PS5 Firware needed please !!!!
  • simo
    • 27
    Hi guys, anyone ho have CFI-1002A firmware dump ?
    thx in advance
  • aktinson
    PS Lover
    • May 2023
    • 18
    • Bulgaria
    Re: PS5 Firware needed please !!!!
    same here, anyone?
    • aktinson
      PS Lover
      • May 2023
      • 18
      • Bulgaria
      what are you doing @simo tho?
      • ghssa
        • May 2023
        • hata
        hi
        • simo
          • 27
          Hi, Aktinson, i m an electronic repair tech, i work for my own, what about you Bro ?
            • 31086
            so you have an australian early console with a drive,
            did you dump the original flash to get the keys out?
            • simo
              • 27
              yes I did
                • 31086
                unfortunatly i only have 101 and 111 in my collection
                • vecihite
                  • Sep 2023
                  • turkey
                  do you have CFI-1008 or CFI-1008A firmware dump ?
                    • 31086
                    i dont
                    • Daniel Larsson
                      Firmware file for LG SK10Y Soundbar stuck in Please wait loop needed
                      by Daniel Larsson
                      My LG Soundbar, SK10Y, has somehow ended up in an endless "PLEASE WAIT" loop and I am now starting to suspect that the firmware is causing this, and I can't manage to connect via the app to push a new firmware in as it never really starts.
                      I can trick it to start via HDMI ARC and it actually starts up, flashes OPTICAL and then goes to ARC where the sound (including sub) is perfect, but the white led indicator keeps blinking and after 20 seconds it says "GOOD BYE" and shuts down.
                      During these seconds the function button is not working...
                      08-13-2025, 10:29 AM
                    • EduCabral
                      [Help Needed] Yatour YT-M06 (Pioneer 1) – Firmware or Schematic Request
                      by EduCabral
                      I'm currently working on reviving a Yatour YT-M06 CD Changer Emulator module for use with a Pioneer 1 interface (specifically with a DEH-P5950IB head unit).
                      While the unit is recognized as a CD changer, none of the USB, SD, or AUX features respond, which leads me to believe the firmware may be corrupted or incompatible.
                      🔧 Details:
                      • Model: YT-M06
                      • Interface: Pioneer 1
                      • MCU: Fujitsu MB89F202
                      • Goal: Find a valid .bin firmware file or memory dump from a working unit
                      I'm happy to attempt flashing, analyzing memory dumps, or doing hardware-level...
                      07-15-2025, 12:26 AM
                    • Daniel Larsson
                      Firmware file for Marantz NR1501 needed
                      by Daniel Larsson
                      I picked up a Marantz NR1501 that the seller said did not produce any audio, but was starting up just like normal. This was indeed the case and the hunt for damaged components started.
                      After confirming all voltages and replacing all caps on this godforsaken HDMI-board I finally got sound from the AUX input, but all digital inputs are still dead.
                      The service menu shows no DSP version so I desoldered IC1604 that should have the serial flash DSP firmware on it and made two dumps that turned out identical.
                      The content of these seems to be useless as far...
                      05-23-2025, 04:11 AM
                    • gkoukoul
                      TV Felix FXV-4221 - firmware needed
                      by gkoukoul
                      Hello!
                      I have a Felix TV that turns on, shows the "FELIX" logo then shows a "WISDOM SHARE" message and doesn't do or respond to anything else.
                      I'm assuming a firmware flash will fix it.
                      I can't find the firmware file though, anyone has it please?
                      11-12-2024, 12:02 PM
                    • Sam Scarbo
                      Blomberg DV17600W laundry dryer MCU firmware needed. Please help!
                      by Sam Scarbo
                      I'm helping my brother to fix his Blomberg laundry dryer. He called a repair guy to have a look and the repair guy said the control board is faulty. They said the replacement board costs $400. Too expensive! 😨 My brother asks me to take a look. He has checked the door switch and thermal fuse, etc., and those seems fine.
                      After plugged to mains, there is no display. There is just a clicking sound from the buzzer, like one click per second. No other response.
                      I suspect the firmware inside the MCU (ATMEGA64A) got corrupted. Can someone in this forum by any chance provide...
                      07-21-2024, 05:24 PM
