Dell PowerEdge T110 server that stopped working after a stress test - bios request
  • Adilson Silva
    • Apr 2026
    • 5
    • Brasil
    I'm working on a Dell PowerEdge T110 server that stopped working after a stress test. I need help recovering the VPD EEPROM (AT24C02).
    ― HISTORY ―
    I bought this server at a charity bazaar (Pequeno Cotolêngo, Brazil). I cleaned it up, installed Windows 10 LTSC, and tested it all day — heavy file transfers to 3 HDDs, driver installations, and finally added an external audio card to watch YouTube. At that point the machine shut down suddenly and never came back.
    ― SYMPTOMS ―
    • Power supply would not arm (no PS_ON signal)
    • Forced the PSU with a jumper — board powers on, fans spin, green LED on
    • Solid amber LED appears 18 seconds after power on
    • CPU and PCH remain completely cold — no POST, no video
    • With RAM removed: amber LED blinks (BMC alive and detecting missing RAM)
    • With RAM installed: amber LED goes solid after 18 seconds (BMC timeout)
    • NVRAM_CLR jumper procedure performed — no change
    ― DIAGNOSIS ―
    After full investigation:
    • MX25L3205D (4MB BIOS Flash) — READ SUCCESSFULLY, content intact
    • AT24C02 (256 bytes VPD EEPROM) — reads as ALL FF, completely blank
    The BMC (Nuvoton WPCM450) is alive but cannot complete initialization without valid VPD data, so it never releases the CPU boot sequence.
    I generated a test VPD bin file with the correct machine data but the BMC rejected it — the structure or checksum format I used was not correct for this board.
    ― BOARD DETAILS ―
    • Model: Dell PowerEdge T110
    • PCB#: 316783600001 A00
    • ASSY: 411783600015 A00
    • VPD chip: AT24C02 (256 bytes, I2C)
    • Programmer: EZP2023+
    ― MACHINE DATA ―
    • Service Tag: 8X4PQN1
    • Express Code: 19417561885
    • MAC LOM1: B8:AC:6F:FC:58:F2
    • MAC LOM2: B8:AC:6F:FC:58:F3
    ― REQUEST ―
    Could anyone please share:
    1. A dump from an identical T110 board (PCB# 316783600001) so I can edit it with my machine data, OR
    2. A pre-edited bin file with the correct VPD structure for this board
    I can provide photos of the board and the EZP2023+ read results if needed.
    Thank you very much for any help!
    Adilson Silva <asilva602@gmail.com>
    17:24 (há 1 hora)
    para mim
    Olá a todos,
    Estou trabalhando em um servidor Dell PowerEdge T110 que parou de funcionar após um teste de estresse. Preciso de ajuda para recuperar a EEPROM VPD (AT24C02).
    — HISTÓRICO —
    Comprei este servidor em um bazar beneficente (Pequeno Cotolêngo, Brasil). Limpei-o, instalei o Windows 10 LTSC e o testei o dia todo — transferências pesadas de arquivos para 3 HDDs, instalação de drivers e, por fim, adicionei uma placa de som externa para assistir ao YouTube. Nesse momento, a máquina desligou repentinamente e não ligou mais.
    — SINTOMAS —
    • A fonte de alimentação não ligava (sem sinal PS_ON)
    • Forçando a alimentação com um jumper — a placa liga, as ventoinhas giram, LED verde acende
    • LED âmbar aceso 18 segundos após ligar
    • CPU e PCH permanecem completamente frios — sem POST, sem vídeo
    • Com a RAM removida: LED âmbar pisca (BMC ativo e detectando RAM ausente)
    • Com a RAM instalada: LED âmbar aceso após 18 segundos (tempo limite do BMC)
    • Procedimento com o jumper NVRAM_CLR realizado — sem alterações
    — DIAGNÓSTICO —
    Após investigação completa:
    • MX25L3205D (Flash da BIOS de 4 MB) — LEITURA CONCLUÍDA COM SUCESSO, conteúdo intacto
    • AT24C02 (EEPROM VPD de 256 bytes) — leitura de TODOS os valores FF, completamente em branco
    O BMC (Nuvoton WPCM450) está ativo, mas não consegue concluir a inicialização sem dados VPD válidos, portanto, nunca Libera a sequência de inicialização da CPU.
    Gerei um arquivo binário VPD de teste com os dados corretos da máquina, mas o BMC o rejeitou — a estrutura ou o formato de checksum que usei não era adequado para esta placa.
    — DETALHES DA PLACA —
    • Modelo: Dell PowerEdge T110
    • Nº da placa: 316783600001 A00
    • Conjunto: 411783600015 A00
    • Chip VPD: AT24C02 (256 bytes, I2C)
    • Programador: EZP2023+
    — DADOS DA MÁQUINA —
    • Etiqueta de serviço: 8X4PQN1
    • Código Express: 19417561885
    — SOLICITAÇÃO —
    Alguém poderia compartilhar:
    1. Um dump de uma placa T110 idêntica (nº da placa: 316783600001) para que eu possa editar? com os dados da minha máquina, OU
    2. Um arquivo bin pré-editado com a estrutura VPD correta para esta placa.
    Posso fornecer fotos da placa e dos resultados de leitura do EZP2023+, se necessário.
    Muito obrigado por qualquer ajuda!
    I need help recovering a Dell PowerEdge T110 server.
    The machine died after a power failure during stress test. The AT24C02 EEPROM (VPD chip) was erased by the event — reads as all FF. The main BIOS Flash (MX25L3205D) was read successfully and is intact.
    Without valid VPD data the BMC does not release PS_ON and the machine won't boot at all.
    Board details:
    - Model: Dell PowerEdge T110
    - PCB#: 316783600001 A00
    - ASSY: 411783600015 A00
    - VPD chip: AT24C02 (256 bytes, I2C)
    Machine data (for editing the dump):
    - Service Tag: 8X4PQN1
    - Express Code: 19417561885
    - MAC LOM1: B8:AC:6F:FC:58:F2
    - MAC LOM2: B8:AC:6F:FC:58:F3
    Could anyone share a dump from an identical board, or a pre-edited bin file with the correct VPD structure?
    Thank you very much!
