ASROCK fm2a58m-vg3+
  • tiric83
    • Sep 2022
    • malaysia
    ASROCK fm2a58m-vg3+
    Hi... i need asrock fm2a58m-vg3+ bios .bin, please help
  • hoaca388
    Badcaps
    • Jan 2022
    • 12368
    Re: ASROCK fm2a58m-vg3+
    Asrock fm2a58m-vg3+
    • tiric83
      • Sep 2022
      • malaysia
      thanks for reply.. is it for FM2A58M-VG3+ R2.0 , bios version P2.70?
        • 22035
        You didn`t say your board is R2.0 .Download the Instant flash bios version from the support site (R2.0 board) https://www.asrock.com/mb/amd/fm2a58m-vg3+%20r2.0/#BIOS and extract the zip folder
        The bios is 8,196KB ,it should be 8,192KB ,it needs a 4KB part of it deleting. Open the bios with UEFITool ,right click on "AMI Aptio capsule" and select "Extract body" ,that will remove the 4KB leaving the proper size bios. It will be saved as a rom file, you can rename it to *.bin if you prefer.
        UEFITool https://github.com/LongSoft/UEFITool..._A57_win32.zip
        • AvenocturnO
          • Jan 2023
          • 3
          • Argentina
          Hi SMDFlea
          I need to flash a FM2A58M-VG3+ Rev 2.01, & i'm very confused 'cause Asrock does not mention in their webpages nothing about different revisions of their motherboards. Should i use your provided .rom?, or may i cut the FM2A58M-VG3+ R2.0 .rom and flash this mobo with the modified one?
          Thx a lot for your valuable time.
            • 22035
            Originally posted by AvenocturnO
            Hi SMDFlea
            Try the R2.0 bios,but make a backup first.
            • AvenocturnO
              • Jan 2023
              • 3
              • Argentina
              I'm sorry, Master, didn't receive any notification about your answer. It worked, thx a lot!
              • macabook
                by macabook
                🧩 Initial Issue
                07-24-2025, 02:17 PM
              • gabrieljma1
                Request: Full BIOS dump for ASRock Z790-CX (DDR5)
                by gabrieljma1
                I’m looking for a full raw 16 MB BIOS dump for an ASRock Z790-CX (DDR5) motherboard.
                The board powers on (fans spin, RGB lights on, RAM LEDs active), but there is no display output and the VGA and BOOT LEDs stay lit.
                I’m using an Intel i9-14900KF CPU (14th gen), and it seems the BIOS version on my board doesn’t support it yet. I tried to flash the official ASRock BIOS file (renamed .ROM → .BIN) directly using my RT809H programmer, but it didn’t work — monitor stays on but with black screen, so I believe the ASRock update file is not a complete...
                10-08-2025, 03:32 PM
              • DynaxSC
                ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
                by DynaxSC
                Hi
                I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
                08-04-2025, 12:20 PM
              • pirati
                by pirati
                10-27-2025, 04:20 PM
              • Vesko356
                by Vesko356
                08-11-2023, 03:27 AM
