 6.20K ohm between 1 and 2 and 800ohm between pins 2 and 3
                                        btw I just meant to do the same thing!
                                        • Fernon@Repair
                                          Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
                                          by Fernon@Repair
                                          i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
                                          VCCIO voltage ok
                                          VCCSA Voltage OK
                                          VCCPLL Voltage OK
                                          Ram Voltage ok
                                          RamVTT OK
                                          VPP 2.5 OK
                                          But No Core Voltage
                                          and i want to this vrm ic datasheet or pinout (ISL69269)
                                          anyone have this ic pinout voltages?...
                                          06-25-2025, 07:19 AM
                                          Trip light 2400 watt line conditioner bought used issue with low voltage oscillation going on between relays
                                          by sam_sam_sam
                                          I found two capacitors on the board and one of the leads on one capacitor had bad soldering joint and the other joint connections not much better and there were several soldering joints that way to much flux around the joint redid several of them
                                          The capacitors were a non brand that I did not recognize they got replaced and now it does not oscillating between relay but what concerns me a little bit is when the voltage is a little bit low the output voltage is around 130 volts and then drops down to 115 volts this happens around 105 to 108 volts if remember correctly
                                          Now...
                                          06-09-2024, 10:57 AM
                                        • electron_jj
                                          Panasonic TH-L42D25A checking the PSU output voltage
                                          by electron_jj
                                          Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
                                          I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
                                          08-29-2021, 08:13 AM
                                          ISL95831HRTZ ISL95831HRTZ-T ISL95831IRTZ ISL95831IRTZ-T Voltage Regulator Datasheet
                                          3+1 Voltage Regulator for IMVP-7/VR12 CPUs
                                          Compliant with IMVP-7/VR12, the ISL95831 provides a complete solution for microprocessor and graphic processor
                                          core power supply. It provides two Voltage Regulators (VRs) with three integrated gate drivers. The first VR can be
                                          configured as 3-, 2- or 1-phase VR while the second output is 1- phase VR, providing maximum flexibility. The two VRs share the
                                          serial control bus to communicate with the CPU and achieve lower cost and smaller board area compared with the two chip approach.
                                          Based on Intersil's Robust Ripple Regulator...
                                          11-05-2024, 03:24 PM
                                        • ruletero
                                          Acer a515-43 low battery charge voltage
                                          by ruletero
                                          Hi
                                          Acer A515-43
                                          LA-H801P
                                          Fail: Does not charge battery, has low voltaje on connector.
                                          Laptop didn't want to turn on, only charge led blinked.
                                          I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
                                          I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
                                          Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
                                          10-24-2022, 02:31 PM
