dell optiplex 7060 bios bin need bios
  • audrimars
    replied
    Thank you for helping >> I need bios for this pc 7060
    s.t {6JBZCW2}
    replied
    Re: dell optiplex 7060 bios bin need bios
    Originally posted by bembeno
    sorry the motherboard owner sent a wrong serive tag no but im sure that the backup bios belong to the motherboard so its 7040 MT
    this is the file i need to fix
    Start a new thread and post your request again,lets keep this 7060 thread for the 7060 only ! .At least now you should understand why its important to post the service tag.
  • bembeno
    replied
  • hoaca388
    replied
    Re: need help with repairing bios dell optiplex 7060 tower
    servicetag : 99N7MX2
    The file you posted belongs to the OptiPlex 7040 Tower
    Service Tag: 1GQXVB2.The file you need is #4
  • bembeno
    replied
    replied
    https://www.badcaps.net/forum/showthread.php?t=103569
    You MUST:
    • Post under a related thread if it exists
    • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 )
    • Post what the problem is,be specific - Black screen,no boot,running slow,password.
      Do NOT post "clean me","clear bios","clean bios","bios need" or other such terms
  • bembeno
    replied
  • Drugzy
    replied
    Originally posted by DUGi
    I did a progress by modifying programmer to 3.3V by lifting pin28, soldered a wire between the power pin 28 and the output of the 3.3 V regulator as well as pin 9 of the CH341. I noticed more variations of that "conversion". which one is correct ?
    I'm able now identify the chip and read the data from it. BUT when I write to the chip verification is failing and data are not written correctly.
    I tried to use different USB 3 ports, powered USB3 hub etc. Without luck.
    Any ideas ?
    When I was doing this for the first time I also had issues - I removed the 3.3v mod from the programmer and all my reading/writing issues disappeared - It was on this particular chip too so without the mod it won't do any damage.
    Also the chip clips can be unreliable, de-soldering is more reliable if you are handy with an iron.
  • DUGi
    replied
    Any ideas ?
  • DUGi
    replied
    Hello, Actually chip on faulty motherboard is MX25L25673GMI-08G
    I finally put everything together, CH341A programmer, SOP16 clip which I rewired to 8pin using diagram on the picture.
    I disconnected everything from motherboard except CPU, connected clip to the chip.
    Installed drivers and run NeoProgrammer 2.2.0.3.
    But software is unable to detect chip.
    What I'm doing wrong ?
    Do I have to remove CPU as well ?
    Do I have to power up PSU ?
    If clip is disconnected from Motherboard when I plug the power cord, PC is staring up beeping.
    When Clip is connected it not starting after plugging the power cord.
    If I have to power up PSU is it just short green and black wire from it ?
  • DUGi
    replied
    Update: Chip is Winbond 25Q256JVFQ 1905 16 pin, Machine Service TAG H4Q1GV2
  • DUGi
    replied
    Hello, I need to recover bios on my Dell Optiplex 7060 SFF after unsuccessfull bios upgrade caused by power outage. Can you advice me what I will need to flash it ? As I understand I will need IC SOP16 cable and CH341A USB programmer. Are they all the same or do I have to buy specific one ? I found EEPROM programmer with USB MX25L6405 version 2 from local reseller. Can I use bios from this thread ( Dell OptiPlex 7060 (V_1.24.0).rar) or do I need Service TAG specific BIOS ? What Software will I need ?
  • Drugzy
    replied
    You're welcome.
    Just letting you know both worked flawlessly, my first time dumping a BIOS chip, all with a $10 CH431A programmer.
    Awesome site with all the information!
  • hardware1
    replied
    Originally posted by Drugzy
    Thanks so much
    You're welcome.
  • Drugzy
    replied
    Here's the other BIOS, try it.
    Service Tag: JBWDMP2.
    Thanks so much
  • hardware1
    replied
    Hi Guys,
    As post above
    Here is the second corrupt BIOS - Dell 7060 SFF
    Have two that are dodgy, this one is either Service Tag 13KYVV2 or JBWDMP2 (Unsure which one)
    One I received which would not boot and the other power went out during a BIOS update.
    Cheers!
    Mike
  • Drugzy
    replied
    Thanks, this is working! However there is an administrative password set - what is it, or can it be removed?
    Thanks again, any chance of a working one also for Service Tag JBWDMP2?
    Cheers!
    Answered my own question, there is a jumper on the PCB which clears the password, PC fixed!!! Thanks heaps @hardware1, could you supply one for Service Tag JBWDMP2 also?
    Much appreciated
  • Drugzy
    replied
    Here's your New BIOS file, try it and let me know.
    Service Tag: 13KYVV2.
    Cheers!
  • hardware1
    replied
    Just wondering if anyone could help me recover this BIOS?
    Dell 7060 SFF.
    Any help would be appreciated
    Cheers
    Mike
  • Drugzy
    replied
    Hi Guys,
    As post above
    Cheers!
    Mike
    DELL OptiPlex 7060 OptiPlex 7000 i5-8500T Specification for Upgrade or Repair
    This specification for the DELL OptiPlex 7060 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OptiPlex 7060 boardview and OptiPlex 7060 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
    09-12-2024, 03:44 PM
    DELL OptiPlex 7060 OptiPlex 7000 i5-8500 Specification for Upgrade or Repair
    DELL OptiPlex 7060 OptiPlex 7000 i7-8700T Specification for Upgrade or Repair
    09-12-2024, 03:36 PM
