Hi... i need asrock fm2a58m-vg3+ bios .bin, please help
ASROCK fm2a58m-vg3+
Mọi khoản quyên góp cho badcaps đều được hoan nghênh, hãy nhấp vào liên kết này để quyên góp. Cảm ơn tất cả những người ủng hộ---------------------------------------------------------------------------------------------------------------------------------------------------------------- -
Re: ASROCK fm2a58m-vg3+
You didn`t say your board is R2.0 .Download the Instant flash bios version from the support site (R2.0 board) https://www.asrock.com/mb/amd/fm2a58m-vg3+%20r2.0/#BIOS and extract the zip folder
The bios is 8,196KB ,it should be 8,192KB ,it needs a 4KB part of it deleting. Open the bios with UEFITool ,right click on "AMI Aptio capsule" and select "Extract body" ,that will remove the 4KB leaving the proper size bios. It will be saved as a rom file, you can rename it to *.bin if you prefer.
UEFITool https://github.com/LongSoft/UEFITool..._A57_win32.zip
Hi SMDFlea
I need to flash a FM2A58M-VG3+ Rev 2.01, & i'm very confused 'cause Asrock does not mention in their webpages nothing about different revisions of their motherboards. Should i use your provided .rom?, or may i cut the FM2A58M-VG3+ R2.0 .rom and flash this mobo with the modified one?
Thx a lot for your valuable time.Comment
Hi SMDFlea
by macabookHello everyone,
🧩 Initial Issue- Board powers on (fans spin, keyboard lights up and can be adjusted, caps lock led lights), but no display or backlight
- External display (HDMI) shows
Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
by DynaxSCHi
I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6... -
by Vesko356First of all thanks to all of our members who have posted previously all methods posted here.
Operating system and OS version.If...-
by paulwalHi. I am not too up on installing BIOS so am looking for a little direction installing a BIOS update.
https://www.asrock.com/MB/AMD/AB350%...index.asp#BIOS
I have an ASROCK AB350 Pro4 that is running a P3.00 BIOS.
CPU is AMD Ryzen5 1500X which I believe is a "Summit Ridge."
Before I go ahead and update it to the latest version, I thought I would ask whether my plan is right to try and be sure I don't make a mess of things.
It appears that the latest BIOS for this chip is the 5.80; therefore I need to install (one at a time)…
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
- Loading...
