Delphi MT60 Car ECU low resistance CAN/L/H to GND
  • Gjackson
    • Aug 2021
    • 134
    • Malta
    I have a delphi MT60 car ECU which has no communication, dashboard fails to light up and so does the car. With all other devices unplugged and the ECU on my bench I powered it and tested the CAN lines, 2.5v solid on each with no activity seen on my scope. Resistance between CAN lines and ground Is 18k for both which is unusuall, I found some sources stating to reball a gate array IC found inside the ECU which I did but resistance didn't change.
    Any ideas? Thanks
  • Gjackson
    • Aug 2021
    • 134
    • Malta
    Re: Delphi MT60 Car ECU low resistance CAN/L/H to GND
    short update:
    I measured CAN to sensor GND and not body GND, could this be the reason why the resistance reads low? Also should I expect to see activity on CAN high/low with nothing else plugged into the ECU?
      • 31255
      forget the canbus, establish if it's dead by looking at the cpu for activity on it's lines
      • Gjackson
        • Aug 2021
        • 134
        • Malta
        I couldn't find any information about any ICs onboard. I've included a picture of the PCB, tried searching up the CPU but could only find a similiar tricore model by infineon which I think has differing pinouts
        datasheet: https://cdn.badcaps-static.com/pdfs/...5aac51b2ee.pdf
        The top left IC is the BGA gate array that I reflowed, the top right IC is a voltage regulator which I could find no information regarding pinouts again. and bottom right is some engine idle sensor.
        Most interesting of course are the top 3 chips, first step would be to make sure that CPU has core voltage but that's difficult to do without proper datasheets and I suspect it's present by the fact that both the CPU and Gate array heat up under my thermal camera to expected levels. How would I go about scoping the I/O pins for "normal" behaviour?
        Thanks again!
          • 31255
          just run a scope around it to see if it has pulsing lines anywhere and that the crystal is running
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8340
            If you want the can bus to come on on any module, you have to terminate it in order that it knows it’s on a network, or run the module in the can bus network. If that crystal isn’t going, nothing else will work either. You need to get the car and do your own diagnostics and not just get handed along a ecu with hear say saying: fix it!
            • Gjackson
              • Aug 2021
              • 134
              • Malta
              Good point!
              ECU's are especially difficult to diagnose without the actual vehicle, regarding the CAN bus I did terminate it with a 120ohm resistor at both ends but still saw no data being transmitted, probably because the ECU requires inputs to react. I'll check the crystal when I have time.
              Thank you.
              • cind12
                GTX 1080 TI Gigabyte Aorus low resistance on vmem
                by cind12
                Hi guys, i was wondering, i've got 9Ohms on Vmem, one of the mosfet was shortet to ground, so i've desoldered hi and low mosfets nad still low res, then i removed all of the memory chips, and the resistance is still low, so did you had maybe a card with that low res on memories, and the card was working fine ?
                Removed the U1866Q and still without result, i dont have thermal cam so can't see where is hot spot when incjeting voltage.
                The resistance on core is ok 0.1Ohm ((Power 0.8V when on)
                Resistance on 12V 4K ohms (Power present when on)
                Resistance on 12V PEX 4K ohms...
                12-08-2023, 09:09 AM
              • Stanley1843
                Screen Display Vertical Multicolor Lines
                by Stanley1843
                Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
                06-29-2024, 11:54 AM
              • Nagy Daniel
                Lowest possible resistance on laptop motherboard rail - Guide Table request
                by Nagy Daniel
                Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
                I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
                I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
                So, I generated a table with AI so I can...
                03-04-2025, 08:24 AM
              • ronaldopdias
                Acer Aspire 3 A314. Not Charging.
                by ronaldopdias
                Laptop Model: Acer Aspire 3 A314
                Motherboard Model: DA0Z8EMB8C0 - Model: Z8E
                Charging IC: BQ24780 which I have repalced.
                Issue Description:
                I'm experiencing an issue with the charging system on this laptop. The BQ24780 charging IC is not working as expected. The main problems are:
                1. ACDET is missing (0V):, Reading 0V on the ACDET pin.
                2. ACOK is not present (0V): Is missing as well.
                3. No SMBus signals (SDA and SCL are missing): The SDA and SCL signals for SMBus communication are not present. There is no clock (SCL) or data (SDA) activity on these lines.
                What I Have...
                12-19-2024, 04:15 AM
              • jeyoung12
                Samsung QN50Q60t lines on screen
                by jeyoung12
                Hi all
                I have lines on the screen...which is an age old problem that can be remedied by watching Youtube videos and getting out the tape.
                My issue (after successfully fixing a different sammy tv with a separate tcon board and isolating the side of the panel...):
                This tv has an integrated tcon...so it is a bit more confusing when trying to isolate the clocks.
                It has a c ribbon and i have taken each end out to see if that will isolate the lines. instead, it makes it much worse ALL over the tv!
                So....i don't know what end of the C ribbon to work with...
                02-26-2024, 10:38 AM
