H81mxv bios
  • pooya_pm
    • Jan 2021
    • 259
    • iraq
    H81mxv bios
    H81mxv bios plz
  • pooya_pm
    • Jan 2021
    • 259
    • iraq
    Re: H81mxv
    Originally posted by pooya_pm
    h81mxv bios plz
    i found this
    • bel77
      • May 2013
      • 33
      • jordan
      Re: H81mxv
      tested work 100%
      • Neddsme
        Bios partially corrupted somehow and now warm boot doesn't work which is critical
        by Neddsme
        Hie.
        I own a Lenovo ideapad v310-15IKB with an i5 7th generation with only Intel graphics configuration.
        Now the heart of the problem is that I don't know when or how it happened but I suddenly started getting distortion in the graphics output on the LCD. This basically meant a black screen full of flickering multicolored short horizontal lines. This would happen 30-60 minutes after booting and using it normally.
        I run Windows 10 20H build so I thought it was just a Windows update issue or graphics driver outdated issue.
        I managed to run Windows troubleshooting and...
        02-04-2022, 05:57 AM
      • DynaxSC
        Stubborn GIGABYTE B365M AORUS ELITE - main PCIe x16 GPU port working only in x8 width mode
        by DynaxSC
        I have this board, where I have exchanged the LGA1151 socket. During testing I discovered, that the large PCIEX16 slot won't by no force work in x16 mode, but keeps to work in x8 mode only.
        I tested this with GPU-Z, also with Render Test (but tried also Furmark and Heaven Benchmark - no effect).
        Tested on Core i5-9600K as well as on an Pentium G5420 and MSI NVIDIA GTX1070 and 2 other cards, including RTX3060Ti.
        Board architecture definitely allows x16 mode, as all 16 PCIe lanes are present between CPU and main GPU slot (nearest to CPU).
        05-04-2025, 12:08 PM
      • studdy05
        Bricked HP Probook 450 G7 Bios questions
        by studdy05
        Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
        Ive got...
        07-08-2025, 09:24 PM
      • iZakre
        HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
        by iZakre
        Hello everybody!
        To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
        The thing is that I had installed TeamViewer and could log into the computer...
        02-19-2023, 02:27 PM
      • Byte_76
        Requesting assistance with 486 motherboard repair
        by Byte_76
        I have a seemingly rare 486 motherboard which shows no signs of life.
        The Motherboard is marked with the labels B887 / 8 / 9 AI, which seems to be a Mecer branded board.
        With an AT power supply hooked up, the power supply turns on but the board does not post, there is no beep and there is nothing displayed on the post analyser card, whether it's plugged into a PCI slot or an ISA slot.
        I found a thread on Vogons of someone else who had the same board in working condition.
        What I've tried so far: (In each case, the symptoms remain unchanged as...
        04-12-2025, 06:43 AM
