Asus strix z490-g gaming wifi bricked after bios update
  • m1ch43lzm
    • Mar 2019
    • 2173
    • Peru
    Try 16MB
    • keeper5511
      • May 2024
      • 20
      • Ελλάδα
      Unfortunately I have to disolder 16mb Chip because it is too close to pciexpress slot.... Clips does not fit there
      • keeper5511
        • May 2024
        • 20
        • Ελλάδα
        Perhaps it is easier you can give me file ME Version 14.1.53.1649V1.1 (extracted from BIOS 2701)?? What do you think??
        So I have test it to 8mb SPI right now...
        • m1ch43lzm
          • Mar 2019
          • 2173
          • Peru
          Tried extracting it, and it's the same version.. 14.1.51.1528, that's why ASUS tells you to manually update ME firmware
          There's a convenient 2mm pitch SPI header on the board, found the boardview for the non WIFI version, and the chip that's closest to the PCI Express slot is the 8MB (W25Q64JV) chip according to boardview
          The bottom chip is the 16MB chip (W25Q128JV)
          SPI header pinout according to boardview
          pin 1, F_SPI_CS1#_R, is connected to the 16MB chip
          pin 2, F_SPI_WP# , shared
          pin 3, +F1_SPI_PWR, 3.3V, shared
          pin 4, GND
          Pin 5, F_SPI_CS0#_SPI is connected to the 8MB chip
          pin 6, F_SPI_CLK_L, shared
          pin 7, F_SPI_MISO_L, shared
          pin 8, F_SPI_MOSI_L, shared
          pin 9, F_SPI_HOLD#, shared
          You have to switch CS0# or CS1# depending on which chip you want to program
          Another option, solder 8 wires between the chip and programmer
          • ronaldopdias
            ASUS ROG Strix B660-I Gaming WiFi – BIOS dump vs ASUS CAP size mismatch, need corruption check, please.
            by ronaldopdias
            I’m troubleshooting an ASUS ROG Strix B660-I Gaming WiFi motherboard and I’m a bit stuck at the BIOS level. What I’ve tried so far
            • Attempted to flash the BIOS using the USB BIOS FlashBack (Q-Flash) port with a properly formatted FAT32 USB drive.
            • BIOS file downloaded directly from the official ASUS support page.
            • Followed the exact FlashBack procedure (correct port, renamed file, standby power only).
            Issue:
            The FlashBack LED does not blink at all — no activity whatsoever. Further investigation
            Because FlashBack didn’t work, I:
            • Removed the BIOS SPI IC from
            02-04-2026, 03:16 AM
          • akwky
            by akwky
            Hi!
            04-14-2025, 01:56 PM
          • razor_amd
            by razor_amd
            12-15-2020, 07:07 PM
          • Technodoc
            ASUS G634J-PMV-VGT Rog Strix need some bios help, laptop black screen
            by Technodoc
            Asus laptop G614JZ-N3012W Rog Strix with i7
            Mainboard G634J-PMV-VGT
            6050A3441302-MB-A01
            2023-02-10
            Power button works okay....power light goes on
            Red "bottom" leds go on
            Charging led works
            Fans do not spin, capslock key does nothing, screen stays black
            I would like to program the bios again, to rule out a corrupted bios.
            However I run into a size error
            The bios chip is a Winbond 25R256JVEN
            Used my Xgecu T-48 to read the bioschip (using select chip as type XM25QH256B @WSON8, read somewhere...
            02-24-2025, 04:46 AM
          • Corey Barkley
            Asus ROG Strix Scar 17 G733ZX-DS94 Need fresh bios forgot password
            by Corey Barkley
            Device: Laptop
            Brand: Asus
            Model: G733ZX-DS94
            CN: DK3L
            Motherboard: G533R-PMV-VGT 6050A3340404-MB-A01
            SN: N2NRKD008429084
            Request: BIOS dump
            Problem: Forgot Password
            I need fresh bios i forgot the password but i have been able to get the bios dump using CH341A so just need the new bios without password....
            04-20-2026, 09:03 PM
