PS4 Slim CUH-2016B no power, no standby light, dead PSU
  • dymardo
    • Feb 2021
    • 10
    • Spain
    Hey folks! First of all thanks for helping me with TV repairs a couple years ago.
    I got a Slim PS4 for 26€ that had no water damage and has never been opened. It won't turn on and doesn't display status light.
    PSU gives out near 0V on 5V rail and 0,08V on 12V rail (I shorted the two pins to turn it on).
    I may need to get a new multimeter since mine is not working all that well.
    I saw videos of mosfet replacements, but I want to detect the problem first before attempting anything else. I do easier stuff like Game Boy repairs, but I have a hot air station if needed.
    PD, the previous owner seemed to have removed the game by breaking the gear seal under the console, to eject the disc manually. I first thought it was a variable resistor to tune the laser.
    Thanks!
    • 31199
    Re: PS4 Slim CUH-2016B no power, no standby light, dead PSU
    start with pictures - it may be blown up or it may just need a cap
    cant tell without seeing it.
    • mecha1166
      QN750Q8FNBFXZA Service Error Codes Needed - Error code 1-3-1-2 ? Dead set, only blinking standby light in repeating sequence
      by mecha1166
      I am working on a QN750Q8FNBFXZA. Dead except the standby light. It blinks what appears to be 1 3 1 2. 1 long blink, pause, 3 short, pause, 1 long, pause, 2 short, pause, repeat. A service manual would be very helpful, or if anyone knows these error codes. Thanks!
      03-28-2024, 08:31 AM
    • esqmooo
      HP Elitebook 845 G8 dead, only caps lock flashing 7 times. Charging light always on
      by esqmooo
      Hello everyone.
      This is my development machine. I've been using it since two years and half without any problem except sometimes it wouldn't wake up from sleep.
      Lately the issue became more frequent and powering it up would take few seconds to show the POST screen.
      Then the computer refuses to power on at all. Now only the caps lock button flashes 7 times then stops. The charging light is always on whenever a power source is connected (battery or charger).
      I tried long pressing on the power button, after several seconds it would go off then when the button is released...
      03-11-2025, 03:57 PM
    • wushumike
      LG 65UB930T - Standby Light can trigger but TV dead
      by wushumike
      The problem: When remote controller is press, the TV seems to wake from standby light goes off; but there is no backlight, image and sound. The relay did click on.
      I have removed the power board to check. Using 2 x 10K resistor from 3.5V to PWR_ON AND DRV_ON, all the voltages is correct.
      The main board has a red LED and is lited, but the optic link does not light up.
      The Power board after sometime will start to blink x 5 interval.... I would assume this is to indicate DRV_On not working.
      Any expert here came across the same problem? I...
      03-27-2023, 09:46 AM
    • shagster
      TX-P50UT30B Dead - No Standby light.
      by shagster
      Hi, haven't been on the forum for a while. But I thought I'd ask here incase this has already been solved.
      Anyway, I have this Panasonic TX-P50UT30B. It's completely dead, no red standby light, nothing. I took off the back and had a look at the fuses. All of them are intact. No shorts when testing the mosfets of the Power supply either.
      And the capacitors look fine also.
      I'm guessing it's a main board issue. But I don't really know tbh. Maybe a corrupt firmware flash, dunno.
      02-27-2023, 10:07 AM
    • ChristianBr01
      LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
      by ChristianBr01
      I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
      The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
      What I already found is that the 12.8V are not an the connector to the main board connector to the power...
      04-23-2025, 01:48 AM
