BIOSTAR H61MGV3 BIOS BIN file
  • vhin02
    • Aug 2020
    • 13
    • Philippines
    Hi! Does anyone has a BIOS BIN file for BIOSTAR H61mGV3 Ver. 7.9? Thanks.
    • 21843
    Re: BIOSTAR H61MGV3 BIOS BIN file
    Are you sure its Ver. 7.9
    • vhin02
      • Aug 2020
      • 13
      • Philippines
      yes. it's indicated on the board.
      • sumitsolutions09
        • Oct 2021
        • india
        H611R320 for Biostar H61MGV3 ver 7.5 bios .bin file required plz somebody help
        • mjavicop
          • May 2022
          • 6
          • quito
          for my H61MGV3 ver7.5 worked R408 and R320 didn't work
          • to5it0
            by to5it0
            10-24-2025, 01:35 AM
          • Citymin
            by Citymin
            S/N : 5RNK9FFT70...
            08-05-2025, 05:12 AM
          • m1ch43lzm
            by m1ch43lzm
            Hi everyone
            09-06-2025, 05:47 PM
          • Forest79
            by Forest79
            07-23-2023, 07:39 AM
          • maanee11
            Help to get Lenovo BIOS bin file for Thinkpad T560
            by maanee11
            Hello Everyone,
            I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
            https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
            In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...
            05-15-2022, 11:59 AM
