Hi, I need the asus M5A99X-EVO-R20 motherboard dump, thank you very much.
Need Bios M5A99X-EVO-R20
Re: Need Bios M5A99X-EVO-R20
Get the bios from the support page - https://www.asus.com/Motherboards/M5...HelpDesk_BIOS/
Get UEFITool and open the bios with it.Select "Action" - "Capsule" - "extract body" and save the bios,it will remove the 2KB CAP header file,leaving you with the correct size bios to flash.
https://github.com/LongSoft/UEFITool..._A57_win32.zip -
Cannot delete post, bios download available on Chrome but not available on Firefox, some bug on asus websiteComment
https://dlcdnets.asus.com/pub/ASUS/m...X%20EVO%20R2.0Attached Filesif you find these attachements useful please consider making a small donation to the site
by mkdjDear all,
I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...-
Channel: BIOS Requests ONLY!
by razor_amdWith ASUS, not everything is quite so simple. I will show you my way. It may be longer or harder but it is the right way to do it in my humble opinion.
This is the picture of 3 similar ASUS motherboards, all of them being X555LD...-
by piratiHello everyone,
by DynaxSCHi,
Usually on ASUS boards it worked...-
by AhariHi all,
I...-
- Loading...
