Lenovo Yoga AIO 7-27ACH6 bios
  • AustinCER
    • Apr 2025
    • 50
    Had the same issue with a Yoga AIO 7-27ACH6 - Type F0G7. Fully powers on and no display. Was able to successfully flash clean BIOS to ensure it was a BIOS issue. Device is back to fully operating and POSTing.
    Serial Number: YJ01ECXB
    However since it was a clean BIOS, Machine Type and Serial number are invalid. Wondering if someone could successfully preserve that data for me into a BIOS flash .bin. I will include the matching BIOS dumps along with the .bin i used to successfully flash the BIOS. Much appreciated in advance.
  • volinakis
    • Jan 2021
    • 3265
    • N/A
    try
    please support this forum
    • AustinCER
      • Apr 2025
      • 50
      Originally posted by volinakis
      try
      Tried flashing but did not work. Assumed it wouldnt because I am getting a verification error. Something I did not run into with the Clean BIOS.
      • volinakis
        volinakis commented
        Editing a comment
        I only put your DMI into your bios, problem is with programmer.
    • m1ch43lzm
      • Mar 2019
      • 3008
      • Peru
      The issue you have is when programming the chip, it has nothing to do with the file
      Check your connection, are you using a clip/pogo pin adapter? Maybe it lost connection when writing, Try again, erase -> program -> verify
      Also use 1.8V adapter with CH341A
      • AustinCER
        • Apr 2025
        • 50
        Thanks for the input. I am using the clip. I just went ahead and re-flashed the BIOS with the clean US BIOS and verified the flash and did not run into any errors. Can confirm I am doing everything correct. I have successfully flashed the the clean BIOS 3 separate times with each successfully posting.
        • m1ch43lzm
          • Mar 2019
          • 3008
          • Peru
          Now try again with volinakis' file, the verification error you get is on a different address than the DMI area, as I said before, it's most likely a connection issue with your programmer/clip
          DMI 5C7000-5D6FFF
          • AustinCER
            • Apr 2025
            • 50
            Can't thank you guys enough. True legends.
            • to5it0
              by to5it0
              10-24-2025, 01:35 AM
            • HotSaladMan
              Lenovo ThinkBook 14S Yoga ITL Bad Flash + Need Bios
              by HotSaladMan
              *##*#*#*#*#*#Cringe Warning Used Clips for Tl866ii Plus Backups#*#*#*#*#*#
              Model : Lenovo ThinkBook 14S Yoga ITL
              S/N : MP28JT19
              MFG Date : 2022/02/09
              Factory ID PRC4
              MO : MPNXB26080FX
              MTM : 20WE001US
              MODULE FCC ID : PD9AX201NG
              IC : 1000M-AX201NG
              BOARD INFO
              FLV34 LA-KO51P
              REV : 1B 2020-08-24
              Bit of Info
              Using Tl866ii Plus, it would scan the chip but wouldn't not detect the
              chip id, so i would always uncheck the id check, so it would bypass the error
              i did in fact make...
              11-07-2024, 07:46 AM
            • abhorsen
              Help Disabling Flash Protection Range Registers on Lenovo P360 Tiny BIOS
              by abhorsen
              Hey guys,
              Hope you all are doing well. I come here from Win-Raid because I am having issues disabling Flash Protection Range Registers so I can flash my BIOS from within Windows using Intel's IFW tool/using flashrom within Linux, however I cannot due to the above mentioned error.
              Here is my thread on Win-Raid detailing the whole process I went through: https://winraid.level1techs.com/t/re...h-gen/95478/27
              Essentially I managed to boot into Windows while shorting PINs 1+5 of my audio chip to disable the HAP bit...
              07-06-2023, 10:22 AM
            • maeson
              BIOS Request - Lenovo Yoga L13 Gen3 (AMD)
              by maeson
              Hi dear Badcaps-Community,
              Somehow an auto update, which I triggered before I left my laptop unattended, bricked my BIOS.
              I was able to extract the 2MB BIOS and 16MB BIOS which I will attend. (CH341B black with NeoProgrammer 2.2.0.10)
              The Device is a Lenovo Yoga L13 Gen3 and I was able to identify the following specifications:
              Lenovo Yoga L13 Gen 3 AMD:
              Lenovo Modell: Type 21BB
              Artikelnr.21BB006GGE
              Seriennummer: PW0A6207
              AMD Ryzen™ 5 PRO 5675U
              Memory 16 GB DDR4-3200MHz
              SSD: 512 GB SSD, M.2 2242, PCIe Gen4, TLC,...
              10-31-2025, 03:08 AM
            • scailermeerkat0
              Lenovo Legion S5 Gen 8 (14APH8) - Issues with BIOS Flash in Crisis Mode
              by scailermeerkat0
              My Lenovo Legion Slim 5 Gen 8 was unable to post/boot following a failed BIOS upgrade attempt in Lenovo Vantage. As the upgrade installation assistant was running in Windows, the device blue-screened and has not been able to post since.
              I have attempted to restore the device using Crisis Mode by taking the following steps:
              1. Identified the crisis recovery file expected name to be macn.bin using this guide
              2. Downloaded the MACN24WW BIOS installation package from Lenovo's website --> Extracted the installation package --> Renamed the ".fd" file to
              01-02-2026, 08:08 AM
