Need Schematic for STK1A32SC -- or ANY Atom x5-Z83xx-based System with AXP288 PMIC
  • starhawk
    • Apr 2014
    I have an Intel STK1A32SC Compute Stick... and a baaad case of The Stubborns somehow I always 'forget' until just after it's too late that (a) the slightest application of heat to the power button shorts it internally, permanently, rendering the system unbootable, and (b) removing the button entirely, being a tiny tiny tiny momentary 'tact' switch, and surface-mount to boot, invariably destroys the support circuit for it, immediately adjacent.
    Ooooops
    I can read datasheets and understand electronics reasonably well; the AXP288 is the PMIC -- power management IC that controls all the voltage rails in the system (and brings it up, and shuts it down, gracefully) -- for the Atom x5-z83xx series SoCs. The datasheet tells me that this is the chip that handles that button; however, the exact circuitry is in the hardware reference documentation, and that is not publicly available... too bad, because from what little I can tell here in the USA, Shenzhen X-Powers Corp that used to produce them, no longer is in operation. At the very least, their website doesn't work right for submitting documentation requests, I've tried
    I doubt that there are public schematics for the Intel STK1A32SC, or for any Intel Compute Stick; however, the knowledge I need will be the same, or at least in some reasonably valid form that I can use, in absolutely any system containing an Atom SoC of that series, paired with the AXP288 PMIC.
    Known makes and models that would fulfill my documentation needs:
    Intel STK1AW32SC Compute Stick
    MeeGoPad T05 Pro Stick PC
    MeeGoPad T09 MiniPC
    Sunchip Wintel CX-W8 Pro MiniPC
    Dell Wyse 3040 Thin Client (not the Dell Optiplex 3040, that's different!)
    Most "T5" stick PCs, most "z83" or similarly-named MiniPCs, and most Atom x5-z8350-based tablets, especially from eBay/Amazon 'disposable' brand names (you've never heard of them, they sound -- forgive me -- very much like a Chinese company, and they make you think someone somewhere said "well, we have to put some kind of branding on it!" at a management meeting, and whatever random thing they first came up with that seemed to sound good is what they went with) use exactly this specific combination of PMIC and SoC. Any of those will do as well... as will any laptop, tiny desktop (etc), or "detachable" from major manufacturers such as Lenovo, Acer, HP, etc, with the Atom x5-z83xx/AXP288 combination.
    ...a point of clarity regarding brand names...
    No disrespect meant towards the Chinese, just that from a Western cultural standpoint, the branding you guys come up with often seem kind of strange in a way that makes some of us giggle a bit. It's fine -- laughter is good for you Besides, it's a different way of doing things, and that's kind of cool. I appreciate that.
    • 22030
    Re: Need Schematic for STK1A32SC -- or ANY Atom x5-Z83xx-based System with AXP288 PMI
    The x5-z8350 is cherry trail.Is the AXP chip an AXP288 or AXP288C
    • starhawk
      • Apr 2014
      AXP288C. Apologies, I had classified that as a revision of the AXP288 because sometimes I'm dumb
      We all have our moments!
      Speaking of which, the reason I put this thread where I did was, was that I've always had these stick computers described as, this is intended to make a Not-Smart-TV TV into a Smart TV. (No idea why, it doesn't really make sense to me, either.) Clarity: not arguing, explaining why I did the dumb. It makes more sense where it is now, and I appreciate the help.
        • 22030
        Originally posted by starhawk
        AXP288C
        heres what ive found so far,hope these help
        • starhawk
          • Apr 2014
          The second one -- the "CircuitCo Sharks Cove" PDF -- that looks especially helpful.
          The relevant circuit is on Page 37... I wish I knew better what value they'd used for CR5A2, but I can probably figure out something adequate from the parts bin. The tricky thing for me is that I can't really afford a custom PCB so I've got to replicate in perfboard... which means thru-hole only components. Yipe.
          • Andyservo
            • Jun 2013
            • 152
            • Indonesia
            Thankyou SMDFlea
            • ezenia
              PS4 controller left stick potentiometer replacement issue
              by ezenia
              Not sure if this is the correct section, but I have a PS4 controller that I am trying to fix. It developed stick drift on the left stick and the usual simpler methods did not fix the problem.
              So I went on eBay and ordered some replacement potentiometers. https://www.ebay.co.uk/itm/174967976757 is where I got them from.
              I took the green potentiometers off the replacement sticks and soldered them onto the PCB. Assembled the controller and ran some tests. The drifting was somewhat fixed (not fully in center, but way better than before). However,...
              09-30-2023, 02:19 PM
            • flusher
              Apple MBP16" A2141 820-01700 PMIC power cycles no boot no shorts
              by flusher
              Bought myself a project thing. Apple MBP16" A2141 820-01700
              No shorts, no visible waterdamage.
              Dead. no history.
              All USBC ports do 20V and charging battery.
              If you plug battery/charger PPBUS is 12.6v and all power rails like RTC, 3v3, 5v etc are present. U7800 PMIC all voltages are present APART from PPVCCPRIMCORE_PRIM_REG (not sure if it has to be present at this stage?! resistance is 40 Ohm). SSD 2.5, 0.9, 1.8 are present on both wings. Charger meter shows 30ma or something like this on charged battery.
              But what PMIC does is that it power cycles(dropping to...
              02-21-2025, 03:12 PM
            • dbuergi
              PS5 Dualsense controller stick drift a mainboard issue?
              by dbuergi
              I got a controller where the left stick was moving left all the time (-1.00 at calibration tool). Even after changing to hall effect sticks it stayed the same and reset and all others things didn't help.
              I removed the stick again and even without it calibration tool shows a movement to the left. Anybody knows where the fault can come from? Maybe any bridges or damaged SMD components?
              05-02-2025, 05:00 PM
            • arahban
              Apple MacBook A2442 faulty PMIC - Question about possible replacement
              by arahban
              Hello Gentlemen,
              I am working on an apple MacBook A2442 board pn 820-02098-A with a visible short on the PMIC U7700 MVK-PLUS as per the schematics
              I have a donner board from apple macbook pro m1 A2338 PN 820-02020 and I saw that the PMIC U8100 TMLT46B0-JPE could be a possible replacement for the U7700
              Can you please help me confirm if the U7700 can be replaced with U8100 ?
              APL1098 is it the same as APL1096
              Thank you very much in advanced
              Ahmad
              12-23-2023, 05:25 AM
            • tommy97
              PS5 Dualsense stick drift
              by tommy97
              I’ve been dealing with some stick drift issues on PS5 DualSense controllers. I’ve replaced the analogs on 4 different controllers using parts from 3 different suppliers (Mobile Sentrix and some from eBay), but I’m still getting slight drift, around 0.01 to 0.05 — only noticeable when zoomed in on the DualSense test GUI.
              Anyone else had this happen even after replacing the sticks? Not sure if it’s the parts, or fault with the controller, or just how sensitive these are. Would really appreciate any tips or suggestions!...
              08-07-2025, 02:19 AM
