HP ProDesk 400 G6 Small Form Factor PC bios
  • seppthefrapp
    • Feb 2023
    • 3
    Re: HP ProDesk 400 G6 Small Form Factor PC bios
    This is the bios file?? Generated by using the bios update tool and saved on usb stick.
    • hoaca388
      Badcaps
      • Jan 2022
      • 11741
      Using a programmer for read your bios chip and post result here.
      • seppthefrapp
        • Feb 2023
        • 3
        Hey! Now i get it. Can you help?
        • hoaca388
          Badcaps
          • Jan 2022
          • 11741
          Use a programmer to read your bios chip, save the read file in *.bin or *.rom format, unlocking must be done on the locked bios file itself, don't try to post the unzipped file from HP support site it's not a complete bios file.
          • Aduff80
            • Apr 2023
            • United Kingdom
            Hi All, I'm glad I found this thread. I also have a (9AG50AV) prodesk g6 400 mini. It does not have the pswd jumper pins even though there is a pswd area there. My bios is password locked. Reading the replies. Do I need to physically take off the BIOS chip and put It into a circuit chip reader of some sort? Please let me know how to do this. TiA
            • narsil
              Enas
              • Dec 2017
              • 83
              • france
              #26
              Please help me to unlock this BIOS password please. Thanks
              HP ProDesk 400 G6
              • hardware1
                • Sep 2021
                • 2930
                • N/A
                #27
                HP ProDesk 400 G6
                Here's your Unlocked BIOS, in the first boot go to BIOS Menu and disable security options (Disable).
                If the Password still present, see if there is another chip (EC) and upload its content here, it could be 16MB or 32MB.
                all donations are welcome,
                • narsil
                  Enas
                  • Dec 2017
                  • 83
                  • france
                  #28
                  Thank you
                  He's working
                  • soup
                    • Jul 2023
                    • 9
                    • Netherlands
                    #29
                    What exact programmer have any of use used to extract the bios?
                    I see a lot of SOP 8 PIN tutorials with the CH341A but not a lot of regarding the SOP 16 PIN.
                    • hardware1
                      • Sep 2021
                      • 2930
                      • N/A
                      #30
                      CH341A can handle the SOP16 package, but you need a special adapter that convert from SOP16 to SOP8, search for it and will see.
                      Also you can solder the chip to the small board that came with the programmer, it has SOP16 footprint and 8 pins.
                      • soup
                        • Jul 2023
                        • 9
                        • Netherlands
                        #31
                        Thanks for clarifying, I tried looking for a SOP16 to SOP8 adapter but haven't found one. Also, I'd (if possible) rather use the clip method.
                        I ordered the kit https://www.amazon.nl/dp/B08HP4X326?...roduct_details and the following clip https://www.amazon.nl/dp/B099X51S1M?...roduct_details
                        Not sure if this is sufficient?
                        • hardware1
                          • Sep 2021
                          • 2930
                          • N/A
                          #32
                          The Adapter and the board are already within the kit. I don't prefer to use clip because it gives you errors most of the time.
                          • soup
                            • Jul 2023
                            • 9
                            • Netherlands
                            #33
                            I see. I'll give the 16 pin prong a chance and see if it works out.
                            Are you by any chance aware of what exact chip it runs?
                            I made a picture of the chip, but can't find a lot about it.
                            The Product No. of the 400 G6 I got is a 1C6Y8EA#ABH.
                            • hardware1
                              • Sep 2021
                              • 2930
                              • N/A
                              #34
                              From its number it should be (256Mbit/32MB, 3.3v). If your programmer can't detect it, you can choose "GD25Q256" and see if that will help or not.
                              • soup
                                • Jul 2023
                                • 9
                                • Netherlands
                                #35
                                So I just finished extracting the data.
                                Any chance you can have a look at it?
                                I have a spare 400 G6 But with slightly different mobo chip.
                                Any idea It's wise to copy it from the working (bios chip) one to the non-functional 400 g6?
                                Edit:
                                Check the other motherboard.
                                Both chips are the GigaDevice 25B256DF1G.
                                Only difference:
                                Non functional has the UE7712 / AH2025 under it and the functional one has UHK914 / AJ2204.
                                • hardware1
                                  • Sep 2021
                                  • 2930
                                  • N/A
                                  #36
                                  Edit:
                                  Only difference:
                                  Here's your New BIOS, try it and let me know.
                                  Serial Number: 8CC1123CN7.
                                  • soup
                                    • Jul 2023
                                    • 9
                                    • Netherlands
                                    #37
                                    Sorry for the late reply, I was waiting for a new ch341a to arrive.
                                    I ordered the new 1.7 version with the voltage selection. Weirdly enough i'm now unable to read it using the GD25Q256.
                                    It now autodetects the chip as AT24C01_7bits 3.3v 1 Kbits in size.
                                    • soup
                                      • Jul 2023
                                      • 9
                                      • Netherlands
                                      #38
                                      So I tried it again but on the xx25 pins, got detected and able to read from it.
                                      When I try to write you .bin it give me the follow https://i.imgur.com/ApkEZ9O.png.
                                      • hardware1
                                        • Sep 2021
                                        • 2930
                                        • N/A
                                        #39
                                        Why you didn't use the same Programmer that you have already used to read the file from post #35?
                                        I think if you want to use "CH341A v1.7", you will need to choose "CH341 Green" in NeoProgrammer.
                                        • soup
                                          • Jul 2023
                                          • 9
                                          • Netherlands
                                          #40
                                          After reading I had realized I had the CH341a version with the 5volt issue.
                                          Sadly the iron failed during soldering.
                                          I just finished writing the .bin you had provided but the mobo indicates a invalid firmware with 5 long beeps and 2 short.
