I downloaded this file on asus site but the files is 16386 can anyone make it this to 16384 size please
Asus prime a320m-k bios
Tags: None
Re: Asus prime a320m-k
Follow the instructions in this thread - https://www.badcaps.net/forum/showthread.php?t=91995 .You already have the bios,you just need UEFITool from the second link .
Download the bios from the support page,open it with UEFITool , select "Action - Capsule - Extract Body" that will remove the 2KB CAPsule header
.Last edited by SMDFlea; 01-20-2021, 07:13 AM. -
by razor_amdWith ASUS, not everything is quite so simple. I will show you my way. It may be longer or harder but it is the right way to do it in my humble opinion.
This is the picture of 3 similar ASUS motherboards, all of them being X555LD...-
Channel: BIOS Requests ONLY!
by piratiHello everyone,
by grimacelordHello,
Anyway, I took dumps of both chips and then downloaded the latest update for this motherboard from ASUS's website...-
by DynaxSCHi,
Usually on ASUS boards it worked...-
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
- Loading...
