Water in Nintendo DS
  • ingenio
    • Feb 2006
    Re: Water in Nintendo DS
    I'm new to this forum, just browsing really, but with all the tech savvy... I don't understand how DI water hasn't been mentioned in this thread.
    After a spill:
    1: Unplug and remove battery immediately.
    2: Let air-dry (a heating vent is effective).
    3: Soak/agitate in deionized water for about a hour. (NOT distilled, the real DI water.. available for about $30/gallon. Read handling instructions.)
    4: Let air-dry (a heating vent is effective).
    5: Violla!
    Using a hair dryer is a TERRIBLE idea because of the static electricity it produces. Not rinsing the board is a TERRIBLE idea because lone ions (usually calcium, magnesium, sodium) are then left to cause damage.
    Ryan
    • Chris1992
      • Apr 2005
      • 561
      Welcome to this forum, and where is deionized water available? $30/gallon is very expensive. BW, to all the other members, the DS doesn't work; haven't tried with a new battery tho.
      The great capacitor showdown!
      • cods69
        • Oct 2005
        • 92
        Originally posted by ingenio
        I don't understand how DI water hasn't been mentioned in this thread...........(NOT distilled, the real DI water.. available for about $30/gallon. Read handling instructions.)
        Good suggestion.
        The reason it has not been mentioned is more than likely availability.
        It's not the sort of thing I stock in my pantry. I look for these sorts of things when I go shopping too, so I know it's not all that common (here, anyway).
        • Rainbow
          • Aug 2005
          • 1375
          I've heard that isopropyl alcohol is also good.
          • tylerlough
            • Dec 2005
            • 96
            I found this over at tomshardware, this is the comments some smart people left about the oil cooled pc article. They talk about nonconductive liquids and oils.
              20 year old Kenmore refrigerator ice maker bad water valve coil took a crap
              by sam_sam_sam
              I got lucky that when I got home and was about to get some ice out of the ice dispenser I hear and see water running down the outside of the ice dispenser what the heck is going on here
              At first I thought that the ice dispenser mold was cracked so I brought a new ice maker because this one has been in there for about 10 years now
              Well I put the new one in and wait and I wait for the water valve to open and let water in no such luck well there is a way to check the function of the motor and the water valve on this ice maker just need a jumper wire “L” to...
              04-09-2023, 08:04 PM
            • Ugur87
              MacBook Air M4 A3240 Brand New Water Damage no Image
              by Ugur87
              I have a brand new 13.6-inch MacBook Air M4 that was only used for three days and now has water damage. A glass of water was spilled over it. I examined the motherboard and there was only water next to the display connector. I cleaned it with isopropanol and the components look clean. The MacBook obviously turns on and draws 20 volts from the power supply. The keyboard backlight comes on, but the display remains black. Where should I best start? Even when I shine a light on the display, I don't see any image. I have all the tools I need, including an infrared camera. Where should I best start?...
              08-28-2025, 01:09 PM
            • edugimeno
              Stagg sms12p audio amp has water damage
              by edugimeno
              Hi! My friend just brought this audio amplifier/speaker fro his music band saying they realized its got no sound. Led powers up but there no sound at all
              I opened it and found 3 board. 2 of them are for input plugs and potentiometers, and the other larger board has the amplifiers for 2 large speakers that it drives
              There's also a large toroid transformer that feeds a lower voltage to the first 2 boards and a larger voltaje (36x2 rectified close to 100v) to the power board. The power board has the plugs for both speakers
              There is only one signal wire connecting the first boards...
              05-24-2025, 06:00 AM
            • RetroComputingGrotto
              Water Damaged Toshiba 48L1435DB
              by RetroComputingGrotto
              I have a water damaged Toshiba TV that was hanging nicely on the wall then over the summer we had a new multi-million pound boiler system put in and right where this TV was hanging is a nice new pair of water pipes for the radiators...
              The TV hasnt been used for a fair few months but it was needed again the other day and needless to say, it didn't power on or show any signs of life (no standby LED etc). After checking the fuse in the plug (and that the socket it was plugged in to worked) I decided to get up some step ladders to take a closer look and low and behold! It looks like...
              10-07-2024, 08:23 AM
            • fab13
              Nintendo Switch lite shuts down after nintendo log and replaced M96T36o
              by fab13
              Hello everyone
              After checking the defective USB-C port and close to a short circuit on the M96T36 chip (8ohm) I have changed both components.
              I specify that there is no other short circuit or heating component(Vu thermal camera)
              First, the problem arises: Error 2101-0001 after the start-up screen ("Nintendo" logo), poor soldering.
              Secondly, I install a new M96T36 and the problem I have is a brief display of the "Nintendo" logo (no short circuit, no sure charge chip, no sure charge port, no sure charge management chip percentage)....
              08-23-2023, 10:54 AM
