Kenwood Chef A901e
  • pborlace
    • Aug 2011
    Kenwood Chef A901e
    Hi
    I'm trying to restore a Kenwood Chef A901e, the one with the PCB motor controller but I'm struggling a bit with the correct wiring layout. I've replaced all the caps and triac plus the 56 Ohm resistor.
    If we look at the pcb from the top with the heatsink/triac to the right:
    Terminal 1: below 150nf cap
    Terminal 2: above and to left of 150nf cap
    Terminal 3: above and to right of 100nf cap
    Terminal 4: heatsink
    | have wired it up as follows:
    Terminal 1: blue from connector block and yellow from motor
    Terminal 2: brown from reset button
    Terminal 3: pink from motor
    Terminal 4: blue from motor
    I can't work out where the red from the motor should be connected, also some photos of pcb boards show a jumper wire from terminal 2 to 3 but some do not.
    Hope you can help and thank you very much for taking the time to look.
  • pborlace
    • Aug 2011
    Re: Kenwood Chef A901e
    All Fixed.
    • fancyorange
      • Oct 2018
      • australia
      hi pborlace, have you got the wiring layout or any service manual? i got the same machine(kenwood chef a901e) and it got an electronic shot during use and one of the 0.15 uF looks burned. i am going to change the capacitance. thanks.
      • RolandVossen
        Kenwood Chef KVC50 / KVL60 / KVC5000 / KVL6000 / KVL6030 / KVL6050 kitchen machine repair
        by RolandVossen
        I am attempting to repair a KVC50 kitchen machine. Problem is that speeds 1..5 on the speed dial do not work at all (motor is not engaged). The 'reverse' and 'slow' settings on the same dial however work properly. I removed the dial, its PCB components seems to be basic: a potentiometer, a microswitch, a couple of LEDs and a couple of SMD diodes or transistors. The dial has three cables with three connectors that hook up to the motor controller PCB. One connector (3 pins) for speed, one connector (5 pins) for the LEDs, and one connector (2 pins) for a safety switch that is...
        03-16-2024, 03:55 AM
      • juergenb
        Nescafe Aeroccino, still fails with new Motor (red flashes only once)
        by juergenb
        i am asking for some Help.
        I have one of these Nescafe Aeroccino (Milk Frother) things with a bad motor.
        The Motor didn“t start anymore and internet is full of users just swapping the motor for a Mabuchi RF-500TB-12560.
        So i got a few of these from Banggood.
        I swapped the motor and now i have a new fault condition.
        In a working Frother you would press the start button, it will light red and work for a few minutes.
        If you press longer it will light blue and just mixup the milk.
        With the new Motor it just starts...
        03-23-2021, 11:24 AM
      • sbt123
        charnwood w821 mini wood lathe motor problem
        by sbt123
        hi there,im having a look at repairing a wood lathe for my dad,(charnwood w821)the problem is when turning up the variable speed control,the motor starts to stop and start by itself,if i continue to turn up the speed it will trip the mcb in the consumer unit,there is also a slight smell of burning from the speed controll box.,Another strange symptom is the lathe can be unplugged from the mains after switching it off and the motor will spin a couple of times by itself,so far ive put a new speed controll potentiometer on and new motor brushes,ive also tested the motor windings and everything looks...
        10-27-2024, 03:43 AM
      • DrDos
        Kenwood KR-6030 vintage stereo ,Old Man Trying to Save a Buck
        by DrDos
        Hello all. I'll try to keep this short. I have no knowledge of electronics. I can use a multimeter and am familiar with caps to some extent. I bought a Kenwood KR-6030 vintage stereo. It need work and so I thought I would recap the thing since I get power to the on switch but nothing else is working. No lights, no sound and so forth. I went to Mouser to order caps and I find I am way over my head. I not only do not know the type of capacitors I need but Mouser and digikey do not accept Kenwood part numbers. I have the info such as 220uF 63v and such but no place to put it. I could buy a recap...
        08-08-2025, 03:16 AM
      • mikey5791
        Help identify this motor
        by mikey5791
        Hi all forum members,
        Found this unknown motor discarded in a junk yard and took home for learning experience. By the look of it, I suspect it is taken out from a type of air blower probably running on ac power. I used digital multimeter on ohm/resistance scale and it doesn't read anything on those 2 black wires. So, this motor is not shorted and should be good to run.
        Correct me if i am wrong on the initial test.
        Can anyone kindly advice on how to test run this motor based on visible external two black wires. Fyi, i don't see any marking on the motor body nor smell anything...
        11-24-2023, 07:54 PM
