Need Bios Hp All in One Ms200 Series, dump Ok
  • passete
    Living=Sharing
    • Jun 2015
    • 487
    • France
    Hello to all
    I can't find any bios for this all in one HP Pc
    Model : MS215fr
    Symptom : once a press the ON switch, it turns on and off (half second)
    I have dumped the Bios, if someone can fix it, I appreciate it.
    motherboard : DAOZN1MB6CO
  • passete
    Living=Sharing
    • Jun 2015
    • 487
    • France
    Re: Need Bios Hp All in One Ms200 Series, dump Ok
    I don't have voltage on the bios chip, is this normal ?
    EDIT: I have 3.30V on the bios chip, sorry.
    • dycc
      Vision
      • Nov 2011
      • 625
      • Côte d'Ivoire
      si la machine s'éteint une demi seconde après que tu l'allume ça voudrait dire que le processus de démarrage n'arrive pas à son terme . je crois qu'il faut d'abord chercher à savoir si les deux tensions de base à savoir 3v et 5V sont présentes . ensuite est ce que les tensions 3vs et 5vs commutées sont présentes lorsque tu appuis sur le bouton d'allumage
      • passete
        Living=Sharing
        • Jun 2015
        • 487
        • France
        I have 3, 5 and 19 Volts on several points!
        Well, the machine doesn't really turns on, it's only the power led that lights for a fraction of a second.
        there is no fan or other sign.
        I have see this same reaction on others hp's, writing the bios solved the problem.
        but I can't find any bios for this ms200 series...
        Merci
        • ala_borbe
          aka Donald
          • 1625
          • Malta
          is there any markings on motherboard???
          Im Back... sort of...
          • passete
            Living=Sharing
            • Jun 2015
            • 487
            • France
            What do you mean ?
            • passete
              Living=Sharing
              • Jun 2015
              • 487
              • France
              I've found on a site this bios "Hp All in One MS219br," but of course tha I can't download it.
              Anyone here got this one ?
              • passete
                Living=Sharing
                • Jun 2015
                • 487
                • France
                Anyone here as access to this site : http://eletronicabr.com/index.php?ac...ails;lid=10633
                And share this file ?
                • passete
                  Living=Sharing
                  • Jun 2015
                  • 487
                  • France
                  I have found another problem :
                  Once I press the start switch, the voltage on the bios chip drops to 0 volts.
                  what does it mean ?
                  • Ahari
                    by Ahari
                    I...
                    Today, 06:12 AM
                  • Habble7
                    by Habble7
                    Suspected Cause:
                    Troubleshooting Attempts:
                    05-22-2025, 07:28 AM
                  • haitham sharabati
                    by haitham sharabati
                    Hello engineers 😀,
                    🔧 Device Info:
                    - Model: HP 15-da2007ne
                    - Product Number: 8XF55EA#ABV
                    - Serial Number: CND0338P0D
                    - CPU: Intel Celeron N4000
                    💀 Problem:😅
                    08-07-2025, 04:54 AM
                  • Kjell
                    Samsung Series 9 - BIOS issue
                    by Kjell
                    After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
                    Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
                    08-01-2025, 09:15 AM
                  • Citymin
                    by Citymin
                    S/N : 5RNK9FFT70...
                    08-05-2025, 05:12 AM
