Nintendo Switch HAC-001 - No picture, momentary backlight
  • pozarek89
    • Jan 2023
    • 9
    • Poland
    Nintendo switch, board HAC-001. The back light comes on and then goes off. After the reset, you can see the backlight all the time, first brighter, then dimmer.
    The console came to replace the SD card slot because the customer burned it with a soldering iron and it was full of flux everywhere. By the way, he melted the blockade of one flex, but it is rather irrelevant. I am completely unfamiliar with this type of equipment but the replacement seemed simple.
    After desoldering the socket, I reassembled console to check if it starts, and it doesn't. It was working before, but not after the connector removal. I was looking for something in the circuit at the screen connector and measuring the resistance on one coil I found a short circuit. It seems suspicious to me because it is quite far from the place of soldering, besides I did not overdo it with the temperature (350 *C) and I made myself a protection of aluminum foil and Kapton tape around the connector, but I did not remove the emmc memory. Did I damage memory? Did I overheat something? Any suggestions?
  • pozarek89
    • Jan 2023
    • 9
    • Poland
    Re: Nintendo Switch HAC-001 - No picture, momentary backlight
    I did radical cleaning of the old flux after the customer from connectors and it works.
    • Exman
      • Feb 2023
      • 9
      • UAE
      Hi Posarek,
      So, the lcd connector was dirty and after cleaning it worked fine you mean ?
      • Natob82
        Micro Momentary Push Switch?
        by Natob82
        Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
        12-21-2022, 05:22 AM
        Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
        This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
        09-06-2024, 05:30 AM
      • taso
        N. Switch HAc-10, no resistance on usb C 6 & 19 pin (D+), console not charging
        by taso
        Hi everyone:
        Anybody know anything about a N.switch without resistance in 6 & 19 pin (D+) in USB C conector? This is a HAC-10 board, all conector pins al good. Console runs ok but charging in very very slow 005 mAp.
        Thx!!!...
        07-15-2025, 12:37 PM
      • tommy97
        Nintendo Switch Oled - Joy con charging
        by tommy97
        I'm having an issue with a Nintendo Switch OLED that suffered liquid damage. After a full cleanup and replacing the Joy-Con rails and joysticks, everything was working fine for about a week. However, now the Joy-Cons won't charge or connect again.
        I tested with a second set of Joy-Cons, and the issue persists. Measuring the voltage on the connector shows 3.7V instead of 5V, which I believe should be the correct value.
        Any insights or suggestions on what could be causing this?
        03-17-2025, 06:30 AM
      • nebulink
        Nintendo Switch-No Shorts and not charging
        by nebulink
        This is a strange one for me. I have a Nintendo switch that turned on initially. The BQ chip was getting very hot. I unplugged and tried a different battery in case there was a problem with them one that came with it. I was told that the battery had been swapped.
        After trying a new battery, the unit would not turn on.
        Ammeter shows 15v 0 amp draw.
        Tested around BG, P13 and M92. No shorts. Decided to swap out BG. Same result.
        Checked voltages around BG, M92 and Max 177050.
        Also checked Max 177621.
        Getting desperate, I changed M92. Nothing
        I changed...
        06-23-2024, 03:22 PM
