Xbox 360 reflow capacitor removal help
  • Batosai3591
    • Aug 2010
    I am about to reflow my xbox 360 and am unsure which caps I need to remove. I have a Xenon version mobo, please help? I really have no idea how to help you figure this out for me, lol. Sorry.
    http://www.360mods.net/index.php?fil...Forums&t=18080
    link related (its the mobo)
    Don't wanna bust no caps
  • Toasty
    • Jul 2007
    • 4171
    Re: Xbox 360 reflow capacitor removal help
    Why do you need to remove caps? Are you doing the "oven bake" reflow or the proper one with a hot air station?
    veritas odium parit
    • Batosai3591
      • Aug 2010
      I don't have a reflow station so I am forced to use my oven.
      • Toasty
        • Jul 2007
        • 4171
        Where are you located? Profile location is blank...?
        Find a reputable service center that does these for a fee with a guarantee. You're looking at around $100.
        -or-
        Purchase a hot air gun instead. There are several videos and instructions on how to do the reflow using them. Use heavy duty aluminum foil to shield everything but the chips.
        If you do the oven method, you risk damaging the board and components. The yellow(Fujitsu) caps would likely survive, but the others black-gold(Rubycon) and black-bronze(Nichicon) may pop. Timing and ~accurate~ temp are critical. Don't go by oven dial or oven thermometer. Electronic type with remote thermocouple probe and checked with boiling water for accuracy. Preheating the chips and surrounding board area with a hair dryer is recommended.
        Welcome to the forums!
        Toast
        veritas odium parit
        • Batosai3591
          • Aug 2010
          Thankyou for fast replies! I went by your recommendations and removed the Rubycon and Nichicon caps, leaving only the newer metal ones which replaced the Fuji's. I re-researched some different oven bake methods and found a few that had around the same temps/time's. I rounded to the closest 5 for temps as my oven only goes by 5's and did the average of the times. Reflowed it, let it cool, resoldered caps, put some good ol' AS5 on the chips, put it all back together and plugged it up. It worked! The second mobo I've successfully reflowed in my oven, lol.
          I have gone through 5 xbox's myself due to red ring and e74 and have repaired countless friends xbox's. Only oven baked 4. One of which works to this day, one lost like 12 caps to my oven, one just didn't work, and the one last night, which now works.
          Thankyou for the help Toasty and thankyou Badcaps for being what you are!
          • mockingbird
            • Dec 2008
            • 5488
            I just fixed a xenon RROD. I didn't reflow though, I did the clamp fix. I did have to reflow an nForce motherboard so I could jungleflash my drive.
            • Toasty
              • Jul 2007
              • 4171
              @ mockingbird: How did/do you figure going with the clamp fix vs. the reflow?
              @Batosai3591:
              >>I re-researched some different oven bake methods and found a few that had around the same temps/time's. I rounded to the closest 5 for temps as my oven only goes by 5's and did the average of the times.<<
              - Can you provide links to the best you found?
              - Time & temp you used?
              Longevity of the "oven bake" repair has always been questionable with me. From what you said, the odds are not in your favor...
              Have you done the DVD drive mod to prevent destruction of the game if the unit is moved while running?
              Toast
              veritas odium parit
                • 31301
                no reflow is reliable without flux, get a syringe(with needle) and some liquid flux.
                • MORETTIGIAN
                  by MORETTIGIAN
                  Title:
                  Description:
                  Procedure performed:
                  - Removed backplate
                  - Reapplied thermal compound
                  - Reassembled card
                  09-18-2025, 12:14 PM
                • Prolog
                  by Prolog
                  12-01-2024, 08:27 PM
                • burom
                  Xbox 360 Xenon Modern Capacitor Replacements
                  by burom
                  I found my old Xbox 360 in storage and opened it up to see if there was anything that broke since it was built in 2006 (launch era Xenon revision, never red ringed, never been serviced) and didn't want to find out by releasing magic smoke. Upon moving the dust bunnies out of the way I was greeted by a bunch of capacitors with crud coming out of the top; it doesn't seem to have leaked onto the board so at least I have that going for me.
                  I'm posting here because I want to try to source replacement caps myself from Mouser or Digikey instead of braving eBay or waiting for places to have...
                  06-07-2024, 05:10 PM
                • cybernet3000
                  Replacing capacitor in Original Xbox Foxlink Power Supply
                  by cybernet3000
                  Hello all,
                  Got a bit of a noob question - I have an original XBox revision 1.0 with a Foxlink FTPS-0001 Rev B psu. I've already removed the infamous clock capacitor and I'm planning on replacing the caps around the big heat sink (Thanks to everyone who contributed to that massive thread for pointing me in the right direction) but I also noticed on the PSU there's one large cap that seems to be bulging a little. It is cap C19 and from my googling I've been able to determine it's a 2200 uF 10 V capacitor.
                  My questions are:
                  1) Can I just replace this with any...
                  12-01-2021, 12:05 PM
                • Agent24
                  Dick Smith Q-1760 linear power supply filter capacitor question
                  by Agent24
                  I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
                  It has at least one problem.
                  The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
                  I have already ordered a replacement potentiometer, so that's not an issue.
                  Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
                  All are CapXon...
                  10-21-2025, 05:39 PM
