Default Alienware Aurora R4 bios dump request
  • salim.thebadboy
    • Aug 2016
    • 51
    • belguim
    Hi Guys,
    I would like to request a Alienware Aurora R4 bios dump (bin/rom) , i beieve that latest bios is A11 , on the dell website it is only an exe file that i cannot extract.
    Stickers on the board say DP\N 07JNH0 Rev A02
    anybody can extract Dell bios from .Exe
    Thank you
  • Claudiomfa
    • Nov 2015
    • 455
    • Portugal
    Re: Default Alienware Aurora R4 bios dump request
    This is the file. Try and report
    • salim.thebadboy
      • Aug 2016
      • 51
      • belguim
      thanks to trying
      but it is not working
      this is my backup
      • eikspaj
        N1NJ4W4RR10R
        • Mar 2015
        • 135
        • Philippines
        try this goodluck!
        There are 10 types of people in the world. Those that understand binary and those that don't.
        • imranromi
          • Jan 2015
          • 1288
          • Pakistan
          Originally posted by eikspaj
          try this goodluck!
          If you use LBE tool to fix my info.. no work properly need to manually fix 100% work.
          • imranromi
            • Jan 2015
            • 1288
            • Pakistan
            Originally posted by salim.thebadboy
            Hi Guys,
            Thank you
            If not work @Claudiomfa file not bios problem
            • tracker1
              • Jul 2017
              • 113
              • romania
              try this goodluck!
              Thank you!!!! I can confirm bios is working!
              • thedarkmiky
                • Mar 2021
                • France
                Thank for the bios
                I Have brick the Aurora R4 when i try dell bios update.
                Wath is the bios chips on the motherboard?
                thank for your help
                • kimmy0312
                  • Sep 2016
                  • 12
                  • Philippines
                  • anikin73
                    • Mar 2022
                    • 112
                    • singapore
                    I managed to recover a Dell Aurora R4 from your A11 bios . thanks alot.
                    Although the ram slot 3 and 4 got issue, I think now the board is running fine.. Could be that i go back to R4A03, it might work, as i put in the ram tester, all data lines are fine.
                    • Locust
                      • Jun 2022
                      Bricked my bios also trying to mod it for no reason, live and learn. Used the bios dump with CH341A, which is a pain to get on 100% correctly with clip. Bios did work eventually and got the machine to work again. Ram slots 3/4 however now do not work and will cause the pc to boot loop until removed and left in 1/2 only. Any ideas why it would cause 3/4 ram slots to malfunction? I have 2 of these mobos, so even if bricked again it's okay. Just trying to see if i can actually find a solution to the other slots if possible. Seems to be common that the bios causes an issue with 2 ram slots. I'm open to options. And yes I know it's a little old, but paired with a 4930k 4.1Ghz on stock voltage with the asetek AW AIO, it runs like a champ. Open to ideas, if anyone is willing. Maybe try a bios dump from my working mobo? Just trying to not brick my good board...Thanks in advance!
                      • anikin73
                        • Mar 2022
                        • 112
                        • singapore
                        I think if you can get your original bios .bin, it might solve the problem. I measured the used ram tester to diagnose it, it seems the ram slot is good. i seriously suspect so. I am unable to get hold of the original bios...
                        • ductranvinh
                          • Dec 2021
                          • 123
                          • Republic of Vietnam
                          try this goodluck!
                          Thanks for share! God bless you
                          It's Working
                          PC work for schemaltic:
                          Mainboard: Gigabyte Z68XP-UD4
                          CPU: I3-3240
                          Ram: 16Gb
                          Graphic Card: GTX 1050Ti zotac 4Gb Mini
                          SSD: 120Gb
                          HDD: 2Tb
                          • drux
                            Alienware Aurora R15 accidentally flashed with XPS 8960 BIOS
                            by drux
                            I've had an ssd that was previously used on dell xps 8960 and then it was installed in Alienware Aurora R15(intel version). On first windows boot in R15 windows started bios update and loaded bios for xps 8960(r15 and xps8960 essentially have same motherboards).
                            Now it has xps 8960 bios that looks different from alienware bios and when I'm trying to run bios update files for R15, I get unsupported platform error.
                            These models have AMI/Aptio BIOS.
                            Tried to edit product info with DMI Edit to change values back to Alienware R15, but it does not want...
                            11-03-2024, 01:18 AM
                          • nissimezra
                            AMMTS-SH Alienware Aurora Ryzen Edition R10 Bios dump
                            by nissimezra
                            Device: DESKTOP PC
                            Brand: DELL
                            Model: Alienware Aurora Ryzen Edition R10
                            Service Tag: 3WVDTH3
                            Express Service Code: 8517977463
                            Board number: AMMTS-SH REV A00
                            Request: BIOS dump
                            Problem,: Black screen
                            CPU Ryzen 7 5800
                            No error code just black screen
                            thank you...
                            05-19-2025, 10:52 AM
                          • Habble7
                            by Habble7
                            Suspected Cause:
                            Troubleshooting Attempts:
                            05-22-2025, 07:28 AM
                          • Svyatpro
                            Alienware X17 R2 (LA-L613P) need BIOS dump or BIOS extract
                            by Svyatpro
                            Hello folks.
                            I have Alienware X17 R2 (LA-L613P) with broken BIOS after unsuccessful BIOS update.
                            Dell_PFS_Extract cannot extract BIOS from bios update.
                            Here is my dump....
                            03-17-2024, 12:41 PM
                          • kamkam336
                            Alienware Aurora R8/9 Bios .bin file needed
                            by kamkam336
                            I got a new mobo from Aliexpress for my Aurora r9 and everything was working fine until i did a bios update. It did not work and now i get 3x, 7x, 3x, 6x blinking code. Dell says that is a corrupt bios. So i have the ch341 and software required, i just don't have the bios.bin file.
                            Since the board is from Aliexpress it doesn't have a service tag, I have a copy of the .exe bios and a copy of my corrupted bios attached. Hopefully this is enough, if anyone is able to help me and requires any more information please let me know.
                            Thanks ...
                            08-19-2024, 06:59 PM
