Xbox one 1540 not taking disc
  • gurj1979
    • 186
    My Xbox one has stopped taking discs. Sometimes it will trip the power supply and no orange light neither.
    If I'm lucky it will randomly take it after about 10 power reboots.
    I got a new drive, swapped over the board but same thing.
    So I swapped over the motor driver IC, but still same problem.
    Is this turning into a motherboard problem rather than the drive or PCB itself ?
    Help please.
    • 31010
    Re: Xbox one 1540 not taking disc
    sounds more like a psu issue
    • gurj1979
      • 186
      It works perfectly with the drive disconnected though.
      • gurj1979
        • 186
        I've also replaced the 4 caps inside the PSU, even though they weren't bulging.
          • 31010
          then i dont know, the motors are the only thing that will pull current.
          • gurj1979
            • 186
            If there's someone with Xbox electronic repair experience with this issue, please help. Daughter can't play her favourite Kinect game.
              • 31010
              your in u.k. - ask coder on his twitch livestream.
              https://www.twitch.tv/thecod3r2015
              • petehall347
                • Jan 2015
                • 4426
                • United Kingdom
                you could either test the supply or the motor or both ..
                • petehall347
                  • Jan 2015
                  • 4426
                  • United Kingdom
                  dont these ones need a reflow of some stuff ? its been a few years since i played with one .. still in bits after i fixed it .. cant remember what it was or not doing now . i do remember it doing something to the supply . might have even put new fets in it ..
                  • gurj1979
                    • 186
                    Looking at the schematics, it all leads back to the Southbridge chip, which aso handles the SMC.
                    I'll try reflow that when I get a chance.
                    • gurj1979
                      • 186
                      So I reballed the Southbridge, but did not resolve the issue.
                      What I found is that U5C2 is not getting ODD_3P3V_STBY_EN signal, or it's being pulled down. ODD_3P3V_STBY_EN is generated by the Southbridge.
                      Any idea's whats going on ?
                      • gurj1979
                        • 186
                        Ok another test. Unit off, disc half inserted, turn in unit with button and the drive takes the disc in, also ilejects when button is pressed.
                        BUT, if unit is already turned on and I try insert disc, it won't accept it.
                        I'm totally baffled.
                        Anyone else know how to fix this ?
                          • 31010
                          maybe the signals that show "tray" status arent right.
                          i know on the original xbox it had tray-open, tray-closed and maybe a disc signal so the computer knew when to read the drive
                          did you check the physical sensors that detect the disc and loader position?
                          • gurj1979
                            • 186
                            Yep, tried 2 drives, swapped over the married PCB. But same thing.
                            Opto sensors only work if I perform the procedure of half disc insert then power on. Otherwise they have no voltage.
                            • gurj1979
                              • 186
                              So I finally found a way of fixing the issue. It not ideal but works everytime for disc insert and eject.
                              U5C2 transistor wasn't giving output. So I bridged 2 pins together. Works a treat.
                              See the picture.
                              • miguelito10008000
                                • Sep 2023
                                • mexico
                                yo tuve el problema en one s solo que no tenia voltaje en 12.0 la solucion fue alimentar con otra slida de 12.0
                                • TMTGTR
                                  An Xbox One PSU Odyssey
                                  by TMTGTR
                                  Firstly I am not a tech. You guys may see mistakes or oversights in my methods so don't be bashful and feel free to post corrections/opinions.
                                  =>Background:
                                  I bought my son a used Xbox One original model: A12-220N1A Rev: 02 with original PSU & 2 controllers 7 years ago. I “modded” the unit placing a 4.5” 12V exhaust fan with a 9v wall wart adapter on top of the vent/fan of the unit. And plugged the Xbox PSU into a Tripplite LTR-600 voltage regulator. Also connected to the Tripplite are a 275w computer tower, an Xbox 360 PSU and a Westinghouse 52” LED TV. ...
                                  06-17-2022, 05:40 PM
                                • Junior††
                                  PS5 Disc Not Supported/ Disc Not Recognized Board Num: EDM-020
                                  by Junior††
                                  Good Afternoon fellas,
                                  Issue:
                                  Disc is showing as not supported when a disc is put in.
                                  Here's what I've done, you can skip this if you just wanna know the question:
                                  - replaced with a disc drive from a donor ps5 (honestly questionable if this is known to work)
                                  - reflowed the disc drive connector
                                  -reflowed the chip in question (shown on image)
                                  - I will say this console was very dusty so it's conceivable that it got so hot that it made the chip joints cold and potentially other things on the board
                                  Question:
                                  I...
                                  02-19-2025, 12:48 PM
                                  HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green EliteDesk 800 i5-7500 Specification for Upgrade or Repair
                                  This specification for the HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green boardview and EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
                                  09-12-2024, 02:00 PM
                                • Stevedb
                                  Boardview xbox 360 , xbox fat , xbox one x and xbox one s
                                  by Stevedb
                                  Hi all
                                  I will share the boardviews i found internet from the xbox 360 , xbox fat and xbox one x and xbox one s
                                  Pasw netcomchetumal.
                                  Enjoy it.
                                  Greetings Steve
                                  From Belgium...
                                  04-04-2023, 12:42 AM
                                • grimacelord
                                  Xbox One S - 12V Rail Short - Q9F1 Keeps Blowing
                                  by grimacelord
                                  Have an Xbox One S here that has a short on the 12V power rail. There is no power, beep, or partial fan spin when connecting power cable.
                                  After diagnosing with thermal camera, Q9F1 MOSFET (NTTFS4C50N) is getting hot. When I remove this MOSFET, the short on the 12V rail disappears.
                                  I first replaced Q9F1 with one from a donor board and then partially reassembled the Xbox to test. When I plugged the power cord in, I got a partial fan spin and I thought I had fixed it, but unfortunately, the Xbox still did not power on. So I then disassembled the Xbox...
                                  10-24-2024, 12:31 PM
