skycaddie sx500 p8 diode
  • computerden
    • May 2022
    • 5
    • scotland
    Hey,
    Got a skycaddie sx500 here thats not charging, the charging port daughter board has several dead diodes labeled p8. none of them giving diode mode readings on or off board and all look a little dead.
    i have tried contacting skycaddie but we all know how that usualy goes. does anyone here happen to know suitable replacements
    they are 1mm*0.5mm
    part number - s12_FM_S5_SUB-PCB_V2.0
    • 31092
    Re: skycaddie sx500 p8 diode
    zener diodes
    voltage could be anything - if they arent shorted they shouldnt be causing problems
    • redwire
      • 3910
      post pics of them
      • Fontana
        BN44-00505A dead. Need to know voltages on output diodes (Samsung T22B300EW)
        by Fontana
        1. g´day! I have a samsung 22" tv monitor to fix. power supply model bn44-00505A. some stuff blown up on the primary, according to research something typical on this model. secondary seems ok. writings on the board say in outputs a5v (standby), b5v (switched) both on the lower 3 diodes on the picture, vamp and b13v (12.8v, both are the linked at the connector that goes to the main board) my question is, are both the upper diodes for 13v? I believe so but wanted to make sure before injecting voltage there to test. I injected 5v on the lower side and standby circuit is working fine
        2. if
        12-18-2023, 05:45 AM
      • tvguy12012012120
        by tvguy12012012120
        02-07-2025, 05:13 PM
      • caspian
        What Zener Diodes on a Linear Power Supply
        by caspian
        Dear members,
        I have a linear variable power supply with unknown brand name that I used for voltage injection.
        Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
        In addition, I discovered that its zener diodes are defective.
        I can replace the burned transistors.
        But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
        Therefore, I cannot replace the zener diodes.
        I do not want to test the zener diodes in a test circuit to discover their model or value.
        no schematics are available...
        05-26-2025, 12:38 PM
      • asr
        Finding replacement diode iPad Pro 3rd gen A1701
        by asr
        Hello, I am looking for help to replace a damaged diode. The tristar was replaced and a diode was damaged in the process. I have a picture of the diode but dont have an exact donor. I mostly have macbooks for donors and only a few ipad and iphone boards. Diode part number: DSF01S30SCAP
        Im not sure where to find the ipad board number. Anybody have an idea where else this diode is used on other boards? Thanks....
        07-09-2024, 06:24 PM
      • bgilmer
        Samsung TV UN55KS8000 dead - bad diode
        by bgilmer
        I wanted to post about my successful repair of a dead Samsung TV.
        Model: UN55KS8000
        Power Supply Circuit Board Number: BN44-00878A
        Part required: SB5150 Schottky diode 150V 5A
        Symptoms:
        Powered TV on with remote control. Briefly (less than one second), saw video, then TV went dark.
        - Not working at all
        - No red LED
        - No standby power
        - Will not power on
        Attempted reboot:
        - Initially unplugged TV for about 20 seconds and plugged it back in (This has fixed this TV in the past when it was unresponsive.) Did not...
        07-24-2022, 12:04 PM
