PS4 CUH-1216B no USB power no 5V usb
  • moscast
    • Oct 2023
    • 37
    • ITALY
    Hi, I have a problem with ps4 sac-001 which doesn't get 5v. obviously in safe mode the USB controls don't work, the 5V doesn't arrive. However, I noticed that 5v reaches the chips near the ports (there are two D82044s) but they don't let it pass. I checked with a working PS4 and saw that those two chips are missing 3.3V on two pins. What can it be? Where do those chips get the 3.3v?
    Thank you
  • redbaron1007
    • Jun 2021
    • 107
    Re: PS4 CUH-1216B no USB power no 5V usb
    You most likely have a dead southbridge if you're not getting any voltage out of the ports.
    Does the system boot into the dashboard or are you stuck in safemode? If it is booting into the dashboard sometimes when the southbridge is shot it will give an error popup for either to much power on the usb ports or connected device couldn't be detected even when nothing is plugged in.
    I don't have a board in front of me, but if the board has a GL3520 on it that could also be the issue. It's the USB 3.0 hub controller for the board. If it is on the board there will be come capacitors you can check for shorts or you could just try swapping it out if you can get a replacement chip.
    I would start with the GL3520 first since it's the easier chip to work with. From my experience I've seen more southbridge issues than GL3520, but I live in an area where lightning strikes are not uncommon and southbridges are very sensitive to lightning surges.
    • ugamazing
      Best place to source RAM chips? 8GB 820-00850 boards to 16GB or 32GB
      by ugamazing
      I'm looking to upgrade several 8GB 820-00850 boards to 16GB or 32GB for personal use. I am curious what the best practice and process is for sourcing new replacement chips, and what vendor(s) you guys prefer? Another question is, how do I find compatible chips and their corresponding part/model numbers? For example, in the 820-00850 schematic, the DDR chip U2600 model listed (EDFB232A1MA) corresponds to 1x32GB chip. Of course, I would need 4x8GB chips to replace the 4x2GB chips currently on the board. How do I find compatible 8GB chips? Is it as simple as searching "BGA178 8GB 2133"...
      08-31-2022, 07:34 AM
    • feherhollo
      WSON8 NEW Bios Chips READ, ERROR, ETC.
      by feherhollo
      I asking for help on some new WSON8 256MB chips. Please share your experience. I faced error on some new chips on read, erase, write with different programmers. These new chips are not exist in any programmers database. (GD25B256D, XM25RH256, W25Q256JV so on.)
      I'm using RT809F V.5.0, EZP2023 Pro, CH341A Green
      For the exact experience with GD25B256DYIG is RT809F erase the chip under 33sec. This kind of 256MB chip normal erase time is 70-120sec so I think not all the partitions are erased. If I do blank check or reread the buffer says FFFFFF but when I write the correct...
      11-26-2023, 09:33 AM
    • piernov
      NVidia bumpgate
      by piernov
      Just archiving everything related to bumpgate since most stuff has disappeared from Google. Maybe people will finally take the time to read some of it and stop shouting "reflow gpu" at every occasion but rather try to understand what the real issue is…
      Interesting parts about the failure analysis are "Why Nvidia's chips are defective" and "Why Nvidia's duff chips are due to shoddy engineering"
      May complete this post at a later date with more details.
      Basically issue is a combination of thermal dissipation of the chip with hotspot,...
      03-27-2021, 10:34 AM
    • Prott
      [RoG Ally] Fault in one of the onboard RAM chips. Any way to diagnose which?
      by Prott
      Hello dear badcappers!
      The title pretty much says it all - do you, please, know if there's any way to troubleshoot which of the integrated RAM chips (LPDDR5X in this case) is faulty?
      Backstory:
      After replacing the 4 onboard (soldered) memory chips on a RoG Ally (4x4 GB to 4x8 GB) it got stuck on the RoG logo. I assume one of the chips is either not soldered properly or faulty. However after reflowing and replacing bunch of them I am still stuck at the same place.
      If there is a way to narrow down which memory module is faulty it would make my life much...
      06-03-2024, 12:05 PM
    • LukeDavis
      Is there a list of known dodgy ATI Radeon chips?
      by LukeDavis
      Hello again! (People are likely going to get tired of seeing posts from me lol)
      I'd like to try and compile a list of known bad AMD/ATI Chipsets and graphics processors.
      While I do not possess the knowledge of some of the brilliant minds on this forum, I can at least mention a few chips I've encountered as being troublesome.
      1. ATI 216-0752001 (RS880M/RX280M) found inside 2 HP laptops, one I've since deemed screwed, and swapped the board to an intel one, the other HP seems to be less hateful and runs fine.
      2. ATI Mobility Radeon X1600 and the...
      02-16-2024, 04:34 PM
