Apple 820-00034A A1418 problem on bios
  • Pragmatiko
    • Jul 2013
    • 468
    • IT
    i have and iMac A1418 with bios corrupted.
    i have tested other bios dump and it turn on but cant access on iOS.
    If i attach my corrupted bios it's possible to make correction?
    Thank you in advance.
  • FalconPunch
    Surface Pro X 1876 Bios corrupted
    by FalconPunch
    Hello everyone, I happen to have a Microsoft Surface Pro X 1876 in my hands. It was brought to me by a friends which happen to have taken off the bios chip to test another motherboard. Upon putting back the bios chip on the original motherboard, The PC is stucked on Windows logo and won t boot to bios or anything. I suspect that the changes of bios chip somehow corrupted the firmware inside. Is the hypothesis correct?
    Also i extracted the bios inside the chip which was on Winbond 25R128JWPQ you can find the file attached if you can fix it (if possible, I would like some insight on...
    08-09-2025, 03:56 AM
  • zlr8r
    Hp Zbook Firefly 14 G10 - corrupted Bios's ? - please check
    by zlr8r
    Greetings
    I am hoping someone could have a check of my Hp Zbook Firefly 14 G10 , 2 x 32MB Bios files... (powers on / black screen).
    Serial Number: 5CG3202C16
    Product #/SKU: 739P0AV
    CT Number: PRTUE00WBI30YX
    Description: HP ZBook Firefly 14 inch G10
    BuildID: 23WWWGAZ602#SABU#DABU
    Feature Byte: 476J6S6b7B7M7Q7U7W7m7saBaEapaqauawbUbhcAfPgSguhKj4jhk8mEn7nVngpDpVpWpnpqprqMqkqz.G3
    MAC address not found.
    • I extracted both 32mb bios files (Main + EC). But when i run the main 32mb bios through MFIT.exe , it produces this error; ie:,
    10-28-2025, 01:56 PM
  • macabook
    by macabook
    🧩 Initial Issue
    07-24-2025, 02:17 PM
  • TylerHyde21
    Lenovo TD350 ThinkServer BIOS v505 Corrupted BIOS,
    by TylerHyde21
    Hello, the bios on my Lenovo TD350 ThinkServer got corrupted during a bios update, the bios restore function killed the Server.
    I need to flash the bios inside the MX25L12835F SOP8, i have already desolder the chip and solder it into my SOP8 adapter and read it with a ROM programmer.
    I use the innoextract 1.9 software to extract the bios file from the .exe file that i download from lenovo website, can you help me edit the Hex file (removing the Index part and resize the file)?
    This guy claim to have done it https://forums.lenovo.com/t5/ThinkSe...doesnt-Start-u...
    06-29-2024, 10:38 AM
  • Loli Popu
    DELL LATITUDE 5590 BIOS CORRUPTED BY CH341
    by Loli Popu
    Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
    12-13-2024, 08:29 AM
