PS5 BLOD- CFI-1115A Disc Version- Board= EDM-020
    replied
    Re: PS5 BLOD- CFI-1115A Disc Version- Board= EDM-020
    thats the address, not the data
  • TheWizard
    replied
    I was told that you scan down until the FFFFF HEX starts then you should not have any data after where the FFFFF HEX ends. But this so called known good has data before and after. I am using HEXHD. You using Text string or Hex Value for searching 001c?
    replied
    the dump i have shows interesting stuff starting at 001c:7200
  • TheWizard
    replied
    Okay well i will have a deeper look. Just didn't want to try and reinvent the wheel is we already had the knowledge. Thanks!
    replied
    your missing the point,
    your comparing them to find out what is different.
    because nobody knows - or they arent sharing what they have found.
    i have ONE CFI-1015 dump,
    thats all i can find online - nobody is sharing shit because the people doing comercial repairs probably think it's some type of asset.
    that or they are scared of sony.
  • TheWizard
    replied
    Originally posted by stj
    use a hex editor that can DIFF 2 binaries.
    maybe 010 editor or imhex
    https://www.sweetscape.com/download/010editor/
    https://github.com/WerWolv/ImHex
    Stj,
    I did use a hexeditor and compared the two binaries. But other than model and serial number. What else do i have to change before flashing the chip?
    replied
  • TheWizard
    replied
    Originally posted by lotas
    On PS4, this behavior was the same as you have on PS5 (not a working HDMI chip) and the set-top box did not boot to the end.
    Lotas,
    So you think i have a bad hdmi encoder chip?
  • TheWizard
    replied
    Okay i just was able to find the model through hex editor on both bin files. The known good is a CFI-1116B and my original is a CFI-1115A. I was told this BIN would work for my EDM-020 board though. Thoughts?
  • TheWizard
    replied
    Yeah i follow you. Is there any tips and tricks to working with HexEditor? I am not sure what i am looking for in the BIN.
    replied
    compare the 2 flashes for differences.
  • TheWizard
    replied
    Can you provide me a step by step walkthrough a bit? I have done this with Dell laptop BIOS's. The only main things to change in them BIN files are the Service Tag, Product Key, and MAC. I assume Sony has something similar? I have the W25Q16JV@SOIC8 backed up to BIN. What do i need to edit before flash. Those are the steps I am looking for. I am a noob with game console flashes.
  • lotas
    replied
    replied
    i dont know if it's just the dvd key and maybe a checksum.
    if you unplug the dvd you can flash the non-drive syscon firmware and it works
  • TheWizard
    replied
    Still battling this one. I have all the power rails. PS5 beeps, turns on. Pulsing blue light and no switch to white. But remains on. Thermal camera shows everything running at from 40-50 degrees celsius. APU , RAM, SSD, all warm. I have removed the BIOS chip and backed it up. My friend offered me to remove his bios chip from known good ps5 as well. Plan is to flash his known good bin to my chip. But what do i need to change in Hex Editor prior to flashing? We want to cross all our t's on this process. I need to know where to find the Model, Serial and any other relevant info that will need to be copied prior to flash. Any ideas?
  • TheWizard
    replied
    remove and dump the syscon flash,
    i'm sick of people asking for dumps so it's time to start creating a collection.
    Not even sure the flash i have on this chip was not previously corrupted.
  • TheWizard
    replied
    Anyone know what the full part number of this chip is? It is located right beside the buck controller. 1st pic shows buck controller to left and un-identified chip to the right. 2nd pic is un-identified chip zoomed in.
    replied
  • TheWizard
    replied
    Not able to find a short on this board. This is like a needle in a haystack without a schematic I did confirm no liquid metal spill. Re-applied liquid metal and and same issue.
  • TheWizard
    replied
    Update: Removed board and connected to DC power supply. Providing 12 volts and 1 amp current. Looks to be a small short somewhere. This should be fun to find. Haha
  • m1ch43lzm
    by m1ch43lzm
    05-12-2025, 08:37 PM
  • Junior††
    PS5 Disc Not Supported/ Disc Not Recognized Board Num: EDM-020
    by Junior††
    Good Afternoon fellas,
    Issue:
    Disc is showing as not supported when a disc is put in.
    Here's what I've done, you can skip this if you just wanna know the question:
    - replaced with a disc drive from a donor ps5 (honestly questionable if this is known to work)
    - reflowed the disc drive connector
    -reflowed the chip in question (shown on image)
    - I will say this console was very dusty so it's conceivable that it got so hot that it made the chip joints cold and potentially other things on the board
    Question:
    I...
    02-19-2025, 12:48 PM
  • Hakuu
    by Hakuu
    Hi There,
    More Details
    TV Model - LG OLED77G1PUA
    07-12-2023, 02:37 PM
  • jb_Bak
    by jb_Bak
    CN6401
    Pin 01 NC
    Pin 02 NC
    Pin 03 "BL_ON": 0V
    Pin 04 "N/C"
    Pin 05 "STBY 3.3V": 3.5V
    Pin 06 "GND": N/C
    Pin 07 "AC_OFF"...
    09-27-2021, 04:52 PM
