Xbox 360 bad laser?
    Xbox 360 bad laser?
    I'd like to know if I may have a case of a bad laser on an Xbox 360.
    The drive will read DVDs fine.
    Attempt to play a game and it will usually (98% of the time) read it as if it is a DVD. However it will work from time to time.
    Does it sound like the laser is bad?
  • cheapie
    null
    • Jul 2010
    • 849
    Re: Xbox 360 bad laser?
    I have a PlayStation(1) that has a similar problem - it launches the CD player instead of the game most of the time.
    • ben7
      Capaholic
      • Jan 2011
      • 4059
      If I recall correctly, they had some problems with the drives in Xboxes. I don't own one, and I hate violence games... LOL
      Muh-soggy-knee
      • newtothis
        • Mar 2013
        • 1556
        • england
        Tom yes they are notorious for having bad drives....
        if you change it beware... the firmware is written to the dvd drive memory and not the system, change it for the wrong one and you will either A) Get banned from xbox live or B) have your console shut completely down (yes this happens to stop people modifying the system.
          I am not intending to swap the drive, just the laser. Would that fix most of the problems with not reading game discs properly?
          • t.j.
            • Apr 2010
            • 383
            • canada
            they have 3 differ types for the fat360's make sure ya get correct one! the controller boards are married to system! i found it cheaper to get complete drive then laser assembly.
            • Andyd1970
              • Feb 2013
              • 374
              • united kingdom
              Hi Tom,
              Yes replacing the laser will fix your problem 100% the lasers on xbox are not great and similar to cheap caps! often fail, I have a customer whos laser has failed about 4 times!
              • Andyd1970
                • Feb 2013
                • 374
                • united kingdom
                Hi Tom,
                I can recommend a company on ebay called "Games Cavern" I have copied below the item number for one of there xbox lasers:
                270916124864
                You do need to check which one you have fitted. I have used them for loads of parts from xbox, PS3, iPhones, and iPads. Highly recommended company.
                • Elysarian
                  • Mar 2013
                  • 200
                  Had the same thing happen to our PS3...
                  We sold the fat (40GB) one and bought a new 120GB slim - buyer came back a week later because it would no longer play games.
                  Sony aren't microsoft though - new Bluray drive installed and problem solved
                    I bid on a Like New drive on eBay and won it for £10.50. I bought the exact same Toshiba Samsung drive. I tried it with the existing PCB and it did not work, as expected, although I had heard some advice saying it would only stop Xbox Live access, which I did not care about. I then tried with the old PCB and it works great. Yay.
                    I decided to swap the whole drive assembly because this Xbox was bought faulty; the guy had clearly put a big-ass CRT on top of it and bent the drive so it would not eject properly unless fiddled with. So I took the case off, and poked the drive up slightly; it worked. But I had to leave the whole plastic case off, which sucked.
                    Now I have put the case back on... and it looks like an Xbox 360 again.
                    Thanks all for help.
                    • luke10050
                      • Mar 2013
                      • 209
                      From my experience in xbox modding, you CANNOT EVER replace the drives circuit board (without flashing custom firmware) as the drive is linked to the system with a unique number.
                      Oh nevermind he probably modded the drive firmware or something, try playing a game
                        Plays games fine.
                        To be clear, I am using a new drive mechanism with my original PCB.
                        The encryption keys are stored on the flash memory, globbed in glue...
                        • Uranium-235
                          Comrade Glimmer
                          • Aug 2007
                          • 5042
                          • US
                          I recently ran into a young man of a customer of mine (his mother) who said his PS3 games no longer play. I'm going to try to clean the laser, if that does not work, there is a procedure to actually replace the BD laser assembly inside the bd drive. Assembly is like ~$25 new on ebay, seems rather easy to replace
                          • Elysarian
                            • Mar 2013
                            • 200
                            It's a fairly simple fix, took me about an hour to do on an older "fat" PS3.
                            I've not had a slim one apart yet so I can't comment there
                            I seem to recall that there are a couple of different BD drives used in PS3s though so make sure you order the right laser assembly.
                            • Uranium-235
                              Comrade Glimmer
                              • Aug 2007
                              • 5042
                              • US
                              I know, which is why hes taking it here for me to clean it first
                                master hoarder
                                • May 2008
                                • 12170
                                If you don't want to buy a new laser assembly and just want a quick temporary fix, you can also just fiddle with the pots on the old laser assembly and just bump up the current slightly. This will in turn burn out the laser quicker.... but who cares anyways when the laser is already on it's way out.
                                But again, this is for a temporary fix and nothing else.
                                • luke10050
                                  • Mar 2013
                                  • 209
                                  yeah i did that with a PS2, got it playing games a bit better but i need either a new drive or a new ps2... anyone got any ideas where to get a ps2 laser assembley?
                                  • Elysarian
                                    • Mar 2013
                                    • 200
                                    Probably as cheap to get a replacement console tbh - I'm seeing lasers for £20 on ebay, PS2 consoles for £25.
                                    Especially when you factor in the time taken to do the repair.
                                    • kc8adu
                                      • Nov 2003
                                      • 8832
                                      • U.S.A!
                                      if you need to swap the whole drive try jungleflasher.
                                      • RJARRRPCGP
                                        • Jul 2004
                                        • 6304
                                        And a damaged or dirty CD usually results in the message telling you to insert a PlayStation disc when one is already in the CD-ROM drive.
                                        ASRock B550 PG Velocita
                                        Ryzen 9 "Vermeer" 5900X
                                        Arc A770 16 GB
                                        eVGA Supernova G3 750W
                                        Alienware AW3423DWF OLED
                                          HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green EliteDesk 800 i5-7500 Specification for Upgrade or Repair
                                          This specification for the HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green boardview and EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
                                          09-12-2024, 02:00 PM
                                        • TMTGTR
                                          An Xbox One PSU Odyssey
                                          by TMTGTR
                                          Firstly I am not a tech. You guys may see mistakes or oversights in my methods so don't be bashful and feel free to post corrections/opinions.
                                          =>Background:
                                          I bought my son a used Xbox One original model: A12-220N1A Rev: 02 with original PSU & 2 controllers 7 years ago. I “modded” the unit placing a 4.5” 12V exhaust fan with a 9v wall wart adapter on top of the vent/fan of the unit. And plugged the Xbox PSU into a Tripplite LTR-600 voltage regulator. Also connected to the Tripplite are a 275w computer tower, an Xbox 360 PSU and a Westinghouse 52” LED TV. ...
                                          06-17-2022, 05:40 PM
                                          ACER Aspire Revo R3600 + 3D Game Pad Aspire 230 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Revo R3600 + 3D Game Pad can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Revo R3600 + 3D Game Pad boardview and Aspire Revo R3600 + 3D Game Pad schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                          09-12-2024, 03:28 PM
                                          ACER Aspire Revo R3600 + 3D Game Pad Aspire N270 Specification for Upgrade or Repair
                                        • Stevedb
                                          Boardview xbox 360 , xbox fat , xbox one x and xbox one s
                                          by Stevedb
                                          Hi all
                                          I will share the boardviews i found internet from the xbox 360 , xbox fat and xbox one x and xbox one s
                                          Pasw netcomchetumal.
                                          Enjoy it.
                                          Greetings Steve
                                          From Belgium...
                                          04-04-2023, 12:42 AM
