Hilti PD30 Laser Range meter Error 276
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    • Romania
    Good day folks.....wow, seems like forever since I posted anything here Still alive and well, thank you I guess you could say I've become more independent and able to work stuff out on my own. This one though goes way over my head and I doubt is fixable, but maybe some bright spark out there has an equally bright idea.
    So: my Hilti PD30 laser meter quit on me just the other day. It was working fine, I set it down for a while and when I tried using it again it gave me an E276 and wouldn't do anything else. I tried taking out the batteries, all that standard stuff but nothing changed. Absolutely no information online on what the error code even means either...
    True, I THINK it did suffer an impact from a falling spirit level at one point. As you can see, the LCD has a black spot on the right edge, so that may have ultimately knocked something else out of alignment. I inspected it under the magnifying glass as much as I could, but didn't spot anything.
    Another thing I noticed is that, initially after the impact, the meter did display its "regular" screen upon power-up - the error didn't show up until I actually tried to fire the laser. The laser would just flash briefly and THEN the error showed up. After removing the batteries, now the error shows up immediately at power up. This led me to believe something died in the optics part (though not necessarily related to the shock): photo transistor or laser diode.
    One thing I tried was powering the laser diode (which is the capsule sitting higher than the other two) directly with my power supply set to a low-ish voltage of 2.5v and around 300mA. It did come on, so I assume the diode is fine.
    Another theory is that one of the photo-transistors "went out", the board reads the current through them at start up, gets nothing in return (or an unacceptable value) and thus throws the error. No idea what them photo transistors are though. All I see is that the diode has 3 leads, the transistors have 2 leads, presumably the light itself acts as the "base". This also doesn't explain why it initially gave the error when the diode fired while now it does it immediately...
    Any two-cents would be appreciated
    Wattevah...
  • CapLeaker
    Leaking Member
    • 8193
    Re: Hilti PD30 Laser Range meter Error 276
    Did you check the interconnection sockets between the boards? Other than that there isn’t much in there like a laser level for example. The only other thing I can think of is that these laser emitter and receiver is knocked out of alignment, or as you said one being dead or giving the wrong information.
    My bet is the alignment / service is being done through software on this rig and there is nothing much you can do to fix it. Would be nice if it would be as easy as a cold solder joint somewhere.
    • Dannyx
      CertifiedAxhole
      • Aug 2016
      • 3912
      • Romania
      Yup, the contact pads are the first thing I had HOPED would be the issue, but they're pristine, at least as far as I can see. Maybe I'll try touching up the solder joints on the connector and the optics, though I doubt it will help. I WOULD try replacing the transistors, but I have no idea what they are and even if I did, it would probably knock the calibration way off with no way of adjusting it, so it seems I've reached a dead end, like it or not...
      Wattevah...
      • petehall347
        • Jan 2015
        • 4427
        • United Kingdom
        might have a cracked trace if its been dropped
        • diif
          • Feb 2014
          • 6978
          • England
          You seem to have a burnt resistor. Top row of components bottom right on the 2nd photo.
          • CapLeaker
            Leaking Member
            • 8193
            Looks like flux to me on that resistor? Like this?
            Maybe check the crystal out if it is swinging…. If not, it will render the board as dead.
            • petehall347
              • Jan 2015
              • 4427
              • United Kingdom
              If a fault code appears, short-press the Measure / Continuous measurement button to return to the measuring mode.Restart the product if the fault code does not disappear automatically
              • Dannyx
                CertifiedAxhole
                • Aug 2016
                • 3912
                • Romania
                Nope - no key gets it going unfortunately.
                The indentation in the regulator you circled is not a hole. I doubt such a low power device would have enough juice to physically destroy components anyway.
                Also, yes, that's flux residue...
                My old man also suggested something that didn't cross my mind: planned obsolescence: after a certain number of measurements/power cycles, the thing simply refuses to run and returns the mysterious error code, forcing you to get a new one. By the time this happens, it's already WAY past its support/warranty date.....
                Wattevah...
                • petehall347
                  • Jan 2015
                  • 4427
                  • United Kingdom
                  i found a list of codes but it doesn't go to 276 .email hilti .. they are apparently good at getting back to you .
                  • Dannyx
                    CertifiedAxhole
                    • Aug 2016
                    • 3912
                    • Romania
                    Yeah, but they'd probably just give me a generic reply like "send it in for repair". No brand in their right mind would point the customer towards a solution on their own
                    Wattevah...
                    • petehall347
                      • Jan 2015
                      • 4427
                      • United Kingdom
                      for fun lick your finger end and run it around the ic pins to see if gets anything going . if you can get it to power up narrow down the wet area and stick something like a 1 or 2 meg resistor there . have done this successfully with weird devices .
                      • CapLeaker
                        Leaking Member
                        • 8193
                        did you check that crystal?
                        • Dannyx
                          CertifiedAxhole
                          • Aug 2016
                          • 3912
                          • Romania
                          No scope sadly....unless I just go ahead and replace it blindly. Even so, if the crystal were bad, I doubt the tool would even power on, nevermind actually display anything, which it does.
                          Wattevah...
                          • CapLeaker
                            Leaking Member
                            • 8193
                            That sux.
                            • chth96
                              Is it possible to test small ceramic disc capacitor with analogue meter?
                              by chth96
                              I read EBOOK of Testing Electronic Component and found that
                              "In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
                              Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
                              It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
                              Is it really possible to test small ceramic disc capacitor with analogue...
                              03-09-2024, 10:03 PM
                            • marce002
                              Laser engraver diode burned?
                              by marce002
                              Hi all
                              I have 2 laser modules broken? (from engraver 100x100 cnc)
                              The electronics drivers are fine.
                              The diodes seem to be dead, both of them.
                              One is (electric) 15W and the small is 2.5W as in the picture.
                              Can I replace them by buying only the diode? Can you tell me which one to buy , i think they are 405nm and blue but do not know if can be replaced..and prices for them? I have already removed the 15w module as in the photo.
                              thanks in advance.
                              02-03-2023, 10:20 AM
                            • MalodicOne
                              macbook pro 820-02100 5v 0 amp
                              by MalodicOne
                              Unit came to me and customer said they spilled liquid on it. Opened unit and inspected board and saw no signs on liquid reaching the board. Plugged in amp meter and it pulled 20v and booted normally, i connected to internet and ran update on the OS. Came in the next day to test again to make sure unit was functional, now its stuck at 5v and 0 amps no power, no shorts found on so far.
                              Tested all CD3217 and RAA489900:
                              UF400
                              PP3v3_UPC0_LDO- 3.48v, .473 Diode
                              PP1v5_UPC0_LDO_CORE- 1.59v, .504 Diode
                              USBC0_CC1- 0v, .455 Diode
                              USBC0_CC2- 1.66v, .454 Diode...
                              07-25-2025, 10:49 AM
                            • asr
                              Finding replacement diode iPad Pro 3rd gen A1701
                              by asr
                              Hello, I am looking for help to replace a damaged diode. The tristar was replaced and a diode was damaged in the process. I have a picture of the diode but dont have an exact donor. I mostly have macbooks for donors and only a few ipad and iphone boards. Diode part number: DSF01S30SCAP
                              Im not sure where to find the ipad board number. Anybody have an idea where else this diode is used on other boards? Thanks....
                              07-09-2024, 06:24 PM
                            • unimatrix93
                              TV backlight zener diode
                              by unimatrix93
                              Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
                              So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
                              Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
                              The led strips has 9 6V leds.
                              02-10-2025, 12:13 PM
