Ps5 version with disk version 1.1 everything seems to work normally but you can't update when installing it blocks at 99% without any error, any suggestions? I would appreciate it thanks
PS5 Wont update stuck 99%
by DynaxSCHi,
I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
The board is generally working now, all PCIe ports are working, Windows installs normally.
However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA... -
by MeraxesI have a Ps4 Slim, it works perfectly, I wanted to update to firmware v 10.1 and now it remains stuck at 53%, before it had version 6.50
Hdd is ok, it is tested with hdtune pro
The Blu-ray worked perfectly before the update
I tried several USB flash drives, no change
The wifi module was changed does the same
Can someone help me ? can the southbridge have problems? -
by FalukyAfter an update it stopped playing audio and video, I have reset it as it says in the manual and tried to reinstall the firmware over the internet but logging failed each time and I tried to download the firmware to install it by usb but it does not appear on the official page, could you help me? Since it would be a shame to have to get rid of him, European version Thank you very much
Best regards.
Anyone got their hands on firmware for Marantz SR5008 stuck in update loop-
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
by mnciks11Hello Guys
I need your help with a macbook touchbar stuck on the update
"a critical software update is required for your mac. connect to a network to install this update"
Im getting the above error and i can not continue at all, it keeps on going back there, i reinstalled iOS, I did the updates, but still looping back on that same error message
Please assist me guys im stuck now
Thank you... - Loading...
