Nintendo Switch emmc failure?
  • stormanimal83
    • May 2014
    • 74
    Hi folks...
    whats wrong with a switch charging (with original charger) only at 15v 470 to 500 mA... at PC it´s loading with 4.9V at 0.45 to 0.47 mA. I checked for shorts at M92, BQ an max IC... nothing seems to be wrong there... tried to connect with tegraRCMGUI but the computer is only recognising the console if the EMMC disconneted... if the nand is connected the computer sees nothing...
    can u help me out?
  • stormanimal83
    • May 2014
    • 74
    Re: Nintendo Switch emmc failure?
    ... fo anybody reading this, i didn´t know that but this behavior is normal cause the switch without emmc is automatically forced into rcm mode... thx thought could be something shorted
    • chickenhawk88
      • May 2024
      • 86
      • US
      there is nothing wrong with the charging as the original nintendo charges at 15v cause it used PD charging vs PC which only outputs 5v (standard charging). As far as the rcm mode, i believe you have a patched version of the switch.
      • privato89
        Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
        by privato89
        I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
        Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
        Let's begin:
        Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
        03-26-2024, 06:37 AM
      • Mikehandsdown
        Nintendo Switch Origional 'EMMC corrupted'
        by Mikehandsdown
        So, I've sent my Nintendo switch away for repair after it wouldn't switch on after leaving it for a few months. No life at all, not even a hit of it booting. I changed the battery but this did nothing.
        It is an early version of the switch and had been running custom software for most of its life.
        I've received feedback from the repair center, first they asked me if I was aware it was modified and then they followed up with 'unfortunately we cannot repair the original mainboard - emmc corrupt. We need to replace the mainboard - £250' I've gone back asking for more...
        10-24-2022, 06:59 AM
        Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
        This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
        09-06-2024, 05:30 AM
      • ReeceyBurger123
        Nintendo Switch EMMC Shorted Ceramic Capacitor Repair
        by ReeceyBurger123
        I had a switch come to me with no power. A short on the main power management Ic and the video output encoder. As I've repaired a few of these consoles with these two Ics faulty I swapped them expecting it to have made the fault go away. Unfortunately there was still a short circuit across these devices, turns out the EMMC board was the cause. I pulled the memory Ic off to still have a short…caused by a MLCC
        I did a YouTube video showing this, I lost the cap in question it stuck to my iron I'll update soon with its value
        https://youtu.be/cSR4B2DDfzg...
        12-05-2021, 03:50 AM
      • Tomylee
        No LCD image after connector replacement – lifted components and damaged resistor (Nintendo Switch Lite HDH-CPU-02)
        by Tomylee
        Sorry for the person who’s going to read all this !
        I'm on a Nintendo Switch Lite, motherboard HDH-CPU-02.
        While replacing the left joystick, I had to remove the motherboard to access the connector underneath. When I lifted the LCD connector latch, it broke (the plastic had become brittle over time), so I replaced the entire connector.
        During the desoldering of the LCD connector using hot air, three small components located just below the connector (likely 0402 capacitors) came off and remained stuck to the bottom of the...
        07-11-2025, 11:52 AM
